    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 103.6k Views 44 Watching
      It'd be interesting to see what speed this plugin worked at with the SU UI disabled. Any chance of an updated version?
      • Chris FullmerC
        @didier bur said:
        Is there still a conflict with progressbar ?
        Nope! It is working great now with progressbar. Thanks for fixing it so quickly too,
          milfot
          Wow, this plugin is fantastic!!
          Much appreciated... i am off to build a forest.
          ..cam
            denna003
            THAnk you very much!!!! ๐Ÿ˜‰
              AcesHigh
              Didier, is this the last version of your tool?
              Can I make a suggestion? It seems the altitude option is too "hard". I mean, I think you could add some dialogue to add a % of chance that components will spray below and above the maximum altitude. That way, they will concentrate on the set altitude, but some of them will spread casually beyond (unless you set the chance of that happening to 0%)
              • T
                tomislavm
                Thank You!
                Where in Croatia?
                  madhav
                  Thanks a lot
                  • Didier BurD
                    Didier Bur
                    Where in Croatia?
                    Pisak, that's 40kms South of Split and 20kms North of Makarska.
                    DB
                    • T
                      tomislavm
                      Nice place for vacation!
                        alsenhawk
                        Thank you,that's what i m looking~
                          arjunmax09
                          @rv1974 said:
                          Didier thanks for your efforts!
                          One can get interesting things with new vertice mode.
                          http://img212.imageshack.us/img212/6828/screenshot060qi3.jpg
                          [URL=http://g.imageshack.us/g.php?h=212&i=screenshot060qi3.jpg][IMG]http://img212.imag
                          But there's bug in vertex+no to keep vertical . It's not working (see lonely cylinder over mesh, in all other cases components stay vertical)
                          To "keep vertical" unchecked will result the component to be placed vertical to mesh, it'll work this way, right?
                          P.S. I'm not programmer (my wife is- it's enough for one family) but you're one step from "spray along vertices of curve" ? ๐Ÿ˜‰
                          P.P.S. Do you shine in ruby field only or there are some lisp routins of yours?
                          hey!!! how did you create the cool DNA model man???!!!... i mean the perfect spiral thing... which plugin did you use???
                          when you fail at something....you haven't really failed...you've found one way the thing will not work out
                          • Didier BurD
                            Didier Bur
                            I was used to code in Autolisp years ago, and now I'm learning Javascript along with Unity3D. ๐Ÿ˜›
                            Regards
                            DB
                              arjunmax09
                              didier... your compo spray is interfering with the progressbar script.. any improvements you've made to compo spray so that it doesn't do the progressbar thing??
                              • Didier BurD
                                Didier Bur
                                I though I had done this several monthes ago, but just in case see page 1 of this thread and download the latest version. The spray uses its own progress bar class named "sprayprogressbar", so there should not be any conflict with other plugin(s).
                                If the problem persists, not my fault anymore ๐Ÿ˜‰
                                Regards,
                                DB
                                  arjunmax09
                                  um.. didier ... there's no ruby file in the latest update... there's one rbs file and one pdf file... where did the plugin go man...??? ๐Ÿ˜’ The rbs file is in the following folder.....
                                  Utilisateurs\Bur\Exercices\Ruby\Component_airbrush
                                  checked both the english and french versions.. both the archives contain the same files....please help... ๐Ÿ˜ž
                                  • Chris FullmerC
                                    .rbs is a plugin. It is the extension put on encrypted plugins.
                                    Didier, we are running into problems where it appears that this script is breaking progressbar again. I know you fixed it up perfectly quite a while ago. did it revert back somehow to a version that no longer works? Or do you think that it should still be working correctly and that perhaps it is something else messing up progressbar? Any thoughts?
                                      maymay
                                      I get an error when SketchUp starts:
                                      Error Loading File compo_spray.rb
                                      C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; no .<digit> floating literal anymore; put 0 before dot
                                      RBS1.0
                                      C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; syntax error
                                      RBS1.0
                                      C;/Program Files/Google/Google SketchUp 6/Plugins/compo_spray.rb;1; Invalid char `\030' in expression
                                      Any ideas? I'd really like to try this out.
                                      • Didier BurD
                                        Didier Bur
                                        Hem, hem, it seems we have some problems with the scrambler now...
                                        I've uploaded the latest RB version, in which there's NO progressbar class. I suppose there's a conflict with another plugin than this one.
                                        Sorry for the inconvenience with the RBS.
                                        Regards,
                                        DB
                                          rangrstudio
                                          Hi I'm trying to install this on Mac with Sketchup 7.
                                          The compo_spray.rb is in the Plugins folder, but I'm not seeing it in the plugins menu. Have reinstalled SKP 7 from scratch, then unzipped the zip file in the plug-ins folder per instructions but nothing.
                                          Is it not mac compatible?
                                          EDIT: I tried it on a windows machine (XP with SKP 7) and I couldn't get it to work there either. The zip contains "compo_spray.rb" and the pdf file. Is there something missing? Thanks for any help.
                                            If you read the PDF help file you'd see that Component Spray Tool is accessed from a pop-out menu in Draw Menu NOT the Plugins Menu !CStool.png
                                            • 3 / 5
