    [Plugin Library] LibFredo6 - v16.3b - 21 Oct 26
    2.3k Posts 592 Posters 13.7m Views 594 Watching
    • G
      Gerrit
      Great job πŸ‘
      This makes a lot easy now 😍
      Thank you ferry much 😎
      • B
        balloon
        Thank you very much Fredo6! 😍
          mgfranz
          OK, I downloaded this utility for use with the Rounding tool, but would like to know "what else does it do"? What can I do with this utility? I see a bunch of .rb files in the directory but other than the Settings menu, I don't see anything else.
          "If you like what you do, it will never be work..."
          In memory of Sam Maloof, 1916-2009
          • fredo6F
            LibFredo6 is shared between several of my plugins. It provides a lot of basic functions (for instance the button palette management, the translation, and a large part of the interactive tools).
            But for the user, it does not do anything by itself, unless used by the real plugins.
              a4jp.com
              If I put this in Vista 64, will it still work in the Programs (x86) folder?
                apple85
                i finally got round to downloading some of the ruby scripts/plugins to use in sketchup (after it being at least 18 months on mu to do list!) and of course not very wisely i've downloaded too many at once so now i'm trying to locate in the sketchup program menus all of the .rb files that i should of hopefully put in the right location and testing if they are working as they should once i've located them.
                Getting to the point i've concluded from these threads that the plugins created by fredo don't work unless the 'libfredo6' file is saved in the right location, which i'm guessing if rubies like 'fredoscale' and 'roundcorner' aren't working, it's because i haven't put the 'libfredo6' file in the right location.
                I've tried reading the instructions provided but they are more pc friendly than mac (i use the mac side of my laptop) but i'm finding them a little difficult to understand (hopefully just having a dumb moment!).
                Would someone mind looking at the attachment below and point out where i am going wrong in terms of where i have placed the 'libfredo6' file and all related files?
                many thanks in advance
                mac libfredo location.pdf
                • fredo6F
                  Your folder LibFredo6 3.4b is the reason for the problem.
                  Move up what it contains (LIBFREDO6_Dir_34 and LibFredo6.rb) into the Sketchup Plugins directory.
                  Same for JointPushPull and FredoScale, where ytou have encapsulated folders.
                    apple85
                    just to clarify - the 'LibFredo6 3.4b' file is like the unnecessary "middle man" file to the LIBFREDO6_Dir_34 file and LibFredo6.rb doc? (same sort of theory with the jointpushpull and similar unzipped files?)
                    thank you for sparing the time to answer my previous post btw
                    • E
                      exodiaangel
                      do i need to be a special type of member or something to download the roundcorners thing? coz i am SO confused πŸ˜• ❓
                      HELP PLEASE!!
                      • Chris FullmerC
                        No you do not. What seems to be the problem? Can you not find the thread for round corners? Or can you not find the script within in the thread? Your post is rather unclear,
                        • GaieusG
                          HELP PLEASE!!
                          Hi Laura,
                          The plugin is attached at the very bottom of the very first post generally. Fredo tends to supply abundant further info and the whole changelog in his first post but you only need what is attached at the bottom really.
                          And yes, this library, too, in the topic of which we are now at the moment.
                          • C
                            chrisdell
                            Okay this thread is as clear as mud.
                            What previously named English version of Fredo do I need to install to get the non-Chinese current version of the recently name changed version for Mac?
                            All the links seems inter connected to form a nice vicious circle.
                            • massimoM
                              massimo Moderator
                              It seems quite clear to me. The "original" (english) zipped folder is, as usual, at the bottom of the first post of this thread.
                              • G
                                Gogle Sketchup
                                Hi, Fredo.
                                Thanks for all your stuff. I have to tell you about a problem from my computer. I extracted all folders as you tell but Sketchup gives an arror like this:
                                """Cannot load plugin FredoScale because the script cannot create DEFRAPAM_Dir folder in:
                                "C:/Program Files/Google/Google Sketchup 7/Plugins"
                                Please create it manually, respecting the case"""
                                It gives the same error for all your plugins. I didn't understand the problem.
                                Sorry for disturbing, and thank you...
                                • G
                                  Gogle Sketchup
                                  I have tried to load for ten times, but nothing happened. It is an amazing plug-in, if there is anybody who saw the same error with me, please help me with it.
                                    agamemnus
                                    OK, I finally read the PDF, and I like all these features. I do.
                                    I just can't pin this bug down yet, but I am occasionally experiencing a problem with being unable to rotate, group, or flip certain elements when the Fredoscale z loader is active. Sometimes, the option to Group is in the "View" menu but not in the Context menu.
                                    • fredo6F
                                      @gogle sketchup said:
                                      Hi, Fredo.
                                      It is a problem of Access Right to your C:\Program Files drive with Vista. The plugin creates this folder to store default parameters. Try to create it manually. You may also want to disable high protection level for the Plugin folder C:/Program Files/Google/Google Sketchup 7/Plugins.
                                        stoop-it
                                        hi,
                                        I can't seem to get this plug in to work..... it has been downloaded as instructed but i cant seem to find the ruby in sketchup... did i miss something.... sometimes my name explains my problems
                                        thank you
                                          stoop-it
                                          Hey Fredo,
                                          thank you very much!!!!! you are dead on!!!!!!!! this works Awesome.... πŸ‘ 😍 🀣 πŸ˜†
                                          • mitcorbM
                                            mitcorb
                                            If I can offer some insight:
                                            LibFredo3.4b is a helper file for many of Fredo's tools. It does not perform any magic on stage. It operates behind the curtains.
                                            Which tool do you wish to download?
                                            There is FredoScale, Tools on Surface, Bezierspline and others.
                                            • 115
                                            • 116
                                            • 6 / 116
