    [Plugin] Slicer v4.3 20110619
    102 Posts 20 Posters 145.6k Views 20 Watching
    • jujuJ Offline
      juju
      I get this error message with Slicer.rb (version 3.0), see image attached.
      http://www.sketchucation.com/forums/scf/sas/Ruby/slicererror.JPG
        [attachment=1:1k4woufo]<!-- ia1 -->slicer error.JPG<!-- ia1 -->[/attachment:1k4woufo]
        I apologise. I uploaded a version that's customized to my menu setup by mistake ! Of the 40 or so who've viewed it so far you are the only one to point it out... Here's v3.1 that's fixed to suit all.
          seasdes
          Thank you TIG for another useful script
          Walter
          Using Sketchup Pro 2019
          • N Offline
            not registered yet
            Thanks so much for the new version - works great! I'm using it similarly to the original purpose TIG mentioned, as a cheap 3D printer. Now to create a (cheap) automated way to cut them out!
            best,
            Matt
            [mattratto]
            • mariochaM Offline
              mariocha
              Very impressive !
              And so usefull .
              Thanks a million !
              The final touch, for the cutting machine (cnc), would be numbers as lines so it can engrave them on the piece.
              Oh and also the possibility to add a letter before the number, like A1, A2, .. B1, B2 ...
              Great plugin. !
              %(#008000)[Mario C.
                @mariocha said:
                Very impressive !
                And so usefull .
                Thanks a million !
                Great plugin. !
                I have a [privately written and hopefully paid for] 'Slicer v4' that has such lines added etc for CNC work - watch this space.
                Here is a script that will add a prefix for you...
                Put into Plugins folder...
                Adds a Prefix to selected text or text inside selected group/instance-definitions
                To use - select the objects needing prefixes [text OR groups containing text etc]
                then in the Ruby Console type prefixtext + <enter>.
                A dialog asks for the Prefix Text - enter it and OK - e.g. A.
                All text in the selection is prefixed with the desired prefix e.g. 9 becomes A9 etc...
                It is for use after running tools like Slicer
                • where sub-sets of slices might be more useful if they are differently coded.
                  Errors will stop you if there is no selection or you enter a blank 'prefix'.
                  It is one step un-doable.
                  πŸ€“
                • mariochaM Offline
                  mariocha
                  Thanks for the prefix.rb
                  Thought I find it difficult to integrate to the process since each text is a group, in a group.
                  For now, I use component numbers made of lines.
                  Hum... that v4, is it close to release ?
                  Need some testing ?
                  I do think it is worth some money.
                  %(#008000)[Mario C.
                    The prefixtext ruby should 'mine down' into any groups selected and add to all text. It undoes in one step anyway... πŸ˜•
                      kwalkerman
                      I'm interested in using the slicer plugin. I'm using the trial version of Sketchup Pro 7.1, and have downloaded Slicer31.rb. Whenever I try to use the plugin, Sketchup crashes. Any help is appreciated.
                      Karen
                      • X Offline
                        xrok1
                        hey, are you finally going to make your own and bust that slicemodeler @&&hole
                          @kwalkerman said:
                          Karen
                          First try testing it on a simple group and make a modest number of slices - say 10...
                          When you get the hang of what it does you can then up the 'fineness' of the slicing... BUT be patient...
                          If you try to make hundreds of slices it will take a while and it sometimes 'whites-out' and appears to stall... BUT it will usually complete if you leave it for a while...
                          πŸ€“
                            I have written a paid commercial version [private] - Slicer_v4 - for someone for CNC use etc... it [or some of its ideas] might leak out to you too... πŸ˜‰
                            • X Offline
                              xrok1
                              awsome! β˜€
                                kwalkerman
                                Thanks for the response. I have tried the slicer on a simple block, and only requested a few slices, but sketckup crashes completely and closes after it asks whether to add numbers to the slices. Anyone else have this issue?
                                Thanks.
                                  A mystery...
                                  Your details please:
                                  Platform & OS
                                  SUp version
                                  Version of Slicer [open file with Notepad and read first section...]
                                  Other plugins loaded [only anything unusual?]
                                  Can you upload a simple skp that you have the problem with and a description of what failed - e.g. Z axis, 12" c/c etc...
                                  It usually works painlessly for most users... πŸ˜•
                                  • mariochaM Offline
                                    mariocha
                                    @tig said:
                                    @xrok1 said:
                                    Slicer_v4 - ... it [or some of its ideas] might leak out to you too... πŸ˜‰
                                    So as to plan my work, is there a time estimate ?
                                    %(#008000)[Mario C.
                                    • E Offline
                                      eco_artbarn
                                      hey I have been looking for this for ages to help my pupils with our laser cutter but i have been trying to down load slicer 3.1rb but i cant work out where to put the text version.
                                      is there a slicer 3.1.rb file that i can just save and load into plugins folder?
                                      cheers
                                        http://forums.sketchucation.com/viewtopic.php?p=16697#p16697
                                        Save the linked file as Slicer31.rb into the Plugins folder - done...
                                        If your browser insists on making it another file type you can always use Select All on the page and paste it into a new empty plain text file and rename it with a .rb suffix NOT .txt ...
                                        • mariochaM Offline
                                          mariocha
                                          In our work, we often deal with terrains modeled as surfaces, not volumes, often very irregular. Making a volume out of them is sometimes quite hard, even with Joint Push-Pull.
                                          Is there a "slicer" that can make slices from a surface ? Slices would then be only segments. πŸ˜„
                                          %(#008000)[Mario C.
                                            To give a meshed surface a volume requires a bit of planning...
                                            You select all of the perimeter edges.
                                            Then use my tool ExtrudeEdgesByVector to extrude all of these edges vertically downwards (-ve Z / blue) far neyond the lowest one.
                                            Check that the faces are 'outwards'.
                                            Leave the extrusion in its group for now.
                                            Edit the group and draw a large flat rectangular plane facing down [reverse if necessay] located below the geometry, but so that it intersects with ALL of these new vertical faces.
                                            Select All inside the group and 'Intersect with Selected'.
                                            Erase the unwanted bits of the rectangle and change your view so you can easily 'select by fence' the bits of the vertical faces below it - delete them.
                                            Close the group-edit and select all of the mesh and Edit-Copy.
                                            Edit the group again and Edit>PasteInPlace
                                            Now you have a 3D volume with the top as a mesh...
                                            Move it to one side or copy the group and paste it into an empty model - and you can Volume or Slice, or whatever you need to do...
                                            If you have two meshes - e.g. existing and proposed land surfaces - you can do a 'cut and fill' volume etc by intersecting them together and making a groups of what's left - there's a tutorial on that somewhere...
                                            β˜€
                                            • 1 / 6
