    [Plugin] Projection toolbar update
    30 Posts 18 Posters 53.9k Views 18 Watching
    • CadFatherC Offline
      CadFather
      for some reason i can't upload an image - the tool i have in mind is the project along z
      • i was thinking of a keyboard shortcut which quickly projects lines along one of the other axis. to be sure the vector one works so don't worry about it...take a good rest
        (if you can).. 😲
      • U Offline
        urs0815
        hallo Didier,
        I installed the "projection toolbar", it works fine, BUT now the right mouse button doesn´t work how it should: when I activate an object and klick the right mouse button (to call the context-menu), the object is not active any longer.
        I use SU6free on MacOSX - I´ve tried it with a 3 button mouse and a Wacom tablett -> same problem
        • EdsonE Offline
          Edson
          didier,
          what can i say? u da man!!! one more fantastic script that will boost everyone's productivity.
          i tried all the tools and they worked perfectly on my mac running OS 10.4.11.
          regards and thank you once more.
          p.s.: would it be at all possible to control the distance between the two points needed to extrude lines along a vector via VCB?
          http://www.mahfuz.arq.br
          • Didier BurD Offline
            Didier Bur
            Hi Edson,
            You can make it work this way, or did I forget something ? 😲 😲
            Click a first point somewhere, drag the mouse in the direction you want the vector to be, then enter a number in the VCB. 😄
            PS: multiwalltool tuto not forgotten 😉
            Regards,
            DB
            • EdsonE Offline
              Edson
              yes, it does work. i have probably done something wrong when i tried before.
              PS: multiwalltool tut not forgotten
              thanks! i thought of that the other day but did not want to ask again since you have been giving us so much.
              regards.
              • free agentF Offline
                free agent
                this has become one of my many favourite scripts, but i cant assign keyboard shortcuts to the individual commands, any way of fixing this?
                • X Offline
                  xrok1
                  i've been wanting this for a long time now. thanks to the new ruby search index and thankyou very much dedier. 😍
                  • X Offline
                    xrok1
                    Hmmm, check this out. if i select more than one line to project perp. to plane, only 1 projects???
                    try the file, select all the edges then the face obove it and try project perp. to plane.
                    project.skp
                      bluestone
                      it's really good one for AV designer
                        ckosio
                        thanks a lot....for sure I will it alot!
                        • DVERGERD Offline
                          DVERGER
                          Bonjour/Hello
                          J'ai certains icones en double, en français et en anglais (en vert sur l'image).
                          I have duplicate icons, in french and in english (in green on picture).
                            Il y a 2 versions successives mélangées en même temps! 😉
                            • DVERGERD Offline
                              DVERGER
                              J'ai "fr_projection_extension" et "projection_extension". Donc je vire "projection_extension". C'est bien ça?
                              EDIT : C'est fait mais j'ai perdu les 4 derniers icones de la barre qui n'étaient pas en double.
                              • X Offline
                                xrok1
                                great set of tools, thankyou.
                                is there any chance to add a project along normal to the extrude lines tool? 💚
                                  LannorMov
                                  @didier bur said:
                                  Hi all,
                                  Here is an update (major revision) of my projection toolbar.
                                  What's new:
                                  · More user-friendly commands: click points instead of selecting objects for plane definitions and vectors
                                  · Better selection errors checkings
                                  · Project faces along Z and along vector gathered in one command.
                                  · ExtrudelineTool included
                                  · lines2cyl and credits commands suppressed
                                  · Construction line at intersection of faces enhanced: multiple selection supported
                                  · New icons
                                  · PDF doc included
                                  Enjoy,
                                  Gracias Didier, solo gracias
                                  • sketcpeppe75S Offline
                                    sketcpeppe75
                                    recent release is projection v6 or v2? tanks to job
                                      Didier Bur
                                      It's V2 and can be found here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=671
                                      DB
                                        sketcpeppe75
                                        beau travail didier....merci beaucoup 😄
                                        • jim smithJ Offline
                                          jim smith
                                          thanks for the update Didier 👍 r
                                          "Out of clutter find simplicity,
                                          from discord find harmony,
                                          In the middle of difficulty lies opportunity"
                                          Albert Einstein
                                            ahnvtk
                                            I posted, then thought I found the answer, then deleted, then thought I don't have the answer.. 😕
                                            Which version is newer: V6 at the first post here, or V2 found at the plugins index of the site linked from the last post here? -
                                            http://rhin.crai.archi.fr/rld/plugin_details.php?id=671
