    Rendering workshop - Whisky Glass
    71 Posts 19 Posters 18.4k Views 19 Watching
    • daleD
      dale
      My computer(S) really don't like these skp files, I have had nothing but problems, and a lot of crashes. Is anybody else experiencing this? On my old laptop the Kerkythea exporter refuses to even convert the file.
      I was really interested in this challenge as I have always fought with glass, and water and caustics, so kept trying, then this morning after letting the file cook overnight I thought I was finally getting somewhere, I was looking at the image, made a slight adjustment to the gamma, and bingo 14hrs of rendering frozen solid.
      Some interesting screenshots along the way though...
      • david_hD
        david_h
        I don't partake in the Distilled Grains, Fermented Fruits or Brewed Hops.
        So. . . .here's some fruit punch. 💚
        • Al HartA
          Al Hart
          Good work.
          Now we need to see how to put buibbles in the liquid. 😄
          Al Hart
          IRender nXt from Render Plus
          • charly2008C
            charly2008
            Unfortunately, I had only Ramazotti.
            • david_hD
              david_h
              What I am having a hard time with is rendering the "Whiskey" as if it were clear water. The Whiskey component always comes out dark and looks more like Coke. I have been messing around with lights, materials, alphas (which I don't understand anyway. .. .) etc.
              How would i do that? Using Twilight. Any Idears out there?
              • Al HartA
                Al Hart
                Many of these Whiskeys seem too dark.
                Try making it a bit more transparent, and try adding some light from the side rather than the top to lightin up the Wkiskey.
                Al Hart
                • W
                  Whaat
                  This has been running for 38 hours.
                  Hey modelhead. Some things to keep in mind with Indigo:
                  Indigo uses physically based parameters. One of the keys for a render like this is that you have to tell Indigo what medium 'displaces' another. This is done with the 'precedence' settings. For example, we want the ice to displace the whiskey so make sure that the precedence setting for the ice is a higher number than the whiskey.
                  Also, when modeling a liquid in a glass, it is important that the surface of the liquid is actually 'inside' the glass. Then, you need to ensure that the glass precedence setting is higher than the whiskey so that the glass will 'displace' the whiskey.
                  I would lower the absorption of the whiskey using the SketchUp opacity setting as well.
                  Hope this makes sense. 😄
                  • david_hD
                    david_h
                    This would help a lot of people I would expect. 💚
                    I am not sure what is meant by that.
                    Sorry I am so thick. 😳
                      d12dozr
                      Pretty sure that is just an Indigo setting
                      http://goo.gl/f7ooYh
                      • david_hD
                        david_h
                        Things get a little mixed up around this here forum
                          museummaker
                          Win! 🤣
                            d12dozr
                            😆 nice David...render looks good too
                            • T
                              tomer1981
                              Hey guys.
                              For those of you who don't remember - I was the one who modeled the whiskey glass & ice cubes, and I'm quite honored that you all use it for your renders.
                              I'm not quite familiar with the rendering program/plugin you're using, but in the I rendered it with FryRender (found at: http://www.randomcontrol.com/). I saw you were discussing the lighting methods for the rendering, and I must tell you (what you probably already know) - LIGHTING IS EVERYTHING. In my render I didn't use any light fixtures. Instead, I used an HDRI, for IBL (Image based lighting). Meaning - a 32 bit image (.hdr format), which is "wrapped" around an imaginary sphere around the model, and is applying light to the entire model. This method is extremely efficient, and gives awesome results, in less time.
                              About the materials - Fryrender uses it's own materials, and it doesn't rely on the ones from sketchup. So, it doesn't matter what material you specify in sketchup (color, transparency, etc.) - the one you pick in Fryrender can be different.
                              I don't know your rendering program, and I don't know if it supports IBL, but from what I see - it gives pretty nice renderings.
                              You can check out more renderings i did with fryrender, and observe the lighting methods:
                              http://www.flickr.com/photos/41836385@N07/sets/72157622515799491/
                              • Al HartA
                                Al Hart
                                @tomer1981 said:
                                Hey guys.
                                I'm not quite familiar with the rendering program/plugin you're using, but in the I rendered it with FryRender.
                                Thanks for creating the model for us, and the initial rendering. I'm sure you noticed that I added a comment to the model that it was being used for this Rendering Workshop.
                                No particular rendering engine is featured in these workshops, but rather users of all rendering products are encouraged to demonstrate and improve their rendering skills through interaction with other users.
                                Thank you for your comments on how you produced your renderings.
                                For the record, here is tomer1981 rendering of the whiskey glass:
                                http://farm5.static.flickr.com/4015/4318646787_0dafc71abe.jpg
                                Al Hart
                                  Sheik
                                  One more for the road.
                                  A small note on the model; you need to cut holes in the surface of the whiskey where the icecubes are, if you are using an physically accurate engine.
                                  On the other hand this is actually a situation that render engines(atleast Maxwell) can´t get physically right. When light first enters from air to ice and then into whiskey, that ray of light will think it is in air, as it passed thru the backface of ice (not thru the frontface of whiskey). Still, the difference is probably very hard to see...
                                  http://i832.photobucket.com/albums/zz242/Sheiken/whiskey4.jpg
                                  • Al HartA
                                    Al Hart
                                    I started a new Workshop on Wood Cabinets.
                                    These aren't as much fun as a Whiskey glass. But it might be worth honing your wood surfaces skills a bit...
                                    404 Not Found
                                    (forums.sketchucation.com)
                                    Al Hart
                                      richcat
                                      Late as always - only just finished the bottle
                                      My recent attempt
                                      http://nxt.accurender.com/photos/sketchup/images/17514/800x600.aspx
                                        richcat
                                        Another late one this time with octane, just as I open another bottle 😉
                                        I know - Wood texture probably not large enough, glass appears to be floating, and ice appears too silver? - but I'm looking through rose tinted specs, and I like it
                                        • david_hD
                                          david_h
                                          Like I said. . .i am no judge of distilled beverages, but those look nice.
                                          • soloS
                                            Richard, I like the first one (above the Octane one), what render app did you use?
                                            • 3 / 4
