    [Plugin] Xref Manager
    98 Posts 43 Posters 97.6k Views 43 Watching
      davecoopstl
      TIG,
      Is the Xref Manager supposed to open automatically when I open my SketchUp file (that contains x-refs)?
      Under Xref Settings, I chose to "Open Xref Manager If Needed" on opening, but it doesn't do it when I open the file.
      It would be great to know, as soon as I open the file, if the x-refs need to be updated.
      Let me know.
      Dave.
      PS - Any chance of getting an Icon Toolbar for this Plugin?
        bianhai
        Very good!Thank you ! πŸ‘
          davecoopstl
          TIG,
          One other question: Is there any way to put a prefix before the names of the imported layers when you x-ref a file into your model?
          Right now, if I have multiple files I need to x-ref in, and they have the same layer names, but different things on the layers that I want to show, the objects get combined onto one layer in my model. It would be great to have a prefix added to the imported layer names, which would be different for each x-ref.
          Just a thought.
          Dave.
            airsuper
            i found out i can't import DWG files with capital letter file extension.
            eg. "abc.DWG" not ok
            "abc.dwg" ok
            i hoping that will be improve over time.
              David M
              Hi, can you please let me know where I can download the latest verion of the X-ref Plugin.
              • Chris FullmerC Offline
                This might very well be the latest, in the very first post is a script to download.
                  davecoopstl
                  TIG,
                  This script is amazing. We're using it to model a huge site, with lots and lots of buildings, and it's working beautifully. The ability to know what has and has not been updated, and update the modified 'xrefs' is invaluable.
                  But, we've encountered one major 'design' flaw with the script. We have almost 30 xrefs loaded in the model, and the Xref Manager dialog box does NOT fit on the screen anymore, so there's no way to click the "OK" button. And there doesn't seem to be a way to adjust the size or orientation of the dialog box!
                  Is there a way that the size of the dialog box can be flexible or adjustable or, at the very least, include a scroll bar! We really need to be able to see the entire list of xrefs, and scroll down to click the "OK" button.
                  Hope you can help.
                  Thanks for all your hard scripting work!
                  Dave Coop.
                    @davecoopstl said:
                    TIG,
                    But, we've encountered one major 'design' flaw with the script. We have almost 30 xrefs loaded in the model, and the Xref Manager dialog box does NOT fit on the screen any more, so there's no way to click the "OK" button. And there doesn't seem to be a way to adjust the size or orientation of the dialog box!
                    Hope you can help.
                    Dave Coop.
                    XrefManager hasn't been updated for many 'years' ! Unfortunately when it was written the only dialogs available were very limited with no ability to move/resize, add scroll-bars, tick-boxes etc - so this problem with extra long lists was known - the current [old] fix is [was] to split you site into two [or perhaps more] sub-site models and then xref those into a single master-site; then the individual 'plot' model file xref goes into the appropriate smaller sub-site model; then you'll get manageable lists - but you do need to remember to update the sub-plot model xrefs and then update the master-model xrefs... 😞
                    The good news is that more recent versions of the API let you use 'web-dialogs' which are much more flexible and allow longer lists, tick-boxes, scroll-bars etc etc πŸ˜„
                    The bad news is I haven't any time to update it [yet] 😞
                    Look out over the coming 'months' rather than 'years' !!! πŸ€“
                      davecoopstl
                      TIG,
                      Thanks for the info. We pretty much figured out the sub-xrefing system. It kind of stinks, because you are constantly checking to make sure the xrefs inside of xrefs are updated, but it does work.
                      Meanwhile, we can NOT wait until you have time to update the script! It sounds like you know exactly how to fix the dialog box, but just need time to do it. Hopefully you'll have time to get to it in the not-so-distant future.
                      Again, thanks for all the great work. We'll keep an eye out for an update to this amazing script.
                      Dave Coop.
                      • halroachH Offline
                        halroach
                        This is a great plugin!
                        I had a bit trouble navigating through the forum until I noticed that the latest version was 5.1 and not 5...
                        I recommend merging the two threads
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=7329
                        http://forums.sketchucation.com/viewtopic.php?f=323&t=7289
                        FlexTools - Super Quick Windows, Doors, Slats...
                          stefx
                          TIG,
                          I downloaded the file.
                          When i tried to import any dwg i got this note:
                          "This requires 'win32ole.so' to be in the Plugin folder!
                          Exiting... "
                          Any tips?
                          Stef.
                            Unzip this in your Plugins folder...win32ole.zip
                              stefx
                              fast answer.
                              good answer.
                              useful answer.
                              thank you very much TIG.
                              stef.
                              • marvins_dadM Offline
                                marvins_dad
                                I was looking to try this out to combine 3 large files.
                                but...
                                http://www.sketchucation.com/forums/scf/viewtopic.php?f=57&t=7330
                                Seems that the Tutorial has vaporized.
                                Any ideas if there are any other locations that can give me an idea how to get around with this ruby?
                                My Gallery
                                  XrefManagerHelpNotes.pdf
                                    marvins_dad
                                    Thanks! πŸ‘ πŸ˜„
                                    My Gallery
                                      pulsezip
                                      Does this plugin work for sketchup 7 or 7.1 ?
                                        I should work for v7/7.1/8 BUT it really does need a major overhaul... BUT there's a loooong list 😞
                                          prospero spring
                                          Hi TIG,
                                          I just upgraded my SketchUp to V8 Pro but the V5.1 is not working anymore. I can get an advice to fix it?
                                          Thanks,
                                            @prospero spring said:
                                            Hi TIG,
                                            Thanks,
                                            Please try running it with the Ruby Console open and post any error messages...
                                            • 1 / 5
