    Stretching with an offset + stretching on all sides
    37 Posts 7 Posters 2.1k Views 7 Watching
      Now is that a question Rocky or a statement?
      Please, note that my English is really bad and it's 22:30 here already (and I did not sleep last night)
      ๐Ÿ˜’
      • X Offline
        xrok1
        its a fact, jack. ๐Ÿ˜‰ try it
        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
          Then it seems to be the same as what I wrote above.
          ๐Ÿ˜‰
          • X Offline
            xrok1
            right, sorry, but you don't mention clicking the mouse which is the key action. try it exactly the way you explain it and it doesn't work because your releasing ctrl+shift without finishing the scale. ๐Ÿ˜›
              I never "click again" with the scale tool just release it. Also when not using these keys. And it works for me this way (too)
              • X Offline
                xrok1
                @xrok1 said:
                do your second click (or release mouse button, depending which way you work)to end the scaling, then type your values and SU will adjust accordingly even though you ended the operation. its like drawing a line; then entering length, doesn't matter that its already done SU will resize it. ๐Ÿ˜‰
                i guess you use the click(hold) drag release method. i use the click, move, click again method. ๐Ÿ˜ณ
                  No, click-move-click here, too. Especially with the PushPull tool I could never get used to click-drag-release. But with the scale tool (now I just realise) when this setting is on, both method works just fine. Try it; click, drag and release. Then enter the value.
                  • X Offline
                    xrok1
                    this is why you can do it either way.
                    • X Offline
                      xrok1
                      i wonder if we should report each other for spamming this thread? ๐Ÿคฃ
                        No, I am telling you. "Simple" click-move-click here. I just know - this is the first thing I always modify with every new version!
                        ๐Ÿ˜„
                        I can always close your reports
                        ๐Ÿ˜‰
                        • X Offline
                          xrok1
                          i know what your saying but if you leave it on auto detect it works either way all the time. you don't have to decide, you can alternate if you wish. ๐Ÿ˜†
                            I am an old man who does not like to try out anything new.
                            ๐Ÿ˜‰
                              agamemnus
                              Thanks.
                              I could never understand this philosophy of forcing the user to input stuff in stages, without telling the user what those stages are. Same with copying with ctrl and then pressing "x10" or whatever. There's no interface that says "now enter the amount of copies made you want-- you have to remember!
                              It's simply un-intuitive to have to type in the number and press enter AFTER the operation.. I am going to forget all about this in a few months and post the same question. ๐Ÿ˜ž
                                Ah come on, you won't forget if you really try to do it a couple of times to see how it works!
                                  agamemnus
                                  Forgetting everything is in my nature. As is learning new things (and old things). โ˜€
                                  • 2 / 2
