    I need help with Fryrender Sketchup...Please Anyone...ahhhhh
    extensions
    15 Posts 5 Posters 3.3k Views 5 Watching
      View your Model in Monochrome - see View>Face_Style at the end of the pop-out list or click the right-hand-most button on its Toolbar.
      I suspect that much/all of your glazing is 'inside out' and it's the 'backs' we are seeing, and although it looks OK in the Model in normal view modes [since it's colored on both sides of the faces] it unfortunately comes out 'black' when it's getting rendered.
      If your 'glass' faces are indeed being looked at from the back then Select them and use right-click context-menu 'Reverse' to flip them the right way round...
      However, I strongly recommend that you also set a shortcut for 'Reverse' - first you must Select a Face and open Window>Preferences>Shortcuts and then Filter for 'Reverse' and then set that to a key or key-combo [e.g. Shift+Q] - this will allow quick reversal of any/all selected faces now and forever thereafter...
      Note that this back_material is often colored 'blue' - but it depends on your current Style's settings - so also check that Style has a contrasting pair of colors for front and back materials, so you can see them clearly in Monochrome - I have a fault finding Style that has the back_material as Magenta - then you definitely see it...
      β˜€
        tbite
        but that's the thing I don't have back faces.
        Before I any of my faces, I always reverse them so that they are all white.
        I don't know what is happening.
        This is the same reason whay I stopped using Indigo.
        This is the Monochrome style like you suggested
        http://img525.imageshack.us/img525/2985/faces.png
          Do you have only the one face making the glass ?
          There's not something else inside is there [even hidden with an off layer] ?
          Can you post the model ? [<=4Mb zipped]
            tbite
            All Glass in the Model is one faced
            Except for the Balcony Glass Which is two Faced.
            Is that the problem?
            I will try post the model without all the extra stuff so that it is 4mb
              tbite
              Here is the Model
              Thanks for your assistance so far.
              I am really grateful.
              Model Attached
                I have looked at it and there is very little wrong with it.
                One or two floor plates are upside down but that should only confuse the rendering in those few levels.
                I don't have your rendering tool but it renders OK in Twilight with everything you'd expect to be transparent - though I did need to adjust the opacity so it was more transparent ~50% v ~80%.
                Sorry but I'm at a loss - any other Fryrenderers out there who might be able to help ???
                There's probably a switch somewhere that makes stuff transparent - what's the opacity of the glass set to ?
                Over to the Fryrender Documentation and Help section I think...............
                http://www.randomcontrol.com/downloads/manuals/fryrender_1.0_user_manual.pdf
                πŸ˜• πŸ˜• πŸ˜•
                  tbite
                  This is what I find strange, it seems few people use Fryrender, even though the quality is far better than many of the render engines I have used.
                  It has a better quality than
                  SU Podium
                  Kerkythea
                  Artlantis
                  Hypershot
                  Indigo
                  IDX Renditioner
                  I haven't used Twilight or a few others
                  but the only ones I can think of with better or equal quality are maybe Maxwell and Vray.
                  **Does anybody here use Indigo? because it is the same issue I had with Indigo
                  I can render double faced (close geometry) glass, but not single faced.**
                    dedmin
                    SU Podium
                    Kerkythea
                    Artlantis
                    Hypershot
                    Indigo
                    IDX Renditioner
                    I'm not sure that Fryrender is better than Indigo. The fryrender's forum is very "proprietary" in my opinion.
                    http://www.indigorenderer.com/forum/viewtopic.php?t=2499
                    Single face with blue glass rendered in Indigo.
                    Pushed 10 mm and applayed Blue glass on the outer faces
                    And it is normal - the faces in SketchUp have zero thickness. In the life there is no such a glass - Fryrender and Indigo are real renders.
                      tbite
                      Thanks.....For that.
                        remus
                        If your going to render single face glass you cant use a normal glass material (as normal glass has thickness.) In indigo theres a specific thin glass material that you need to use: perhaps there's an equivalent in fry?
                          tbite
                          Thanks a lot guys, I now understand it all.
                          Real renderers like Indigo and Fry will not render the faces properly.
                          but I have not been able to find the thin glass equivalent of Indigo.
                          btw I think in Indigo,how do I change the colour of the thin glass
                          I don't think I was ever able to do it.
                            remus
                            I dont know if you can, worth PMing whaat to double check though.
                              cadmunkey
                              tbite, I used to use fryrender. The glass material you need to use for single thickness glass is called "ghost glass". It is one of the default materials, but you can also download variations of it from the material repository.
                                tbite
                                I've figured it out, thanks everyone for the help.
                                In Fryrender I can achieve single glass by using the ghost glass as cadmunkey mentioned.
                                To change the colour of the glass I used layers, it seems everything not basic in fryrender is achieved with layers.
                                If there is such a thing in Indigo I am guessing that is how it would be done as well.
