    [Plugin] Slicer v4.3 20110619
    102 Posts 20 Posters 145.0k Views 20 Watching
    • mariochaM Offline
      mariocha
      Thanks for the prefix.rb
      Thought I find it difficult to integrate to the process since each text is a group, in a group.
      For now, I use component numbers made of lines.
      Hum... that v4, is it close to release ?
      Need some testing ?
      I do think it is worth some money.
      %(#008000)[Mario C.
        The prefixtext ruby should 'mine down' into any groups selected and add to all text. It undoes in one step anyway... πŸ˜•
          kwalkerman
          I'm interested in using the slicer plugin. I'm using the trial version of Sketchup Pro 7.1, and have downloaded Slicer31.rb. Whenever I try to use the plugin, Sketchup crashes. Any help is appreciated.
          Karen
          • X Offline
            xrok1
            I have a [privately written and hopefully paid for] 'Slicer v4' that has such lines added etc for CNC work - watch this space.
            hey, are you finally going to make your own and bust that slicemodeler @&&hole
              @kwalkerman said:
              Karen
              First try testing it on a simple group and make a modest number of slices - say 10...
              When you get the hang of what it does you can then up the 'fineness' of the slicing... BUT be patient...
              If you try to make hundreds of slices it will take a while and it sometimes 'whites-out' and appears to stall... BUT it will usually complete if you leave it for a while...
              πŸ€“
                I have written a paid commercial version [private] - Slicer_v4 - for someone for CNC use etc... it [or some of its ideas] might leak out to you too... πŸ˜‰
                • X Offline
                  xrok1
                  awsome! β˜€
                    kwalkerman
                    Thanks for the response. I have tried the slicer on a simple block, and only requested a few slices, but sketckup crashes completely and closes after it asks whether to add numbers to the slices. Anyone else have this issue?
                    Thanks.
                      A mystery...
                      Your details please:
                      Platform & OS
                      SUp version
                      Version of Slicer [open file with Notepad and read first section...]
                      Other plugins loaded [only anything unusual?]
                      Can you upload a simple skp that you have the problem with and a description of what failed - e.g. Z axis, 12" c/c etc...
                      It usually works painlessly for most users... πŸ˜•
                      • mariochaM Offline
                        mariocha
                        @tig said:
                        @xrok1 said:
                        Slicer_v4 - ... it [or some of its ideas] might leak out to you too... πŸ˜‰
                        So as to plan my work, is there a time estimate ?
                        %(#008000)[Mario C.
                        • E Offline
                          eco_artbarn
                          hey I have been looking for this for ages to help my pupils with our laser cutter but i have been trying to down load slicer 3.1rb but i cant work out where to put the text version.
                          is there a slicer 3.1.rb file that i can just save and load into plugins folder?
                          cheers
                            http://forums.sketchucation.com/viewtopic.php?p=16697#p16697
                            Save the linked file as Slicer31.rb into the Plugins folder - done...
                            If your browser insists on making it another file type you can always use Select All on the page and paste it into a new empty plain text file and rename it with a .rb suffix NOT .txt ...
                            • mariochaM Offline
                              mariocha
                              In our work, we often deal with terrains modeled as surfaces, not volumes, often very irregular. Making a volume out of them is sometimes quite hard, even with Joint Push-Pull.
                              Is there a "slicer" that can make slices from a surface ? Slices would then be only segments. πŸ˜„
                              %(#008000)[Mario C.
                                To give a meshed surface a volume requires a bit of planning...
                                You select all of the perimeter edges.
                                Then use my tool ExtrudeEdgesByVector to extrude all of these edges vertically downwards (-ve Z / blue) far neyond the lowest one.
                                Check that the faces are 'outwards'.
                                Leave the extrusion in its group for now.
                                Edit the group and draw a large flat rectangular plane facing down [reverse if necessay] located below the geometry, but so that it intersects with ALL of these new vertical faces.
                                Select All inside the group and 'Intersect with Selected'.
                                Erase the unwanted bits of the rectangle and change your view so you can easily 'select by fence' the bits of the vertical faces below it - delete them.
                                Close the group-edit and select all of the mesh and Edit-Copy.
                                Edit the group again and Edit>PasteInPlace
                                Now you have a 3D volume with the top as a mesh...
                                Move it to one side or copy the group and paste it into an empty model - and you can Volume or Slice, or whatever you need to do...
                                If you have two meshes - e.g. existing and proposed land surfaces - you can do a 'cut and fill' volume etc by intersecting them together and making a groups of what's left - there's a tutorial on that somewhere...
                                β˜€
                                • E Offline
                                  eco_artbarn
                                  Thanks TIG that works a treat.
                                  i am sure i have seen a slicer tutorial before where it adds the slots half way up and half way down, is there a way of doing that with 3.1?
                                  i slice in the x and then sllice in the y and lay the sections out flat, but if there was a way of adding the midway slots that would be a huge advantage
                                  let me know cheers ash
                                  • E Offline
                                    eco_artbarn
                                    cool, when's it gonna be ready to unleash on us?
                                    • mariochaM Offline
                                      mariocha
                                      Tig, I have tried your method to give a volume to a mesh surface. Not bad. But not it, for us.
                                      Having to do all these extrusion just kills the gain. (btw I used the term terrain where I should have used cliff and hill sides.)
                                      What we need is to replace our manual process of generating slice from the meshes, group&number them, and offset to get rib (& face) for cnc.
                                      Or maybe just a rb to make numbered groups of our slice lines and then flattened copies ? πŸ˜„
                                      %(#008000)[Mario C.
                                        mariocha - I don't fully follow you...
                                        To work out Volumes there are Volume Tools - Slicer is a different thing ?
                                          There is a paid script SliceModeller that I unwittingly helped develop !
                                          That adds slots to the slices... Slicerv4 might do that too... πŸ˜‰
                                          • mariochaM Offline
                                            mariocha
                                            Sorry, I meant
                                            Slicer only works on volumes, so you suggested to make volumes out of our meshes (with ExtrudeEdgesBy Vector).
                                            We would like to automate mesh slicing to rib. πŸ˜„
                                            (giving an offset value to make the face)
                                            %(#008000)[Mario C.
                                            • 1 / 6
