    Calling Whaat and Fredo!! new MAC issues (SOLVED)
    94 Posts 19 Posters 25.9k Views 19 Watching
      chrisjk
      (agAin, I'm on a phone so....)
      chris, I guess you are using the correct two profilebuilder files if you can get it to work in the user library.
      Have you tried putting the profilebuilder files in the MacHD library AND removing the user library plugin folder altogether?
      ...(not even an empty folder-- which will still cause certain rubys to break).
      Jeff,
      You are right - thank you. Even an empty plugins folder at the user level is enough to cause things to break. Moving everything over to the top level and deleting the user level folder has worked for me. Now all the tools and icons are there and functioning - great result! I quite thought I had tested this arrangement but I must have become confused by all the shuffling back and forth I have been doing.
      • EdsonE Offline
        Edson
        in fairness i must say that jeff's suggestion has worked for me. i moved all the plugins i had at the user level to the regular plugins folder and removed the extra plugins folder. so far all the plugins are working, even podium which originally installs itself at the user level and booltools.
        http://www.mahfuz.arq.br
          tfdesign
          I've bookmarked this thread, and I'm going to try shifting everything around after I've finished this church visualisation project. But, it all looks very promising, so thanks to everyone for putting all this time in- especially Jeff! 😄
          • W Offline
            Whaat
            @chrisjk said:
            Jeff,
            I have tried installing Profile Builder as you suggest but to no avail - it is not to be seen. The manual makes explicit mention of this "The plugin may NOT work if installed to the following directory: Macintosh HD/Library/Application Support/Google Sketchup 6/SketchUp/Plugins" and although I am using SU7.1 (5803) rather than the version 6 mentioned by WHAAT,it makes no difference. The other plugins you mention will work in either place albeit missing some toolbars/icons or actual tools as in the case of Fredo's BZ tools.
            The key word above is 'may'. The plugin will work if put in the standard HD plugin location (as long as there is no User/plugin folder). At the time I wrote the manual, the best workaround I could think of for this problem was to require all users to install Profile Builder to the Users subfolder.
            Since then, I have found the solution to this problem which was been discussed at length here. The problem is related to the Sketchup.find_support_file("Plugins") method which will not return the HD subfolder if there exists a Users plugins subfolder (I never determined if it was related to the OS version or not...)
            The solution I have found is to not use this method unless you also specify the desired subfolder. For example, if you say Sketchup.find_support_file("Plugins\/ProfileBuilder"), it will return the ProfileBuilder subfolder regardless of where it is installed (as long as it's in one of the $: locations)
            I intend to update ProfileBuilder, SDS, and BoolTools with this fix but I have been dragging my heels a bit (sorry for this...)
            So, to summarize, all my plugins should work if you install them in the standard HD plugins subfolder. However, if you run into a conflict with Podium, put the plugin in the Users plugins subfolder.
              Would be interesting to hear what Sketchup.find_support_file("Plugins") returns on Edison's 10.5 system. As on my 10.4 system it still returned the HD path after installing Podium.
              • EdsonE Offline
                Edson
                /Library/Application Support/Google SketchUp 7/SketchUp/Plugins
                note: i have now all my plugins at the hd level.
                  Ah. Then we need someone else with 10.5/10.6 and User plugins folder to test this.
                  • cmeedC Offline
                    cmeed
                    Can I say a huge Thank you to all those people who have helped this problem go away. I have no user level plugins folder now and everything seems to work. THANK YOU!
                      Jim
                      Holy carp, so Sketchup.find_support_file is not portable?
                      Does that mean I need to look at all the locations stored in $LOAD_PATH to be sure?
                      It does explain some blank toolbar image problems I have on the Mac.
                        If you use that to get the path of your own plugin - use File.dirname(__FILE__) instead. Or possilby File.dirname( File.realpath(__FILE__) ).
                        To find other plugins: yes I think you do.
                          Jim
                          Yes, but File.dirname(__FILE__) does not return a valid path when used in an encrypted file.
                          What is File.realpath?
