    Pasting a Logo or Seal to a cylinder
    24 Posts 8 Posters 3.5k Views 8 Watching
    • GaieusG
      That would work but in fact, there is the problem that intersected geometry on a curved surface will distort the surface very ugly. That's what the whole conversation started with.
      • ely862meE
        ely862me
        u can do something else too..pretty fast..
        Make a high texture with the logo in the position u want..import the texture,scale the texture to fit 4 or 5 segments of the cylinder,apply the texture,unsoften the the lateral edges of those 4,5 segments ..scale the original texture for the logo to get out of object range..and apply it to the entire object ..
        All the best!
        Elisei
        ata logo applyed by EliseiDesign.skp
        Elisei (sketchupper)
        Come and See EliseiDesign
          d12dozr
          😳 sorry, I thought it would work, but I didn't try it.
          However, this should work: Stick groups to mesh http://forums.sketchucation.com/viewtopic.php?p=211560#p211560 Just keep the logo a separate group and just far enough away from the cylinder that there is no z-fighting.
          http://goo.gl/f7ooYh
          • W
            wsellers89
            Gentlemen,
            I can't thank you all enough for your help.  This is what I think is tremendous about the SketchUp community.  People willing to take time out of their important day to help others learn from their experience!  Rest assured that I don't typically bother posting questions until I have read, and re-read the books that I have, and the posts on the forum.  Materials and textures are still one of the biggest mysteries to me.
            The suggestions that you all provided were excellent and I was able to paste the logos onto the cylinder as necessary.
            I hope sometime in the future someone can find out what causes the surface "crumpling" when you intersect a logo or stamp with a smooth body, and put together a work around solution.  I have used that technique before to put markings on airplane models (see attached file).  The intersection method was a great suggestion provided by another SketchUp expert and seemed to work well for flat, smooth bodies.  When intersecting logos with rounded engines or fuselages however, the crumpling would sometimes occur.  It is frustrating when it occurs because of the time spent carefully tracing over an intricate logo for intersecting with the body.
            Again, many thanks for your kind comments and suggestions!
            • charly2008C
              charly2008
              Hi Elisei,
              how did you do this "high texture"? In the moment I have no idea how to do it.
              Karlheinz
              • ely862meE
                ely862me
                @charly2008 said:
                Hi Elisei,
                Karlheinz
                Sorry i didn specified that..whatever program u have ,like:paint,photoshop,etc.
                Happy sketching!
                Elisei
                • charly2008C
                  charly2008
                  I've tried it with the logo too. The disortion effect can be minimized. The organic model I've smoothed
                  and the cylinder is made with 48 sectors.
                  • charly2008C
                    charly2008
                    With 96 sectors the disortion effect is no longer recognizable.
                    • GaieusG
                      Although for our eyes, SU seems to use single faces for unlimited number of polygons, I suspect that in the background it in fact triangulates those faces. And when you intersect some curved surfaces, you have no control over the direction of that triangulation/autofold function - thus the ugly effect.
                      This can also be suspected when you try to close the face of some definitely coplanar but rather complex structure and often SU only lets you do it by manual triangulation and then keeps the face even after you delete those coplanar, dividing edges.
                      • W
                        wsellers89
                        Is there a plugin that will take rectangular faces and triangulate them?
                        • massimoM
                          massimo Moderator
                          Here you can find one.
                          • 2 / 2
