    RAL colors
    85 Posts 40 Posters 44.0k Views 40 Watching
      FWIW, I compared the list of SKMs in the RAL folder with a list of RAL colors with RGB values I downloaded somewhere. I found 9 colors not listed in the SKMs. They'd be easy enough to add and if I get time, I will make them.
        +FWIW those missing 9 are not commonly used by powder-coating companies etc anyway... πŸ˜’
          Then perhaps this was a waste of my five minutes. πŸ˜‰
          RAL Colors ADDED.skp
            Waste not want not. πŸ˜‰
            I've extracted these into SKM files...
            Here's a zip file with the various SKM files RAL+.zip
            [which I've renamed slightly into 'anglicized' versions [Telegrau>>>Telegray] and to match other RAL SKM naming conventions].
            Extract them and place these 9 SKM files into the same folder as the other RAL SKM files [i.e. inside ../Materials/.. named RAL ?]
              Thanks for that TIG. I thought about using Gray instead of Grau but the rest of the list I downloaded was in English with the word Gray used on other names. I decided to stick with what I read.
              Also thanks for zipping up the SKMs. I figured for only 9 colors, they'd be easy enough to drag into the RAL library right from SketchUp but your way makes it easier yet.
              • 3 Offline
                3rdEye
                Yep, thanks TIG,
                i`ll try your Version despite IΒ΄m Austrian and like somehow the german version... πŸ˜†
                  @3rdeye said:
                  Yep, thanks TIG,
                  I`ll try your Version, despite IΒ΄m Austrian and like somehow the German version... πŸ˜†
                  3rdEye
                  You can always load the extra 9 skm files, rename them back with 'grau' etc and they re-export back as new skm files... them remove die Englisch diejenigen...
                  πŸ˜‰
                  • N Offline
                    neilmpenny
                    @burkhard said:
                    unpack and copy into the material folder. All are .skm files
                    credits to Holger K
                    Burkhard
                    Thank you very much for this, I am extremely grateful. You have helped me no end.
                    • I Offline
                      ibskibskalle
                      Dear Burkhard...
                      Thanks for all the work!
                      But, I can't unzip it (tried in many ways) - when i do only one file is there?
                      Are you able to upload another one? IΒ΄m mac user, maybe thats why?
                      Many thanks in advance...to you and Holger K
                      Very Best
                      Allan
                      credits to Holger K
                      Burkhard
                        Allan
                        Download the ZIP.
                        If your MAC auto-extracts it then you have got all of the SKM files [hopefully in a folder].
                        If it does not, then extract all of the files into a folder...
                        Now place that folder of SKM files into your Materials folder's collect tree...
                        Restart SketchUp and ensure the collection is in your Materials lits...
                        • deaneauD Offline
                          deaneau
                          hello RAL Color doesnΒ΄t work in 2013/2014
                          i see only an empty list. the file size is 9k
                          have anybody a link to a working version?
                          thank you
                          dean
                            Actually, it does work in both SU2013 and SU2014 but you have to go through some gymnastics and hold your tongue just the right way. πŸ˜‰
                            Try extracting the contents of the attached ZIP file to the Materials folder and see what you get. On PC you'll probably have to use Open or Create a collection to get SU to look at the folder.
                            RAL.zip
                              keramare
                              Just what i needed. Thanx again.
                                Which file did you download?
                                  keramare
                                  i rushed to thank but cant make it work on 2013. I copied the file in the materials folder but sketchup cant see it. I then made a ral folder and copied there the skm file. Sketchup sees the ral folder but its emty. Any other idea?
                                  UPDATE: TIG saved my life everything is ok. TIG your king.
                                  • jarynzlesaJ Offline
                                    jarynzlesa
                                    thx πŸ‘
                                    http://www.vizualizaceschodiste.mypage.cz/
                                      keramare
                                      first i downloaded RAL-Farben.zip but didnt work out and then i downloaded RAL.zip posted by TIG and worked out.
                                      • deaneauD Offline
                                        deaneau
                                        @DaveR
                                        I donΒ΄t know why the zip is damage or in a wrong format. i use windows8
                                        could you try RAR? normally WIN RAR can zip files open, too
                                        thank you Dean
                                        p.s. color and "farben" is the same, only the file is different πŸ˜‰
                                        greets from berlin
                                          Try it again.
                                          • deaneauD Offline
                                            deaneau
                                            @Dave R
                                            thank you Dave its the German Version πŸ˜„
                                            all Beginner (not you Dave) in Sketchup must remember, that RAL is a subtractive color system
                                            Subtractive color - Wikipedia
                                            (en.wikipedia.org)
                                            and what you see, is an aditive color in sketchup
                                            Additive color - Wikipedia
                                            (en.wikipedia.org)
                                            important is the RAL No.
                                            RAL colour standard - Wikipedia
                                            (en.wikipedia.org)
                                            here the german Page with more infos
                                            (with a link to the english version)
                                            301 Moved Permanently
                                            (ral.de)
                                            here a Page to RAL and other Colorsystems (British and Australian Color System is include) however not for sketchup πŸ˜‰
                                            RAL Effect E3 colour fans and swatches
                                            RAL Effect E3 colour fans and swatches - RAL, BS4800 and BS381C colour charts, swatches, cards, fans and books. Order online
                                            (www.e-paint.co.uk)
                                            thanks again Dave
                                            Dean
                                            p.s. My idea: a thread for all Colorsystems wordwide and possible downloads concentraded in on thread.
                                            • 4 / 5
