    RAL colors
    85 Posts 40 Posters 56.0k Views 40 Watching
      FWIW, I compared the list of SKMs in the RAL folder with a list of RAL colors with RGB values I downloaded somewhere. I found 9 colors not listed in the SKMs. They'd be easy enough to add and if I get time, I will make them.
        +FWIW those missing 9 are not commonly used by powder-coating companies etc anyway... 😒
          Then perhaps this was a waste of my five minutes. 😉
          RAL Colors ADDED.skp
            Waste not want not. 😉
            I've extracted these into SKM files...
            Here's a zip file with the various SKM files RAL+.zip
            [which I've renamed slightly into 'anglicized' versions [Telegrau>>>Telegray] and to match other RAL SKM naming conventions].
            Extract them and place these 9 SKM files into the same folder as the other RAL SKM files [i.e. inside ../Materials/.. named RAL ?]
              Thanks for that TIG. I thought about using Gray instead of Grau but the rest of the list I downloaded was in English with the word Gray used on other names. I decided to stick with what I read.
              Also thanks for zipping up the SKMs. I figured for only 9 colors, they'd be easy enough to drag into the RAL library right from SketchUp but your way makes it easier yet.
                3rdEye
                Yep, thanks TIG,
                i`ll try your Version despite I´m Austrian and like somehow the german version... 😆
                  @3rdeye said:
                  Yep, thanks TIG,
                  I`ll try your Version, despite I´m Austrian and like somehow the German version... 😆
                  3rdEye
                  You can always load the extra 9 skm files, rename them back with 'grau' etc and they re-export back as new skm files... them remove die Englisch diejenigen...
                  • N
                    neilmpenny
                    @burkhard said:
                    unpack and copy into the material folder. All are .skm files
                    credits to Holger K
                    Burkhard
                    Thank you very much for this, I am extremely grateful. You have helped me no end.
                    • I
                      ibskibskalle
                      Dear Burkhard...
                      Thanks for all the work!
                      But, I can't unzip it (tried in many ways) - when i do only one file is there?
                      Are you able to upload another one? I´m mac user, maybe thats why?
                      Many thanks in advance...to you and Holger K
                      Very Best
                      Allan
                      credits to Holger K
                      Burkhard
                        Allan
                        Download the ZIP.
                        If your MAC auto-extracts it then you have got all of the SKM files [hopefully in a folder].
                        If it does not, then extract all of the files into a folder...
                        Now place that folder of SKM files into your Materials folder's collect tree...
                        Restart SketchUp and ensure the collection is in your Materials lits...
                        • deaneauD
                          deaneau
                          hello RAL Color doesn´t work in 2013/2014
                          i see only an empty list. the file size is 9k
                          have anybody a link to a working version?
                          thank you
                          dean
                            Actually, it does work in both SU2013 and SU2014 but you have to go through some gymnastics and hold your tongue just the right way. 😉
                            Try extracting the contents of the attached ZIP file to the Materials folder and see what you get. On PC you'll probably have to use Open or Create a collection to get SU to look at the folder.
                            RAL.zip
                            • K
                              keramare
                              Just what i needed. Thanx again.
                                Which file did you download?
                                • K
                                  keramare
                                  i rushed to thank but cant make it work on 2013. I copied the file in the materials folder but sketchup cant see it. I then made a ral folder and copied there the skm file. Sketchup sees the ral folder but its emty. Any other idea?
                                  UPDATE: TIG saved my life everything is ok. TIG your king.
                                  • jarynzlesaJ
                                    jarynzlesa
                                    thx 👍
                                    http://www.vizualizaceschodiste.mypage.cz/
                                    • K
                                      keramare
                                      first i downloaded RAL-Farben.zip but didnt work out and then i downloaded RAL.zip posted by TIG and worked out.
                                      • deaneauD
                                        deaneau
                                        @DaveR
                                        I don´t know why the zip is damage or in a wrong format. i use windows8
                                        could you try RAR? normally WIN RAR can zip files open, too
                                        thank you Dean
                                        p.s. color and "farben" is the same, only the file is different 😉
                                        greets from berlin
                                          Try it again.
                                          • deaneauD
                                            deaneau
                                            @Dave R
                                            thank you Dave its the German Version 😄
                                            all Beginner (not you Dave) in Sketchup must remember, that RAL is a subtractive color system
                                            http://en.wikipedia.org/wiki/Subtractive_color
                                            and what you see, is an aditive color in sketchup
                                            http://en.wikipedia.org/wiki/Additive_color
                                            important is the RAL No.
                                            http://en.wikipedia.org/wiki/RAL_colour_standard
                                            here the german Page with more infos
                                            (with a link to the english version)
                                            http://ral.de/
                                            here a Page to RAL and other Colorsystems (British and Australian Color System is include) however not for sketchup 😉
                                            http://www.e-paint.co.uk/products.asp?cat=56
                                            thanks again Dave
                                            Dean
                                            p.s. My idea: a thread for all Colorsystems wordwide and possible downloads concentraded in on thread.
                                            • 4 / 5
