    Which CAD program?
    39 Posts 18 Posters 8.6k Views 18 Watching
    • jim smithJ
      jim smith
      I teach part time at a local university and get the chance to play around with a lot of software. ArchiCad and Revit are fully integrated 2d-3d programs with a lot of horse power, large learning curve and are very costly. They give great results and provide a wealth of data but require a lot of input work. The company I work for has looked into Revit, but none of the engineering consultants we use are into it. The program makes more sense in a large company where all disciplines are on the program and makes more sence for larger projects. I think for a small start up firm it may work for you being a Revit specialist and hire out that way. If you will be doing smaller commercial/residential buildings,using Revit/ArchiCad will be killing ants with a hammer (IMHO)
      I have been using sketchup and autocad together sucesfully, not really BIM but we do 3,000 to 10,000 sq. ft. buildings- mostly one or two stories. We use Autocad as do all of our consultants.
      Autocad isn't cheap either. Some compatable alternates to Autocad have been mentioned here. If you have time try some 30 day trials. One that I have found may have great potential is Double Cad XT. They have a free version and the pro version is feature laden, very compatable with autocad and they company has tutorials on using sketchup with Double Cad. Really worth looking at.
      Good luck in starting you new venture - it is an exciting time. Keep in touch about what you find!!! β˜€
      "Out of clutter find simplicity,
      from discord find harmony,
      In the middle of difficulty lies opportunity"
      Albert Einstein
      • pmolsonP
        pmolson
        Hi Lene,
        I am proficient in the following CAD, B.I.M., & modeling programs.
        AutoCad (cad program)
        Revit (B.I.M.)
        Cheif Architect (B.I.M.
        Archicad (B.I.M.)
        Sketchup πŸ˜„ (Fun 3d modeling Program)
        Based on the description you provided of the work you are doing I would not recommend
        a B.I.M. program.
        B.I.M.
        They are very costly, have a large learning curve and require
        a steadfast diligence in maintaining modeling standards if they are to be useful.
        Larger companies that can devote a cad managers time to keeping these large animals
        under control can benefit from the process, but I have yet to see smaller companies
        use the programs to there full extent. Many times they end up just being very expensive
        cad programs. I currently am employed by a company that uses Archicad.
        If you were going to go with a B.I.M Program you should take a hard look at Chief Architect.
        Residential based, relatively inexpensive, & pretty darn easy to use.
        CAD
        If you often share dwg files and you are using SU for modeling than it seems to
        make since to go the Autocad route.
        It is a very good drafting tool. It also has the benefit of
        being very possibly the most used program out there.
        I would not be surprised to see a Sketchup inti-graded cad program pop up before too long.
        Wouldn't that be wonderful!
        Good luck, & keep it simple.
        p
        • B
          blair
          If Chief Architect is a consideration also take a look at SoftPLAN which you may find to be as good or better.
          • sketch3d.deS
            sketch3d.de
            @pmolson said:
            keep it simple.
            recommending AC?
            btw:
            @lene_iacobe said:
            ...but I’m a whole hearted Mac person, so I’m looking for a program for Mac.
            N.
            • utilerU
              utiler
              I used Chief Architect for some years since V7 but went away from it after V9 because it was too rigid. I needed a program that was as flexible as possible and one that could integrate with SU.....
              So I chose Spirit STI http://www.softtech.com
              Even though there doesn't seem to be much on the website, the program integrates with SU both ways and is quite easy to get around.....
              EDIT: I see you use MAC, Spirit is a windows based program if you're happy to partition you HD...
              Just Curious...
              • T
                tfdesign
                Q; When is a Mac (not "MAC"!!! 😑 ), not a Mac?
                A; When it is booting into Windows!!!
                It makes sense (it really does!), if you are going down the route of Windows, then get a PC, and NOT a Mac!! It is a complete waste of money, time and effort to use Bootcamp. It is better, and more efficient, to have both machines running side-by-side.
                πŸ˜„
                • utilerU
                  utiler
                  Sounds like you love your Mac, MAC? πŸ˜‰
                  Just Curious...
                    rabbit
                    Well, all this shows is that lots of people use lots of different CAD programs....
                    But, i think you should have a look at rhino - not only is it an amazing 3D nurbs modeller, but its 2D toolset is very very good - you can download V4 and use it as long as you like - it just stops saving after 25 saves.
                    McNeel is a great company (similar in some ways to the @last company that developed sketchup) - their rhino forum is extremely helpful, and the developers are always on there. Its autocad translation is extremely good, and always up to date, and it is a lot easier to use than autocad.
                    it also compliments Sketchup very well, reads and writes sketchup files, and can do all sorts of curvy stuff that sktchup is hopeless at - the two programs together are all i need for sure, and i think you could do a lot worse (like vectorworks & doublecad for example, which in my opinion are horrible programs)
                    Rhino 4 and the beta V5 (which you can download and use once you have purchased V4) are PC only, but also in beta, which you can download and use for free, is a mac version. this will be due for release sometime after V5 for the PC is released, which will likely be towards the latter part of 2010.