                            @jim said:
                            Yes, but File.dirname(FILE) does not return a valid path when used in an encrypted file.
                            Really? Never used encrypted files. What do you get in return then?
                            Sorry, I mixed up with PHP. 😳 I meant File.expand_path http://ruby-doc.org/core/classes/File.html#M002540
                            Reason you might want to use that is explained here: http://forums.sketchucation.com/viewtopic.php?f=180&t=26040&st=0&sk=t&sd=a#p224558
                              Jim
                              The File:
                              print "*** file1.rb being loaded..."
                              print __FILE__
                              print File.dirname(__FILE__)
                              print File.dirname(File.expand_path(__FILE__))
                              print "*** Done."
                              Output when not scrambled:
                              c;/Program Files/Google/Google Sketchup 7/Plugins/file1.rb
                              *** Done.
                              Output when scrambled: No idea why the podium path is in there?
                              (eval)
                              c;/Program Files/Google/Google Sketchup 7/Plugins/SU_Podium_V2/plug_in/extensions
                              *** Done.
                                eh? Now that's odd!
                                  driven
                                  sorry if I'm interupting
                                  May not be related, I'm new to ruby scripting, but in trying to figure out why I sometimes have blank tool buttons, I have noticed a couple of things.
                                  if I load a sphere_tool.rb from WebConsole I don't get the icon, but the ruby works
                                  if I use a full 'load' call from WC to Ruby Console using a "Plugins" I get the large icon or "plugins" I get the small icon,
                                  the other thing is they just add into the existing unless I restart in between.
                                  In other cases, depending on the path in the .rb I'm calling, the blank button may or may not work from WC or ConsoleEditor. even if it works load though ruby Console or place in plugins folder. I'll keep tabs on the path in future, to see if it's a type of path causing the issue.
                                  Spare non functional buttons (like I get with TIG's EE toolbar) only appear (on re-start) if left open and horizontal on close, but they go away when moved vertical down a left side
                                  I don't know why or how I'm just poking around to try and learn something...
                                  For what I've been playing around with this seems to be the most reliable path...
                                  @str = Sketchup.get_resource_path("")
                                  are there problems with me using that if I want to share what I make?
                                  observations...
                                  • tbdT Offline
                                    tbd
                                    even if I am not anymore involved in Podium 2 development, I will take a look tomorrow when I get back on my Windows machine.
                                    http://plugins.ro
                                      tfdesign
                                      Thank you TBD. That's very decent of you. 😄
                                      • tbdT Offline
                                        tbd
                                        regarding v2 "odd" behaviour when running scrambled scripts - as .rbs are executed dynamically the FILE returns "." (current directory) which is changed by Podium v2 (renderer.rb) via Dir.chdir.
                                        that's why File.expand_path(FILE) returns .../SU_Podium_V2/plug_in/extensions path
                                        you can try this code:
                                        Dir.chdir "c;/"
                                        puts "*** file1.rb being loaded..."
                                        puts __FILE__
                                        puts File.dirname(__FILE__)
                                        puts File.dirname(File.expand_path(__FILE__))
                                        puts "*** Done."
                                        and you will get back:
                                        (eval)
                                        c;/
                                        *** Done.
                                        http://plugins.ro
                                          dylan
                                          I missed this thread.
                                          Fantastic piece of info about moving rubies and deleting the User level plugins folder on the Mac.
                                          That extra folder has been a pain with rubies in the past.
                                          http://dmdarchitecture.co.uk/
                                            rbrown3rd
                                            Hello everyone. I am a relatively new Sketchup user using a MAC with OSX 10.58 and Sketchup 7.1.6859. I openly admit to be totally lost as to how to install the Bezier Curve plugin. Reading all of this thread has me totally lost. I am running some tools I added for generating CNC files for a foam cutting machine. I am pretty sure I installed those a long time ago as .rb files. Would someone please tell me the easiest way to get a spline tool installed? I need to create some airfoil designs. Thank you very much.
                                            • 4 / 5
