    [Plugin] Volume Calculator2...
    64 Posts 23 Posters 90.0k Views 23 Watching
    • W Offline
      watkins
      Dear TIG,
      I am having problems with the attached model. The volume calculator works fine on the blank casting (2 %), but falls over with the casting with the holes. I am using version 1.8 of VolumeCalculator.rb because (in the past), I found it worked best with internal voids.
      Would it be possible to include a drop-down and editable list of densities, with the option to calculate total mass as well as volume. By editable I mean the possibility to add to the list of materials and densities.
      Would it be possible to include an escape function (ESC key?) so that the calculation could be terminated if found to be taking too long?
      Kind regards,
      Bob
      Model for TIG.skp
        To do stuff with density/volume/weight use my very recent 'Center of Gravity Tool'...
        I have got you 'holey form' to make a Volume... BUT I rotated it in 3D so it didn't take forever to work at 0.5%!
        Having all of those holes in every 'slice' r_e_a_l_l_y slows things...Capture.PNG
        • W Offline
          watkins
          Dear TIG,
          Many thanks for answering my query. I hadn't thought to change the Z direction before running the script. A very, very useful plugin. Thanks
          Regards,
          Bob
            Pout
            Hey TIG,
            Thx for this script.
            I have a little question:
            Let's say a group only contains one or multiple faces not forming a volume (so volume can not be calculated)
            How do I build in a test that determines if the script should continue with the volume calculation (or just give the combined area of the faces)?
            Maybe the test is already in the code, but i can't seem to figure it out completely.
            regards
              There are two versions of Volume - [v1] is slow but 'reliable' and the other [v2] is fast but 'sensitive' !
              v1 will find the volume of a shape even it it has no 'lid' or holes in it - just as if it were filled up with a fluid till it spilled out - but it takes it's time on very high accuracy settings...
              v2 needs a 'manifold' shape - make sure that the form is fully faced - there's my recent manifold.rb to check this. Used on a suitable form v2 will quickly return the volume with as much accuracy as it can muster... if it has 'holes' or complex faces [internal etc] it can't return a volume.
              To find the area of faces there's a new thread started recently that explains how best to do this...
              πŸ€“
                SUCCESS01
                hello......... it seems to be intressting, please how to get it?
                  SUCCESS01
                  thanks man... you're so great πŸ‘
                    BillB1
                    Hi, just wanted to let the community know, I tried running Volume2.1, having had it run successfully in the past, and found that whilst the dialog loaded and the "clone volume" object was created, no volume text label was added to the drawing. Guessing that the problem might be a plug-in conflict, i disabled some of my more recent plugin additions (change filename from .rb to .rbXX) and re-ran Sketchup and Volume. The problem was Sketchy Physics plugin (V3 I think). Disable it and Volume 2.1 works as expected.
                    Don't know if anyone can shed any light on this or can suggest a solution for them both to co-exist?
                    Best wishes to all.
                      Thanks Bill
                      There is a know issue with some clashes with scripts and SketchyPhysics - see this http://forums.sketchucation.com/viewtopic.php?p=300105#p300105 BUT it's never been reported with Volume before ?
                      Perhaps it's a clash with the
                      class Geom;;Point3d
                         def dot(v)
                            self.x * v.x + self.y * v.y + self.z * v.z
                      code ?
                      πŸ˜•
                      I'll look into it...........
                        BillB1
                        No idea TIG, I'm not best-placed to comment on coding πŸ˜•
                        It would be interesting to know whether anybody else has the same issue or whether it is a peculiarity of my system...
                          Mvmcneil
                          I am cleaning up all my plugins and testing as I install each one to make sure there are no conflicts and I keep getting an error when I do a validity check on simple cubes and spheres. Is this normal?
                          Using Sketchup 7.1 on OSX 10.6.5.
                          Thanks.
                            How do you know this is related to Volume?
                            Change your active layer to Layer0 beforehand and see what happens ??
                            • EarthMoverE Offline
                              EarthMover
                              Would it be possible to create a Volume by Surface option for this plugin? I often have to figure out volume calculations of things that below grade and hence not shown in the model. Say something like a concrete footer or slab. In the model I only usually show the surface. I thought it would be great if the plugin recognized if the selection was a single plane with no depth and would prompt the user to set a virtual depth before proceeding to the volume dialog. If it's not too much trouble.
                              Content Creator at Skapeup
                                Adam
                                Can't you just select all of the faces [using a filter] and then get the total area from Entity Info and then x that depth in " to get the volume in cu" [then x 0.000578703703703704 to make it cu' or x 0.000021433470507545 to make it in cuyds]...