                    Also, at $995.00 it is a bargain...no subscriptions etc..
                    Finally, it is not a silly idea to use bootcamp on a MAC at all; in fact a lot of people use MAC's without ever using the mac os at all - this is because the Mac hardware and build quality is very good compared to many other, espically laptop, companies.
                    cheers
                    rabbit
                    • T
                      tfdesign
                      Yes, Apple hardware is fairly well built- this Macbook Pro has been on 24/7 for the last 4 years- and it is still working (unlike my shite HP laptop, which both PSU and hard drive and screen have already died, having said that, the DVD writer has been playing up a bit recently), but then if I had bought say a Sony Vaio, that too would still be working. But a Sony is cheaper than an Apple. You buy an Apple for it's operating system- Mac OSX!! It's madness to buy a Mac just to run Windows- you, if only to run windows, are simply buying it for a 'pose', because the glowing Apple logo against the silver backdrop says "Look at me. I'm a creative kind of guy"! "Look, I'm... err,.... running Windows 😳 "!!! 😲 πŸ˜† πŸ˜† πŸ˜†
                      Rabbit, I'm sorry for being so pernickety, but why do you (and all other guilty parties) keep writing "Mac" as "MAC"? I'm completely confused. πŸ˜• "Mac" is an abbreviation of "Macintosh". MAC is something completely different. ie "MAC address"- which, btw, Macintosh also posses. Where is the emoticon for banging one's head against the table??! πŸ˜†
                      Can anyone please tell me why they always use MAC rather than Mac? ❓
                      And yes, you are right, Rhino is very good, and I really respect McNeel for getting the application right before release πŸ˜„
                      Tom
                        rabbit
                        Hmmm... Tom, what are you smoking in that pipe...?
                        mac, Mac, MAC....whatever, never thought about it, no doubt you are right.
                        I think really that , when you say your macbbook pro has been chugging it out for the last four years 24/7 then that just supports my case. you say a sony would still be working also, - who knows? maybe it would.
                        Between us my partner and I currently have four laptops - two acers, one hp, and one mac.
                        The oldest is a acer travelmate, that finally stopped working after about about 8 years.
                        The other acer is still going after about four years, the macbook is great after about 2.5 years, and the hp, which was the most expensive and highest spec, has ongoing problems after less than two years - the power supply died, now the screen has died (a known problem apparantly, and not worth the money to repair)
                        So now i need a new laptop that can run windows 7 64 bit, and really only Dell and the mac are in the running (sony has nothing with the same spec) - the mac has no numeric keypad, but is $200 cheaper than the dell, and about 1 kilo lighter (plus it also comes with the mac os). The dell has a faster processor, a slightly better video card, and all the other stuff is the same spec.
                        So it is a no-brainer really to go with the mac - it is just so much better in terms of build and design, and i fully expect it to be around in another 4,6 years...
                        And when rhino for the mac is up to speed, then maybe i will switch to the mac os for good...
                        I couldn't give a toss about the apple logo, or apple posey stuff - I just want to do my job, without the hassle and downtime of the hardware dropping the ball...
                        cheers
                        rabbit
                        • H
                          Howard leslie
                          Lene,
                          If you're starting your own BUSINESS, the answer to me is simple - go the Autocad route.
                          Get a NEW copy of Autocad LT OR if you can find one, an older FULL version of Autocad - but don't go below Autocad version 2000.
                          If you can find a copy of Autocad 2000 - great.
                          You can download a plugin from SolidWorks that allows you to open / save any Autocad version - works well. (This enables you to open Autocad 2003 dwg files with Autocad 2000 for example).
                          Autocad is the 800 LB Gorilla that sits in the corner that you can't ignore.
                          (as quoted many times on this Forum)
                          Its the most popular CAD program in the World. (doesn't mean its the best).
                          It also works really well, back and forth with SU - especially if you have SU Pro.
                          Chances are you're clients will want data in Autocad format. (dwg / dxf 2d / 3d)
                          The only way to know FOR SURE that any data you produce is compatible - is to actually have Autocad.
                          The clones are OK, but... they aren't always perfect.
                          Much better to spend a bit now - and keep your clients happy - not good to lose them.
                          Keep your clients happy and your business will grow.
                          (speculate to accumulate !!!)
