    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      groomden
      Is it possible to stretch by assigning a new dimension? i.e. i have an object that is 30 inches high. After selecting the fredo stretch and placing the stretch plane i would like to make the new overall height of my object be 28.5 inches high. Can i type in 1.5inches to get this result?
      Also, I noticed that when you are stretching a group of components where there are multiple instances present, the other components are not updating to the new size that is being stretched? Can this be made a toggle or something to 'update all instances of components in model?'
      Dennis
      • fredo6F Offline
        This is supported. Just move the mouse over the handle corresponding to the stretching direction (you don't even need to click, highlighting is enough). Then press TAB or select "enter new dimension' in the contextual menu. The dialog box shows you the current dimension. You can enter a new one. Note that the dialog box accepts formulas, so you can keep the current number and append -1 1/2'' if you like.
        This is intentional, because in most cases you wish to create a new component with different dimensions and may want to keep the original version, but the idea of a toggle is interesting.
          groomden
          I would find the toggle useful because i am designing furniture for cnc production with various components that I need to get out in a flat state. So I have a 3d fully built model but I also have a version with all the components flat on the ground to make it easy to move the geometry into my CNC package.
          Thanks for the quick and useful response!
          (Are you interested in developing other plugins? I have one that I would like made and am willing to pay for. I don't know if you have seen the SliceForm plugin out there but I would like a version of that with the ability to make slices in a radial direction or to make slices that are perpendicular along a path.)
          • fredo6F Offline
            You can always play with the replacement of components by other components, which is a standard SU capability (in the Component Window).
            For slicing, I think there already exists several plugins doing slicing with various features. I don't know what SliceForm does precisely. Anyway, I am busy at the moment with a Loft and Skinning script, but I am sure some script writers could take the challenge.
              Don-Quixote
              ho scaricato la tua libreria, ma non funziona! come faccio, sembra geniale la tua idea 😞
                manong
                newbie here. this plugin looks great however when i tried to use it my sketchup pro 7 crash and close. is there any way to fix it?
                • mitcorbM Offline
                  mitcorb
                  @Manong:
                  Libfredo is a helper script. Not a procedure plugin as you would see if you were to read previous posts above. You must download some of Fredo6's tools, plugins scripts, such as Fredoscale, or Hoverselect which rely on Libfredo for their functions. Please search the threads for these, and, if you actually did download one of them, and had the trouble you mentioned, then post there. Fredo will try to help you. He is very helpful.
                  Best regards,
                  mitcorb
                    Gerrit
                    Great job πŸ‘
                    This makes a lot easy now 😍
                    Thank you ferry much 😎
                      balloon
                      Thank you very much Fredo6! 😍
                        mgfranz
                        OK, I downloaded this utility for use with the Rounding tool, but would like to know "what else does it do"? What can I do with this utility? I see a bunch of .rb files in the directory but other than the Settings menu, I don't see anything else.
                        "If you like what you do, it will never be work..."
                        In memory of Sam Maloof, 1916-2009
                        • fredo6F Offline
                          LibFredo6 is shared between several of my plugins. It provides a lot of basic functions (for instance the button palette management, the translation, and a large part of the interactive tools).
                          But for the user, it does not do anything by itself, unless used by the real plugins.
                            a4jp.com
                            If I put this in Vista 64, will it still work in the Programs (x86) folder?
                              apple85
                              i finally got round to downloading some of the ruby scripts/plugins to use in sketchup (after it being at least 18 months on mu to do list!) and of course not very wisely i've downloaded too many at once so now i'm trying to locate in the sketchup program menus all of the .rb files that i should of hopefully put in the right location and testing if they are working as they should once i've located them.
                              Getting to the point i've concluded from these threads that the plugins created by fredo don't work unless the 'libfredo6' file is saved in the right location, which i'm guessing if rubies like 'fredoscale' and 'roundcorner' aren't working, it's because i haven't put the 'libfredo6' file in the right location.
                              I've tried reading the instructions provided but they are more pc friendly than mac (i use the mac side of my laptop) but i'm finding them a little difficult to understand (hopefully just having a dumb moment!).
                              Would someone mind looking at the attachment below and point out where i am going wrong in terms of where i have placed the 'libfredo6' file and all related files?
                              many thanks in advance
                              mac libfredo location.pdf
                              • fredo6F Offline
                                Your folder LibFredo6 3.4b is the reason for the problem.
                                Move up what it contains (LIBFREDO6_Dir_34 and LibFredo6.rb) into the Sketchup Plugins directory.
                                Same for JointPushPull and FredoScale, where ytou have encapsulated folders.
                                  apple85
                                  just to clarify - the 'LibFredo6 3.4b' file is like the unnecessary "middle man" file to the LIBFREDO6_Dir_34 file and LibFredo6.rb doc? (same sort of theory with the jointpushpull and similar unzipped files?)
                                  thank you for sparing the time to answer my previous post btw
                                  • E Offline
                                    exodiaangel
                                    do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused πŸ˜• ❓
                                    HELP PLEASE!!
                                    • Chris FullmerC Offline
                                      No you do not. What seems to be the problem? Can you not find the thread for round corners? Or can you not find the script within in the thread? Your post is rather unclear,
                                        HELP PLEASE!!
                                        Hi Laura,
                                        The plugin is attached at the very bottom of the very first post generally. Fredo tends to supply abundant further info and the whole changelog in his first post but you only need what is attached at the bottom really.
                                        And yes, this library, too, in the topic of which we are now at the moment.
                                          chrisdell
                                          Okay this thread is as clear as mud.
                                          What previously named English version of Fredo do I need to install to get the non-Chinese current version of the recently name changed version for Mac?
                                          All the links seems inter connected to form a nice vicious circle.
                                          • massimoM Offline
                                            massimo Moderator
                                            It seems quite clear to me. The "original" (english) zipped folder is, as usual, at the bottom of the first post of this thread.
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 108
                                            • 109
                                            • 31 / 109
