    [Plugin] ExtrudeTools - Full Set
    636 Posts 178 Posters 768.8k Views 175 Watching
      @tig said:
      http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      Is the latest update - the main changes are updated lingvo files and in EEbyR a picking order glitch has been fixed.
      See the individual tools' threads' links for more details... β˜€
      hey TIG,
      is the zip updated as well?
      personally, it's easier to update the entire suite instead of individually (even if only one of the tools have been updated) because i can just overwrite everything instead of having to open the TIGtools folder and only overwrite certain files.
      http://forums.sketchucation.com/viewtopic.php?p=217663#p217663 links to a zip of everything current today [in this thread] - see the suffix on zip's name... This time I also updated each tools' thread too - from now on I'll probably keep the combo zip up to date, and then remove any zips from the four tools' threads - bt keeping the threads' links for the tools' instruction/version-info parts only...
      So there's no need to get the other tool zips... IF you get the combo-zip here http://forums.sketchucation.com/viewtopic.php?p=217663#p217663
      • jeff hammondJ Offline
        cool, thanks
        i think that's the best way to keep everyone up to date. (vs 4 individual threads/tools)
          driven
          Cheers TIG,
          zip Combo works first time out on the Mac, great to see them altogether now, well done...
          still get the 5th button? maybe Jeff could see if it replicates on his Mac.
          Jeff, if I open SU with the toolbar off, and then open it I get 4 EEby... tool buttons, if I open SU having not turned off EEby...TB before quiting, I get a 5th button, it does nothing except changes colour, everthing works if it's there or not, would you mind checking before I fresh install everything again? it might be a Mac thing...
          • N Offline
            notareal
            Thanks, It's good to have just one archive that is needed to load.
            Welcome to try [Thea Render](http://www.thearender.com/), Thea support | [kerkythea.net](http://www.kerkythea.net/) -team member
              @driven said:
              Cheers TIG,
              i can't replicate it.. i always get only 4 toolbar buttons no matter what i do.
              i've done it on a PPC/tiger/SU6 & intel/leopard/SU7.
              could there be a conflict with another plugin causing this?
              • wind-borneW Offline
                wind-borne
                @driven said:
                Cheers TIG,
                following john's scenario, I can replicate.
                Maybe a new tool on the horizon πŸ˜† πŸ‘
                "To read between the lines was easier than to follow the text."OSX 10.11.6
                %(#BF80BF)[SU 8 pro
                  oh wait, if i give the toolbar a horizontal orientation then i do in fact get the extra button.. i keep all of my tool bars vertically on the left side and when done like that, it's always 4 buttons.
                  if i move the 5 button bar to vertical prior to restarting , only 4 will show up after the relaunch.
                    driven
                    so it is a Mac thing, but quite harmless it seems, and I already asked TIG if it was a new tool pending (sorry no), I also stripped out all my rubies and then did a clean-instal of SU just to see if it would go-away, all to no avail. So I'm quite please it can be replicated... sort of.
                    I'll try the vertical tip from Jeff and then forget all about.
                      There MIGHT be a new tool coming... BUT it's nothing to do with that extra button !
                      • ken28875K Online
                        ken28875
                        Awesome tools, TIG.
                        I have been using it a lot lately and love it. But I run into a problem each time. After using it, whenever I right click on an object, most of the functions are not working and i have to restart Sketchup. I wonder if it's a bug and if anyone else has experienced it.
                        http://i593.photobucket.com/albums/tt12/ken28875/right_click_not_working.jpg
                        Thanks,
                        _KN
                        Follow Your Dreams.
                          Rip Tanion
                          I've only really tried EEBR so far, but it's really cool and has a multitude of uses.
                          Personally, I find a tutorial for EEBR unnecessary. I find the plug-in pretty straightforward and easy to use. Still, Arc did a good job with his vid.
                            @ken28875 said:
                            Awesome tools, TIG.
                            _KN
                            This is a known problem - BUT not related directly to any particular Plugin. The latest versions of SUp have a bug where the context-menu items can get 'grayed-out' after a number of repeated 'clicks' on objects; it might also be related to the number of plugins that you have installed.
                            I also have the problem - the Edit menu last item repeats the context-menu without a glitch - but it is still annoying having to save and restart to fix it...
                            The SUp team are onto it - hopefully a maintenance release will fix back it as it was... πŸ˜’
                            • ken28875K Online
                              ken28875
                              Thanks, TIG.
                              Follow Your Dreams.
                              • JClementsJ Offline
                                JClements
                                And I thought I was the only one having this problem! Thanks for mentioning it.
                                  d12dozr
                                  Thanks TIG, Just dl'd and played a bit. I like the zipped set...makes it so much easier. Cheers!
                                  http://goo.gl/f7ooYh
                                  • H Offline
                                    haynesc
                                    will the zipped set be updated along with each update of each individual plugin ?
                                      The individual EEby.. tools will no longer be updated.
                                      Any new or updated EEby tool[s] will be issued in this zipped set...
                                      However, the 'notes' will remain in each individual tool's thread, and I shall also remove the downloads from each at the next update... [which might be next week].
                                      • H Offline
                                        haynesc
                                        cool ... much easier
                                        • majidM Offline
                                          majid
                                          Thnak you again dear Tig πŸ˜„
                                            remus
                                            I downloaded this a while ago and forgot to say thanks, so thanks! These are those most sacred of tools that bring entirely new functionality to SU.
                                            • 31
                                            • 32
                                            • 2 / 32