                          Hope this helps
                          Howard L'
                          • T
                            tfdesign
                            Howard, I'm sorry, but that's nonsense about AutoCAD. that's exactly the kind of marketing BS that Autodesk would love everyone to believe! I have no problem whatsoever opening and exporting DWG files to and fro from AutoCAD to Highdesign for example (and on a Mac!). Yet HighDesign costs a fraction of the price of Acad LT. Hell, I even fooled my lecturers at university into believing that I'd used ACAD, when in fact I used a Β£13 shareware application called QCad to do the drawings- I still got an A!!
                            Don't believe the hype! Make a profit, not a loss!!! πŸ˜„
                            • utilerU
                              utiler
                              @rabbit said:
                              mac, Mac, MAC....whatever, never thought about it, no doubt you are right.rabbit
                              I am one who is guilty of writing Mac as MAC....... Mac ShMac I say....
                              Just Curious...
                              • T
                                tfdesign
                                Smoking? Mac OSX of course! it's hot shit dude! πŸ˜„ πŸ˜„
                                I used to smoke (both tobacco and occasionally, funny tobacco). When I reached 40, I quit. I could perhaps do with a smoke these days- as it might calm me down a bit? (in case you hadn't already noticed!?! πŸ˜‰ πŸ˜† πŸ˜„
                                • AnssiA
                                  Anssi
                                  @lene_iacobe said:
                                  Hi there!
                                  In short my work is space design for companies. I look at the space available, give advice on how to use it in the best way, with regards for knowledge sharing, etc.
                                  A normal job would include me getting dwg files of the space; moving same walls, maybe putting in a kitchenette, etc. Never any real housebuilding.
                                  I then do the interior decorating in 2D, make sure there’s enough room for everybody working there etc.
                                  For the presentation I show the overall view in 2D, some details in 3D, and then reference photos of the furniture etc. This I do in InDesign.
                                  My clients normally use AutoCad.
                                  To return to the original topic, I would guess that you would be able to do most of your work with SU, especially if your projects do not require the management of large amouts of space and construction data. For this kind of projects, even the CD-s could perhaps very well be produced with SU/Layout.
                                  So am I right in assuming that your CAD needs would be mainly determined by needs to communicate with engineers or other consultants? In these cases following standards is the essential requirement, and the default exchange medium is still DWG files - things like IFC are still not in very general use.
                                  For professional work, I would recommend standard solutions. If you choose to use a PC, take AutoCad LT, the full thing is ridiculously expensive for what you want to do. I do not know about Mac CAD solutions, but I understand that Vectorworks is something like a standard, and handles DWG decently.
                                  My 2 cents
                                  Anssi
                                  • C
                                    cadward
                                    I have to agree with Anssi...Go with AutoCad LT or 100% dwg compatable clone for use with PC. Vectorworks seems like a good choice for Mac...but I do not have that much experience with it., and it is also not cheap.
                                    I have licenses for AutoCad 2010, AutoCad Architecture 2010, and Revit 2008 ...and almost all of the 2D projects could be done with AutoCad LT.....2 of the past architectural firms I've worked for used AutoCad LT, and produced projects varying from Residential, Multi Family Housing, Retail & Medical Office Bldgs, Warehouses and Adaptive Re-use. Great way to start a business for PC based CAD work. The Dwg format is by far the most requested format for information transfer with a client or contractor. Get a trial copy of LT and some of the clones available and check test for yourself. Its also easier to find AutoCad trained help when you need to hire help.
                                    Good Luck
                                    • T
                                      tfdesign
                                      That's absolutely true, and I cannot deny that one bit, BUT, AutoCAD LT does not run on a Mac, without Windows installed!
                                      But why again, are we having even more suggestions from people who haven't had any experience of other platforms apart from PC's, even though the original demand was for that of a Mac based system?
                                      Right. Okay. Here goes. The hard sell.
                                      It is rather unfortunate that developers such as Engineered Software's PowerCADD 8, which is also fully compliant with the DWG/DXF format, and built 100% for OSX only, is pushed out of existence for the likes of Autodesk et al. Read the testimonials, try the demo, try Wildtools set, which make sketching in 2D fun!
                                      I've experience of self inflicted alopecia, trying to get AutoCAD Architectural Desktop (LT's bigger brother) to sketch a simple helix. Further adding insult to injury to then taper that same helix, I threw in the towel. Wildtools within PowerCadd are an extremely powerful set of tools (I know, as I used PC7 before I did my degree) that allows you to do just that, amongst many other things of course, with ease.
                                      http://www.seqair.com/WildTools/WT3D/Helix/Helix3.gif
                                      http://www.seqair.com/WildTools/WT3D/Helix/Helix5.gif
                                      http://www.seqair.com/WildTools/WT3D/ParOff/ParOff8.gif
                                      Here is a list of many of the other functions available within PC8 while using WildTools;
                                      (www.seqair.com)
                                      Here's a list of what other architects and engineers have to say;
                                      (www.seqair.com)
                                      And lastly, I suppose that's almost it. Ultimately of course Lene, it is up to you. I too run my own business, and I have chosen to use Mac exclusively. Admittedly I do also own two PC's, but I am constantly frustrated at how developers for Windows don't always stick to standards, and when updates come, you then spend the best part of a day working out why a commonly used function has either been moved or called something else. As for that nasty "ribbon", now present within many a Vista and windows 7 application? Give me a break!