                                This one-liner will return the volume of 1" depth of the selected flat faces in cuyds [other selected entities or non-flat faces are ignored].
                                You can change 'd=' to another depth as desired; change 'f=' [and the final 'puts()'] if you want say cu' etc...
                                d=1;f=0.000021433470507545;v=0;Sketchup.active_model.selection.each{|e|v=v+(d*e.area)*f))if e.class==Sketchup;;Face and e.normal.z.abs>=0.999};puts(v+" cuyds")
                                Just copy paste it into the Ruby Console, adjusting d= [and perhaps f= etc] as desired, then <enter>...
                                πŸ€“
                                  EarthMover
                                  Thanks TIG. Would it involve changing the coding for each desired depth? For instance on a brick patio I often have to figure out three volume calculations. One for excavation depth and soil removed (10"), one for crushed gravel base (6") and one for bedding sand @ 1". Right now I do it by copying the surface shape into a different SU session and then making three copies of that and then extruding each to their desired depth. I then run the volume plugin on each group. I thought it would be easier with a prompt to set depth from the initial surface.
                                    The result is cuyds [or cu' if you were to change the f= value] and it's based on a 1" depth - so you can simply multiply that volume by the actual depth in inches to get the actual volume ?
                                    Otherwise paste the code and change the initial d=10; say if it's 10" and so on... see how the 10" version is simply 10x more volume than the 1" version etc...
                                    To make it have dialogs etc is much more complex than a 'one-liner' like this...
                                    πŸ˜•
                                      Having slept on it you would probably want to find the volume of faces that slope too. This version does that - a fully 'vertical' face has 0x volume and a fully 'flat' face has 1x; while at 45 degrees it'll be 0.707x [1/sqrt(2)] of its flat cousin with the same surface area
                                      v=0;b=Geom;;BoundingBox.new;m=Sketchup.active_model;s=m.selection;s.each{|e|(b.add(e.bounds);v=v+(e.area*e.normal.z.abs))if e.class==Sketchup;;Face};if v>0;t="Faces>Volume";r=inputbox(["Depth;","Units;"],['1"'.to_l,"cuyds"],["","cuyds|cu'|cu\"|m3|cm3|mm3"],t);if r;v=v*r[0];case r[1];when "cuyds";f=0.000021433470507545;when "cu'";f=0.000578703703703704;when "m3";f=0.000016387064;when "cm3";f=16.387064;when "mm3";f=16387.064;else;f=1.0;end;v=sprintf("%.6f ",(v*f));p=b.max;m.start_operation(t);m.active_entities.add_text((v+r[1]),p,[10,10,10]);m.commit_operation;else;p 'Canceled.';UI.beep;end;else;p 'No Faces!';UI.beep;end
                                      This 'one-liner' version now asks for the depth and units, and then puts a piece of Text at the selected faces' max bounds.
                                      To make it into a proper tool do this...
                                      Make a file called 'VolumeFaces.rb' in the Plugins folder and add this code
                                      require 'sketchup.rb'
                                      module TIG
                                      def self.volumefaces()
                                      unless file_loaded?(File.basename(__FILE__))
                                        UI.menu("Plugins").add_item("Volume from Faces..."){TIG.volumefaces()}
                                      end#menu
                                      file_loaded(File.basename(__FILE__))
                                      It then appears in Plugins Menu under 'Volume from Faces...', select faces and run it, set the dialog options as desired etc... πŸ€“
                                        Ah damned there is no right button on Mac? 😞
                                        But as writed in the header there is also a Menu on the top line πŸ˜„
                                        Because Menu volume is on contextuel menu on right clic button !
                                        you must have also sketchup.rb in the folders Plugins!
                                        Maybe it's for that you don't see that!
                                        works fine wtih the free one! β˜€
                                        %(#FF4000)[Moderator note from thomthom:
                                        I removed the sketchup.rb file as it not be needed to distribute this. Each SketchUp version needs a specific version, otherwise odd bugs can appear. The file should also not be in the Plugins folder. (Might have been true many many versions ago, but for the last few it should be in the Tools folder.)]
                                          duchuy2001
                                          plz upload v1.8 bro TIG !!!
                                          Thank u very much !
                                            Thank u very much !
                                            If you go the the SCF Plugins Index page - menu linked above - and use your browser's find function [ctrl+F?] for 'volume' you'll find all of the volume tools listed in their own threads - v1.8 has its own thread... πŸ˜’
                                            Please learn to use the basic SCF forum and browser-page search/find tools it will be to your advantage...
                                            • 3 / 4
