    Podium 2 beta 2
    extensions
    30 Posts 11 Posters 4.4k Views 11 Watching
      sepo
      SU Podium V2 beta 2, which is now called Beta34 (because it's the 34th build) has been released.
      Please download it from the same V2 Beta page - http://www.su-podium.com/v2beta/.
      Read about what's new to beta2 here- http://www.su-podium.com/v2beta/info.htm#two.
      A short list would be
      1. Options UI which includes, resolution size options, JPG/PNG/HDR/ format options, environment options including Sketchup background (including SketchUp sky), physical sky option and an option to pick from several presets.
      2. Omni light soft shadows included in the presets.
      3. Sun turbidity are built into the presets as well.
      We expect to release another beta with a short list of new features in two weeks or so. Additional betas will follow the next beta as well.
        chrisjk
        Is there going to be a Mac version?
          sepo
          Yes there will be Mac version once we complete Beta.
            tfdesign
            And will the Mac version installer be fixed too, so Podium doesn't turn off all our plugins all over again?
              sepo
              You keep saying that but we do not have evidence of it.
              • N Offline
                nomeradona
                thanks for the upfate sid. btw your rendering skills using podium has really been up with a new level.
                • jeff hammondJ Offline
                  haha
                  what?
                  there are a few threads on this forum about it and multiple attempts to contact you guys to discuss it with the only response being 'we'll have the mac guy look into it'
                  it's a very real problem and it's not hard at all to see it.. have you even attempted to see what the complaints are about? like on a computer running osx? i know for a fact if you did do that then you would have your evidence.
                  what sort of evidence are you looking for?
                    tfdesign
                    Mate, you are unbelievable! I don't know what I find more insulting, your arrogance or your "I'm spending all of your lovely money by going skiing every weekend" avatar!! πŸ‘Š
                    Jeff is absolutely right. Why don't you just go and look for the evidence- it's right here, right in front of you! I tell you what, I'll hold your hand and guide you to the search field at the top of your browser window. In this window, type; "podium +osx +installer". You then press a button on your keyboard, it's called 'return'! πŸ˜„ you may have to edit your search options a little. You do this by ommiting certain key words such as "installer"- that's if you are having problems. πŸ˜„
                      Sepo: there has been a number of comments here in various threads where users has said that some plugins stopped working. It has appeared to co-relate with Podium installation. When the users uninstalled Podium, or moved Podium to the location Google recommends (/Library/Application Support/Google/Google SketchUp [n]/SketchUp/plugins), they they have reported back that their plugins where functioning again.
                      I'm not a Podium user so I've not experienced it myself - but it's what I've observed in the Plugins forum some time to time.
                        sepo
                        We do not have any complaints on the Podium forum. We have a loads of Mac users and have had some problem with clashing plugins but that is all. Saying that if you have a problem with Podium on Mac please report it to back to our support or post on the Podium forum.
                        "Mate, you are unbelievable! I don't know what I find more insulting, your arrogance or your "I'm spending all of your lovely money by going skiing every weekend" avatar!! "
                        Don't you mate me as your whole reply is patronising and at least vulgar. I find it rather offensive to be talked in a such manner (or lack of it).
                        If you are paying customer report your problem to our support and we will deal with it.
                          sepo
                          Thomas I remember there was some problems but I beleive the problem has been resolved as we do not have any rescent reports of that nature.
                            there aren't any complaints there because podium works just fine with the current installation..
                            the complaints happen here because the installer messes up certain plugins. ("so-and-so plugin doesn't work on mac" etc.)
                            it's a simple fix.
                            the podium installer creates a plugin folder in the wrong directory when it should be placed in the standard plugin folder. having 2 plugin folders in osx sketchup 'confuses(?)' certain plugins and they will no longer work unless you put them in the new plugin folder created by podium.
                            i've manually installed podium in the standard plugin folder and deleted the 2nd folder it creates and everything runs fine.
                            the fix would be a simpler installer so it's not like it's some sort of undertaking to get it correct.. it would actually be less work to do it right.
                            the path thomthom pointed to:
                            is correct except it's missing the main ingredient.. it should be:
                            macintoshHD/library/application support/google sketchup 7/sketchup/plugins
                            that is where the plugin folder is located upon a fresh SU install
                            podium creates a plugin folder at:
                            user/library/application support/google sketchup 7/sketchup/plugins
                            (notice the similarities between the two paths.. there's only a slight difference between the two but it's a major one. i understand how the two can get confused but it should be sorted out)
                              sepo
                              Thanks Jeff . I will pass this to our support and report back.
                              • cmeedC Offline
                                cmeed
                                After lots of head scratching with plugins not working and missing tool bars etc, on finding the SCF thread that solved the problem by removing the plugins folder at user level that podium created was a great relief and a god send. Podium works fine as jeff pointed out when you move that too.
                                Podium is fantastic and i thought that i'd link this god send on the podium forum. So I did point out this to the podium people fairly recently (not to the team directly). Also in doing that i asked podium people if i would get any problems. 0 replys and 97 people looked.
                                podium V2 looks really good and exciting. i love using 1.7 and will be wanting to download the V2 mac beta when its ready. But, i will want to know about installation, because it was podium I'm afraid that was causing the problems. all plugins working after taking the advice of people here. Still Love podium.
                                  sepo
                                  Thanks Cmeed. This is quite interesting. I have forwarded this info to Dave from Cadalog. I was told that we had only one official report of problem in more than thousands of registered Mac Podium users. He told me also that he himself tested it on 3 macs in the office without any problem. Now, I am not saying anything with certainity but could it be that there is also some other plugin which contributes to this problem.
                                  Dave has promissed that we will look at installer again and see what could be done. This is as much as I could report for now.
                                    Would it help with links to some of the threads where this has been discussed?
                                    • cmeedC Offline
                                      cmeed
                                      You may well be right. But, over the last 4 years of using sketchup I've wanted more out of it and increasingly plugins give me that chance like podium and the fredos et al of this world. So over time there maybe a conflict maybe?. I use alot of plugins, mainly the one seen in the visual index. but also more.
                                      Maybe the majority Mac users of podium don't have as many and don't get conflicts. Podium has always worked fine no matter where you place it. So the line of inquiry starts with us questioning the plugins not working and finding an answer. Certainly the people here that have responded 'passionately' use plugins alot like me. Therefore we have problems and voice them here. luckily for me these are clever people and have sorted a resolution.
                                      My question is - is there a point to having a user level plugins folder? will i get any problems?
                                      everything works now i have deleted the user level folder and placed podium in HD.
                                      • cmeedC Offline
                                        cmeed
                                        this explained everthing for me - it VERRRY long but i hope this cuts to the chase
                                        I posted this to su podium forum
                                        http://forums.sketchucation.com/viewtopic.php?f=180&t=15182&st=0&sk=t&sd=a&start=60
                                          http://forums.sketchucation.com/viewtopic.php?f=180&t=15182&st=0&sk=t&sd=a&start=60#p208998
                                          @whaat said:
                                          Since then, I have found the solution to this problem which was been discussed at length here. The problem is related to the Sketchup.find_support_file("Plugins") method which will not return the HD subfolder if there exists a Users plugins subfolder
                                            sepo
                                            OK I have reported all of this back. I will inform you of the outcome. Thanks.