                                      I've ditched Autodesk and Windows because despite what people say, there are alternatives out there, to the so called " de facto standard", and here I offer another real world DWG alternative that runs on Mac.
                                      • C
                                        cadward
                                        Hey tfdesign
                                        I have had experience with Mac platform....I found it interesting...but not as friendly as Mac supporters have claimed....I love their sense of product design....did not like their pricing structure....way to expensive... I took the approach of choosing the software that I needed to start my company. If you are into architectural design...PC is the platform to go with. That being said...I really do wish PC's were more concerned with product design....but when you come down to it...the look or shape of your computer really doesn't matter...Unless you have a designer office that you wish to show off....it's the software you use that matters...I personally do not like AutoDesk's pricing structure....But they do offer a very good product that is one of the architectural industry standard...if you can find a good AutoCad clone...go for it...I personally have been using AutoCad since 1990....and my business has benefitted from my decision....but if you can find a software that offers more...go for it...Just remember to buy one that offers good product support.
                                        The bottom line is to choose the best software for your business,,,then buy the computer that supports it.
                                        • T
                                          tfdesign
                                          @cadward said:
                                          Hey tfdesign
                                          Hey cadward. πŸ˜„
                                          Have you now?
                                          a-huh... and..
                                          Right. Not friendly? Okay. That's usually the answer I hear from people who work in pawn shops like 'cash converters', people who have never actually used a Mac. So, in what way? How do you mean? Isn't windows a 'pale copy' of Mac OS anyway? (or Apple's GUI, a copy of Xerox Parc, as some like to say?)
                                          So a Mac is about 'looks' like rather than 'function'?
                                          Expensive? Sorry, but that's another popular Mac myth. A top of the range Macbook Pro is cheaper than a top of the range Dell laptop! And better built! You can also buy a very well specified Mac Mini for Β£420. What about the price of AutoCAD? Do you consider ACAD cheap? I could buy both say PC8 and a Mac Mini for the price of a seat of ACAD LT! πŸ’­
                                          Yes. Likewise! β˜€
                                          Nonsense. Utter nonsense. Next you'll be arguing that is because there is more software available for PC's (more software, more training and, and I fear, more learning costs, less productivity etc)
                                          Ah! So you do think that Mac users choose Mac's because they prefer their looks?
                                          There you go! You reckon it's all about the 'pose factor'? πŸ˜’ I'd be a millionaire by now if every person who said that, each gave me a fiver! πŸ˜‰
                                          Yes, but not always. One of my colleagues, Mike, still prefers to use a pencil and a photocopier! I don't think Mike's pencil has ever even had an OS update, not to mention half a dozen of those security updates that occur each week. And as for the yearly service pack update, the 'update' costs about 30p. πŸ˜†
                                          No I don't think many people do (and it is exactly one of the reasons that I don't support Autodesk!). But what makes this reasoning any different from those so called "high Apple prices"?
                                          "one of the" ….."standards"…..a huh
                                          Why would you necessarily want yet another clone of AutoCAD? What a shame that not a lot, in the world of 2D, because of such "industry standard" dinosaurs, such as ACAD, have ever bettered the genius of Ivan Sutherland's SketchPad at MIT, in the 1950's (<---click on link!)
                                          Yes. It shows! πŸ˜‰ Do you really like that command line? 😲
                                          [quote="cadward":2qcoemgz]
                                          and my business has benefitted from my decision....[/quote:2qcoemgz]
                                          So what you are saying is that software does the designing, instead of a good designer with an 'ounce of talent'? Hmm that kind of logic, is like saying, "purchase a Nikon, because it will make you take better pictures"?! Nonsense!
                                          but if you can find a software that offers more...go for it...[/quote:2qcoemgz]
                                          It's not really about more in a software, it is about productivity, and using a Mac at that!
                                          Just remember to buy one that offers good product support.[/quote:2qcoemgz]
                                          Pah! No comment! πŸ˜„ FWIW, Apple's support is rated among the best in the world. Try getting good support from Autodesk and while attempting to avoid a remortgage of your home and possessions! πŸ˜’
                                          The bottom line is to choose the best software for your business,,,then buy the computer that supports it.[/quote:2qcoemgz]
                                          Of course! So, what was the point of this last post ❓
                                          πŸ˜„
                                          • Mike LuceyM
                                            Mike Lucey
                                            Why does AutoCad have to be the 'standard'?
