    [Plugin] Proper Animation V1.08 Beta(Updated 14/11/10)
    246 Posts 108 Posters 229.6k Views 108 Watching
      din_wiesel
      Hello
      Proper Animation is such a cool and easy PluIn to animate things in Sketchup.
      But I got a problem with my objects.
      I have a package with numbers of wood piece. In the first position it should lie on the ground.
      In the second position is a 90 degree rotation of the first position.
      But the objects get their own life, you will see it in the video.
      The objects in this animation are Components and Groups
      See the video
      Has anyone a solution for this problem.
      • mariochaM
        mariocha
        I has a similar problem. It was due to not having put the axes of the components at the right spot. Groups are also hard to control, I find, cause they do not have axes that can be set at a specific spot at will. So I make every object to be animated a component and set the axes to the pivot point of the desired rotation.
        %(#008000)[Mario C.
        • K
          KXI System
          Thank you, I have found a great deal of uses for this plugin, and glitches... 😆
          Actually, Sometimes the things I animate when I play then, they disappear! Is this a glitch?
          Getting the perfect sig is hard...
          Google it!
          • mariochaM
            mariocha
            Well, this happens when I forget to close group/component before play or switchin
            Well, this happens when I forget to close group/component before play or switching scene.
            %(#008000)[Mario C.
            • K
              KXI System
              But all my groups are closed, but the easy way for me to fix this is to turn on shadows. But then when I play it the shadows don't move along!
              Help! Help! And Help! 😮 😮 😮 😮 😮 👊
              Google it!
              • mariochaM
                mariocha
                Is it the shadow thing I talk about in my post on page 7 ?
                %(#008000)[Mario C.
                • K
                  KarinaGM
                  Mariocha
                  how do you set the axes to the desired position?
                  **"Aquel que sacrifica un poco de libertad por seguridad, no se merece ninguna y terminará perdiendo ambas"
                  -Benjamín Franklin.**
                  • K
                    KXI System
                    Found a strange glitch when I was trying to animate labica model, here you see:
                    Glitch.skp
                    Google it!
                    • K
                      KXI System
                      Hey-hey, an update!
                      Google it!
                      • B
                        Bradley1234
                        so i tried the plug in and it works. noticed that, using Sketchup v7.1 making the animation frames i needed to set the frames up, stop then restart the plugin for the frames to sync with the regular animation frames.
                        ok so it works; but i exported it to animation with the .AVI extension then tried to import into windows movie maker and it got an error saying the Codec is not found? then could not open it.
                        so Sketchup made an animation but im not able to edit it. Is there a codec that needs to be downloaded?
                        • mariochaM
                          mariocha
                          @karinagm said:
                          Mariocha
                          Right-click on component, Changes axes, then you need to click 3 points ; first the new origin, then 2 along the desired red axis, or first on red and second on green axis.
                          %(#008000)[Mario C.
                            morisdov
                            Hello Bradley,
                            As noted in the documentation and previous posts on this thread, Sketchup can not export the animations in the "standard" way.
                            You have two options:
                            1. quick and dirty - hide the axes and use a screen capture utility while playing the animations
                            2. slow and pretty - use a renderer to save each animation frame and chain those together into a movie - read previous posts - Kerkythea, Twilight ...
                              Jim
                              morisdov,
                              It's also possible to write an image for each frame from the FrameChangeObserver. You would end up with a series of images that can be compiled into an animation using some other software.
                              • B
                                boothy
                                what is and where is the framechangeobserver ?
                                Boothy
                                  @boothy said:
                                  Boothy
                                  Error 404 (Not Found)!!1
                                  (code.google.com)
                                    SouzaRM
                                    @morisdov said:
                                    Hello Bradley,
                                    Remember:
                                    01. The PlugIn SmoothStepAnim.rb is very good (not render) for save picture in picture of the [Proper Animation] and group the images for video (http://groups.google.it/group/Sketchup-Pro/browse_thread/thread/ea575d1bce3d1c97)
                                    02. Post SketchUCation: http://forums.sketchucation.com/viewtopic.php?f=323&t=10946&hilit=Re%3A+Plugin]+proper+animation+for+SketchUp+6+free%2Fpro&start=75#p142979
                                    Re: [Plugin] proper animation - for SketchUp 6 free/pro
                                    PostBy Ecuadorian on Wed Mar 25, 2009 7:55 am
                                    03. Post SketchUCation: http://forums.sketchucation.com/viewtopic.php?f=323&t=10946&hilit=Re%3A+[Plugin]+proper+animation+for+SketchUp+6+free%2Fpro&start=90#p181444
                                    PostBy mariocha on Tue Sep 01, 2009 8:53 am
                                    • B
                                      bnem
                                      Hello,
                                      On advice from the forums I've animated a scene usng "PROPER ANIMATION" and as expected can't export it. I'm using a "SMOOTHSTEP ANIMATION" plug-in to break the scene up into jpgs but how then can I re-assemble the step-by-step images into a movie file? Is there no ruby that lets me export a proper animation?
                                      any help would be appreciated
                                      tks
                                      /ben
                                      • GaieusG
                                        Hi Ben,
                                        Rendering applications very often only export the frames as still images. Later you can assemble these images into an animation using several (free or cheap or expensive) 3rd party programs like VirtualDub for instance. This will also allow you better control over your video quality than if you exported them from SU.
                                          Seems Twilight can render the animations of plugin like Proper Animation
                                            darkhelmet
                                            Okay I gave this a shot but must be missing a whole lot. Spent several hours creating several scenes, all of which contain multiple objects animated with Proper - office equipment coming up through the floor. I installed the Smooth Animation plugin and Virtualdub. All ready to go! Nope. Exported the frames as PNG using Smooth...all static images of each scene - no Proper animation in any of the frames.
                                            What did I do wrong?
                                            CLARIFICATION: The camera is animated but nothing else, basically nothing animated with Proper.
                                            • 12
                                            • 13
                                            • 7 / 13
