    [Plugin] Projection toolbar update
    30 Posts 18 Posters 56.0k Views 18 Watching
    • free agentF
      free agent
      this has become one of my many favourite scripts, but i cant assign keyboard shortcuts to the individual commands, any way of fixing this?
      http://i167.photobucket.com/albums/u143/FreeAgent84/bug.gif
      • X
        xrok1
        i've been wanting this for a long time now. thanks to the new ruby search index and thankyou very much dedier. 😍
        • X
          xrok1
          Hmmm, check this out. if i select more than one line to project perp. to plane, only 1 projects???
          try the file, select all the edges then the face obove it and try project perp. to plane.
          project.skp
          • B
            bluestone
            it's really good one for AV designer
            • C
              ckosio
              thanks a lot....for sure I will it alot!
              • DVERGERD
                DVERGER
                Bonjour/Hello
                J'ai certains icones en double, en français et en anglais (en vert sur l'image).
                I have duplicate icons, in french and in english (in green on picture).
                  Il y a 2 versions successives mélangées en même temps! 😉
                  • DVERGERD
                    DVERGER
                    J'ai "fr_projection_extension" et "projection_extension". Donc je vire "projection_extension". C'est bien ça?
                    EDIT : C'est fait mais j'ai perdu les 4 derniers icones de la barre qui n'étaient pas en double.
                    • X
                      xrok1
                      great set of tools, thankyou.
                      is there any chance to add a project along normal to the extrude lines tool? 💚
                      • L
                        LannorMov
                        @didier bur said:
                        Hi all,
                        Here is an update (major revision) of my projection toolbar.
                        What's new:
                        · More user-friendly commands: click points instead of selecting objects for plane definitions and vectors
                        · Better selection errors checkings
                        · Project faces along Z and along vector gathered in one command.
                        · ExtrudelineTool included
                        · lines2cyl and credits commands suppressed
                        · Construction line at intersection of faces enhanced: multiple selection supported
                        · New icons
                        · PDF doc included
                        Enjoy,
                        Gracias Didier, solo gracias
                        • sketcpeppe75S
                          sketcpeppe75
                          recent release is projection v6 or v2? tanks to job
                          • Didier BurD
                            Didier Bur
                            It's V2 and can be found here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=671
                            DB
                            • sketcpeppe75S
                              sketcpeppe75
                              beau travail didier....merci beaucoup 😄
                              • jim smithJ
                                jim smith
                                thanks for the update Didier 👍 r
                                "Out of clutter find simplicity,
                                from discord find harmony,
                                In the middle of difficulty lies opportunity"
                                Albert Einstein
                                  ahnvtk
                                  I posted, then thought I found the answer, then deleted, then thought I don't have the answer.. 😕
                                  Which version is newer: V6 at the first post here, or V2 found at the plugins index of the site linked from the last post here? -
                                  http://rhin.crai.archi.fr/rld/plugin_details.php?id=671
                                  • Didier BurD
                                    Didier Bur
                                    @ahnvtk: the latest version is to be found at the link on RLD http://rhin.crai.archi.fr/rld/plugin_details.php?id=671
                                    DB
                                      ahnvtk
                                      thx
                                        melkhout
                                        This is a great plugin!
                                        Anyway it would come extremely handy, if it were able to project multiple points at once onto a given surface.
                                        Though I have no idea how complicated it would be to modify the script accordingly, to me this would be of great value!
                                        Best regards!
                                        • C
                                          ckflyer
                                          the plug looks so great, I would like to try and learn it
                                          • GaieusG
                                            Go ahead,LYC and download > install it then!
