    RAL colors
    85 Posts 40 Posters 56.0k Views 40 Watching
      Waste not want not. 😉
      I've extracted these into SKM files...
      Here's a zip file with the various SKM files RAL+.zip
      [which I've renamed slightly into 'anglicized' versions [Telegrau>>>Telegray] and to match other RAL SKM naming conventions].
      Extract them and place these 9 SKM files into the same folder as the other RAL SKM files [i.e. inside ../Materials/.. named RAL ?]
        Thanks for that TIG. I thought about using Gray instead of Grau but the rest of the list I downloaded was in English with the word Gray used on other names. I decided to stick with what I read.
        Also thanks for zipping up the SKMs. I figured for only 9 colors, they'd be easy enough to drag into the RAL library right from SketchUp but your way makes it easier yet.
          3rdEye
          Yep, thanks TIG,
          i`ll try your Version despite I´m Austrian and like somehow the german version... 😆
            @3rdeye said:
            Yep, thanks TIG,
            I`ll try your Version, despite I´m Austrian and like somehow the German version... 😆
            3rdEye
            You can always load the extra 9 skm files, rename them back with 'grau' etc and they re-export back as new skm files... them remove die Englisch diejenigen...
            • N
              neilmpenny
              @burkhard said:
              unpack and copy into the material folder. All are .skm files
              credits to Holger K
              Burkhard
              Thank you very much for this, I am extremely grateful. You have helped me no end.
              • I
                ibskibskalle
                Dear Burkhard...
                Thanks for all the work!
                But, I can't unzip it (tried in many ways) - when i do only one file is there?
                Are you able to upload another one? I´m mac user, maybe thats why?
                Many thanks in advance...to you and Holger K
                Very Best
                Allan
                credits to Holger K
                Burkhard
                  Allan
                  Download the ZIP.
                  If your MAC auto-extracts it then you have got all of the SKM files [hopefully in a folder].
                  If it does not, then extract all of the files into a folder...
                  Now place that folder of SKM files into your Materials folder's collect tree...
                  Restart SketchUp and ensure the collection is in your Materials lits...
                  • deaneauD
                    deaneau
                    hello RAL Color doesn´t work in 2013/2014
                    i see only an empty list. the file size is 9k
                    have anybody a link to a working version?
                    thank you
                    dean
                      Actually, it does work in both SU2013 and SU2014 but you have to go through some gymnastics and hold your tongue just the right way. 😉
                      Try extracting the contents of the attached ZIP file to the Materials folder and see what you get. On PC you'll probably have to use Open or Create a collection to get SU to look at the folder.
                      RAL.zip
                      • K
                        keramare
                        Just what i needed. Thanx again.
                          Which file did you download?
                          • K
                            keramare
                            i rushed to thank but cant make it work on 2013. I copied the file in the materials folder but sketchup cant see it. I then made a ral folder and copied there the skm file. Sketchup sees the ral folder but its emty. Any other idea?
                            UPDATE: TIG saved my life everything is ok. TIG your king.
                            • jarynzlesaJ
                              jarynzlesa
                              thx 👍
                              http://www.vizualizaceschodiste.mypage.cz/
                              • K
                                keramare
                                first i downloaded RAL-Farben.zip but didnt work out and then i downloaded RAL.zip posted by TIG and worked out.
                                • deaneauD
                                  deaneau
                                  @DaveR
                                  I don´t know why the zip is damage or in a wrong format. i use windows8
                                  could you try RAR? normally WIN RAR can zip files open, too
                                  thank you Dean
                                  p.s. color and "farben" is the same, only the file is different 😉
                                  greets from berlin
                                    Try it again.
                                    • deaneauD
                                      deaneau
                                      @Dave R
                                      thank you Dave its the German Version 😄
                                      all Beginner (not you Dave) in Sketchup must remember, that RAL is a subtractive color system
                                      http://en.wikipedia.org/wiki/Subtractive_color
                                      and what you see, is an aditive color in sketchup
                                      http://en.wikipedia.org/wiki/Additive_color
                                      important is the RAL No.
                                      http://en.wikipedia.org/wiki/RAL_colour_standard
                                      here the german Page with more infos
                                      (with a link to the english version)
                                      http://ral.de/
                                      here a Page to RAL and other Colorsystems (British and Australian Color System is include) however not for sketchup 😉
                                      http://www.e-paint.co.uk/products.asp?cat=56
                                      thanks again Dave
                                      Dean
                                      p.s. My idea: a thread for all Colorsystems wordwide and possible downloads concentraded in on thread.
                                      • sallyS
                                        sally
                                        Hello,
                                        I've downloaded Tig's RAL file with English names (thanks Tig) and placed it in my materials folder, where all the colours are in a second folder and show as SKM files. It shows as a collection in the paint bucket but it's empty....I've tried a re-start a couple of times but still no joy.... help please 😄
                                          driven
                                          @sally
                                          it should be in your 'User' Materials folder...make one if it's not in this folder...john
                                            John, you're missing a bunch of colors. 😉
                                            • 4 / 5
