    Stretching with an offset + stretching on all sides
    37 Posts 7 Posters 3.0k Views 7 Watching
      I can type it in - perhaps I release ctrl/shift as I do it and then re-press ?
      I'm on PC what's yours ?
      • X
        xrok1
        do your second click (or release mouse button, depending which way you work) to end the scaling, then type your values and SU will adjust accordingly even though you ended the operation. its like drawing a line; then entering length, doesn't matter that its already done SU will resize it. πŸ˜‰
        • GaieusG
          Now is that a question Rocky or a statement?
          Please, note that my English is really bad and it's 22:30 here already (and I did not sleep last night)
          πŸ˜’
          • X
            xrok1
            its a fact, jack. πŸ˜‰ try it
            • GaieusG
              Then it seems to be the same as what I wrote above.
              πŸ˜‰
              • X
                xrok1
                right, sorry, but you don't mention clicking the mouse which is the key action. try it exactly the way you explain it and it doesn't work because your releasing ctrl+shift without finishing the scale. πŸ˜›
                • GaieusG
                  I never "click again" with the scale tool just release it. Also when not using these keys. And it works for me this way (too)
                  • X
                    xrok1
                    @xrok1 said:
                    do your second click (or release mouse button, depending which way you work)to end the scaling, then type your values and SU will adjust accordingly even though you ended the operation. its like drawing a line; then entering length, doesn't matter that its already done SU will resize it. πŸ˜‰
                    i guess you use the click(hold) drag release method. i use the click, move, click again method. 😳
                    • GaieusG
                      No, click-move-click here, too. Especially with the PushPull tool I could never get used to click-drag-release. But with the scale tool (now I just realise) when this setting is on, both method works just fine. Try it; click, drag and release. Then enter the value.
                      • X
                        xrok1
                        this is why you can do it either way.
                        • X
                          xrok1
                          i wonder if we should report each other for spamming this thread? 🀣
                          • GaieusG
                            No, I am telling you. "Simple" click-move-click here. I just know - this is the first thing I always modify with every new version!
                            πŸ˜„
                            I can always close your reports
                            πŸ˜‰
                            • X
                              xrok1
                              i know what your saying but if you leave it on auto detect it works either way all the time. you don't have to decide, you can alternate if you wish. πŸ˜†
                              • GaieusG
                                I am an old man who does not like to try out anything new.
                                πŸ˜‰
                                  agamemnus
                                  Thanks.
                                  I could never understand this philosophy of forcing the user to input stuff in stages, without telling the user what those stages are. Same with copying with ctrl and then pressing "x10" or whatever. There's no interface that says "now enter the amount of copies made you want-- you have to remember!
                                  It's simply un-intuitive to have to type in the number and press enter AFTER the operation.. I am going to forget all about this in a few months and post the same question. 😞
                                  • GaieusG
                                    Ah come on, you won't forget if you really try to do it a couple of times to see how it works!
                                      agamemnus
                                      Forgetting everything is in my nature. As is learning new things (and old things). β˜€
                                      • 2 / 2
