    [Plugin] Slicer v4.3 20110619
    102 Posts 20 Posters 149.4k Views 20 Watching
      A mystery...
      Your details please:
      Platform & OS
      SUp version
      Version of Slicer [open file with Notepad and read first section...]
      Other plugins loaded [only anything unusual?]
      Can you upload a simple skp that you have the problem with and a description of what failed - e.g. Z axis, 12" c/c etc...
      It usually works painlessly for most users... πŸ˜•
      • mariochaM Offline
        mariocha
        @tig said:
        @xrok1 said:
        Slicer_v4 - ... it [or some of its ideas] might leak out to you too... πŸ˜‰
        So as to plan my work, is there a time estimate ?
        %(#008000)[Mario C.
        • E Offline
          eco_artbarn
          hey I have been looking for this for ages to help my pupils with our laser cutter but i have been trying to down load slicer 3.1rb but i cant work out where to put the text version.
          is there a slicer 3.1.rb file that i can just save and load into plugins folder?
          cheers
            http://forums.sketchucation.com/viewtopic.php?p=16697#p16697
            Save the linked file as Slicer31.rb into the Plugins folder - done...
            If your browser insists on making it another file type you can always use Select All on the page and paste it into a new empty plain text file and rename it with a .rb suffix NOT .txt ...
            • mariochaM Offline
              mariocha
              In our work, we often deal with terrains modeled as surfaces, not volumes, often very irregular. Making a volume out of them is sometimes quite hard, even with Joint Push-Pull.
              Is there a "slicer" that can make slices from a surface ? Slices would then be only segments. πŸ˜„
              %(#008000)[Mario C.
                To give a meshed surface a volume requires a bit of planning...
                You select all of the perimeter edges.
                Then use my tool ExtrudeEdgesByVector to extrude all of these edges vertically downwards (-ve Z / blue) far neyond the lowest one.
                Check that the faces are 'outwards'.
                Leave the extrusion in its group for now.
                Edit the group and draw a large flat rectangular plane facing down [reverse if necessay] located below the geometry, but so that it intersects with ALL of these new vertical faces.
                Select All inside the group and 'Intersect with Selected'.
                Erase the unwanted bits of the rectangle and change your view so you can easily 'select by fence' the bits of the vertical faces below it - delete them.
                Close the group-edit and select all of the mesh and Edit-Copy.
                Edit the group again and Edit>PasteInPlace
                Now you have a 3D volume with the top as a mesh...
                Move it to one side or copy the group and paste it into an empty model - and you can Volume or Slice, or whatever you need to do...
                If you have two meshes - e.g. existing and proposed land surfaces - you can do a 'cut and fill' volume etc by intersecting them together and making a groups of what's left - there's a tutorial on that somewhere...
                β˜€
                • E Offline
                  eco_artbarn
                  Thanks TIG that works a treat.
                  i am sure i have seen a slicer tutorial before where it adds the slots half way up and half way down, is there a way of doing that with 3.1?
                  i slice in the x and then sllice in the y and lay the sections out flat, but if there was a way of adding the midway slots that would be a huge advantage
                  let me know cheers ash
                  • E Offline
                    eco_artbarn
                    cool, when's it gonna be ready to unleash on us?
                    • mariochaM Offline
                      mariocha
                      Tig, I have tried your method to give a volume to a mesh surface. Not bad. But not it, for us.
                      Having to do all these extrusion just kills the gain. (btw I used the term terrain where I should have used cliff and hill sides.)
                      What we need is to replace our manual process of generating slice from the meshes, group&number them, and offset to get rib (& face) for cnc.
                      Or maybe just a rb to make numbered groups of our slice lines and then flattened copies ? πŸ˜„
                      %(#008000)[Mario C.
                        mariocha - I don't fully follow you...
                        To work out Volumes there are Volume Tools - Slicer is a different thing ?
                          There is a paid script SliceModeller that I unwittingly helped develop !
                          That adds slots to the slices... Slicerv4 might do that too... πŸ˜‰
                          • mariochaM Offline
                            mariocha
                            Sorry, I meant
                            Slicer only works on volumes, so you suggested to make volumes out of our meshes (with ExtrudeEdgesBy Vector).
                            We would like to automate mesh slicing to rib. πŸ˜„
                            (giving an offset value to make the face)
                            %(#008000)[Mario C.
                              Wouldn't it be quicker to make the 'curtain' and then use JointPushPull on it to give it a Volume then Slice it ?
                              Or are you looking for a Slice at Nodes option ?
                              Can you give a before and after example, with steps so I can understand your issues better... πŸ˜•
                              • mariochaM Offline
                                mariocha
                                Indeed we tried with JPP. And we use it on simple meshes before Slicer. But often the mesh is too complicated, with acute angles, JPP results in a mess then. So an offset has to be done after the slicing.
                                But I realise that the overlaps that Offset often do are going to be a problem that will need manual work anyway.
                                So we only need the part of the script that generates the slices, numbers and flattens them, like #16.
                                %(#008000)[Mario C.
                                  So if I understand correctly, you want a version of Slicer that can make slices through a '2D-mesh' - a 'curtain' of faces [that have no 3D values in plan - or the equivalent 'other' dimension] - and then represent these as group of lines forming 2D slices laid out on plan. I assume that you don't want any 'thickness' to these 'slices' as they are initially 'lines' anyway ?
                                  Are these always in plan ?
                                  If so there already is my ContourMaker ?
                                  I see you seem to 'make faces' of the results - this could be added as an auto-offset by a desired distance of the lines closed into a face...
                                  What is the exact use of these later on ? CNC work ?
                                  • mariochaM Offline
                                    mariocha
                                    Yes Sir TIG, you got it right.
                                    But these overlaps Offset creates (when some lines are shorter than the offset distance, I think) are going to be impossible to handle automatically, no?
                                    %(#008000)[Mario C.
                                      Watch this space...
                                      Do you want to always cut in Z - it's easier that if I have to make XYZ versions ???
                                          So the 'ribs' are vertical.
                                          How do you determine there rotation about the Z axis ?
                                          By axis X/Y or by Node angle bisector etc ?
                                          It is easy enough to make the closing edges 'horizontal'...
                                          πŸ€“
                                          • mariochaM Offline
                                            mariocha
                                            Great.
                                            My sections are always standing up. But at any angle on xy plane.
                                            Oh, and the top and bottom level have to stay the same if a face is created. Offset tends to change these if the initial top or bottom lines are slanted, as you know.
                                            %(#008000)[Mario C.
                                            • 2 / 6
