    [Plugin] Slicer v4.3 20110619
    102 Posts 20 Posters 151.2k Views 20 Watching
        So the 'ribs' are vertical.
        How do you determine there rotation about the Z axis ?
        By axis X/Y or by Node angle bisector etc ?
        It is easy enough to make the closing edges 'horizontal'...
        πŸ€“
        • mariochaM
          mariocha
          Great.
          My sections are always standing up. But at any angle on xy plane.
          Oh, and the top and bottom level have to stay the same if a face is created. Offset tends to change these if the initial top or bottom lines are slanted, as you know.
          %(#008000)[Mario C.
            If you made a curve along the front edge then the ribs could be angled to match the angle-bisector to each pair of edges at a node, or square at the ends ?
            What would the typical 'scale' of this be - i.e. rib depth and rib spacing etc...
            Do these ribs project into the face, or out from it ?
            • mariochaM
              mariocha
              A curve along the front edges ? Ha! on the floor, you mean? It would have to be a bezier, I guess.
              Ribs are a few inches (4") behind the faces.
              Typical heights are 5' to 20', rib with of 10"
              %(#008000)[Mario C.
                You can make a 'curve' from any selection of edges that are continuous - use 'weld.rb'.
                You could set this curve in 4" from the face and then a rib 10" wide inwards from that.
                Centers would then be the curve's nodes ?
                Height matches the face's height where it is 'cut'.
                • mariochaM
                  mariocha
                  Yes that is just right.
                  (I confused "curve" (arc) with "curve" (polyline)) πŸ˜›
                  %(#008000)[Mario C.
                  • mariochaM
                    mariocha
                    Following your advice in an earlier post about using JPP, I looked at it again. I realized I was not using the settings adequately. Once the settings are right, it does the job pretty well. 😳 πŸ˜„
                    All that's needed now is Slicer to follow the curve of the footing slicing at angles like you mentionned.
                    %(#008000)[Mario C.
                    • mariochaM
                      mariocha
                      Well, for now, the ribs are perpendicular to a straight line averaging the direction of the pane. This line angles as needed and we treat the mesh in sections. I ajust the axis along the way. We have to do a footing plate showing where to stand the constructed rib.
                      %(#008000)[Mario C.
                      • P
                        princedragoncok
                        Firstly great work on Slicer, but as many have mentioned an upgrade to slicer-modeller would be fantastic. I have also started learning paracloud gem, but as of yet there aren't enough reasons for me to go out and buy it just right now. Although I don't fully understand all its functions yet, I was particularly interested in a ribbed structure in their gallery which was created by some sort of internal 'pinch' points. It is illustrated below..
                        http://paraclouding.com/WP/wp-content/themes/tma/images/uploads/model-photo-showing-the-ribs-structure-which-vary-in-depth.jpg
                        Could the slices perhaps follow bezier curves either (A) - manually created by the user, or (B )- generated automatically by some sort of 'pinching'?
                        Possible?? ❓
                          Look at my Extrude Edges By Rails By Faces
                          Make the face a 'rib' ?
                          OR try the simpler EEbyFace and process a 'rib' face just the one curve at a time, useful if the form is not susceptible to a 'meshed' solution...
                          • P
                            princedragoncok
                            Yes that is almost the solution indeed... but what about the slots? Can slots automatically be made at intersections via a plugin? and then laid out nicely like in slicer?
                            • mariochaM
                              mariocha
                              One could also try FFD on the grouped slices. No ?
                              %(#008000)[Mario C.
                                You want "Slotter" πŸ€“
                                Run the 'Slotter' tool, you select a shape [group] that has some intersecting forms [groups] (perhaps two 'sliced' sets in two 'planes'), choose whether 'top' or 'bottom' slots required in the selected shape.
                                It booleans half slots in the selected shape at every intersection [say from the 'top] to match the intersecting forms, and also all of the other forms gets slots added in the other direction, so that then all of the forms will 'slot together' if made in reality...
                                The slotted shapes would be copied/grouped for safety and laid flat if desired ?
                                This idea is quite doable... I'll think on it πŸ’­
                                Any feedback welcome during the 'gestation' phase...
                                • P
                                  princedragoncok
                                  Slotter... that's exactly it. Don't really know what to add to your description at the moment apart from laying them out neatly after slotting. I have a laser cutter at my disposal at the moment (I work in a model shop) and would love to realise some concept designs with slotter, slicer and slicermodeller. Looking forward to the next upgrade!
                                  • X
                                    xrok1
                                    πŸŽ‰
                                    wtf πŸ˜†
                                    we need a smiley of someone tapping there watch. πŸ˜†
                                    [edit] guess this will have to do
                                    http://t2.gstatic.com/images?q=tbn;2qN6u957f_4AnM;http://neatliving.typepad.com/photos/uncategorized/2008/10/03/smiley.png
                                      I do the impossible immediately, but miracles take a little longer... πŸ˜‰
                                      • P
                                        princedragoncok
                                        Lol, a slicing miracle... I can't wait
                                        • mariochaM
                                          mariocha
                                          I just encountered a situation where I am asked for ribs that follow the curve, staying perpendicular to it (like radial).
                                          %(#008000)[Mario C.
                                            Noted...
                                            • 3 / 6
