    [Plugin] Projection toolbar update
    30 Posts 18 Posters 53.7k Views 18 Watching
    • U Offline
      urs0815
      hallo Didier,
      I installed the "projection toolbar", it works fine, BUT now the right mouse button doesn´t work how it should: when I activate an object and klick the right mouse button (to call the context-menu), the object is not active any longer.
      I use SU6free on MacOSX - I´ve tried it with a 3 button mouse and a Wacom tablett -> same problem
      • EdsonE Offline
        Edson
        didier,
        what can i say? u da man!!! one more fantastic script that will boost everyone's productivity.
        i tried all the tools and they worked perfectly on my mac running OS 10.4.11.
        regards and thank you once more.
        p.s.: would it be at all possible to control the distance between the two points needed to extrude lines along a vector via VCB?
        http://www.mahfuz.arq.br
        • Didier BurD Offline
          Didier Bur
          Hi Edson,
          You can make it work this way, or did I forget something ? 😲 😲
          Click a first point somewhere, drag the mouse in the direction you want the vector to be, then enter a number in the VCB. 😄
          PS: multiwalltool tuto not forgotten 😉
          Regards,
          DB
          • EdsonE Offline
            Edson
            yes, it does work. i have probably done something wrong when i tried before.
            PS: multiwalltool tut not forgotten
            thanks! i thought of that the other day but did not want to ask again since you have been giving us so much.
            regards.
            • free agentF Offline
              free agent
              this has become one of my many favourite scripts, but i cant assign keyboard shortcuts to the individual commands, any way of fixing this?
              • X Offline
                xrok1
                i've been wanting this for a long time now. thanks to the new ruby search index and thankyou very much dedier. 😍
                • X Offline
                  xrok1
                  Hmmm, check this out. if i select more than one line to project perp. to plane, only 1 projects???
                  try the file, select all the edges then the face obove it and try project perp. to plane.
                  project.skp
                    bluestone
                    it's really good one for AV designer
                      ckosio
                      thanks a lot....for sure I will it alot!
                      • DVERGERD Offline
                        DVERGER
                        Bonjour/Hello
                        J'ai certains icones en double, en français et en anglais (en vert sur l'image).
                        I have duplicate icons, in french and in english (in green on picture).
                          Il y a 2 versions successives mélangées en même temps! 😉
                          • DVERGERD Offline
                            DVERGER
                            J'ai "fr_projection_extension" et "projection_extension". Donc je vire "projection_extension". C'est bien ça?
                            EDIT : C'est fait mais j'ai perdu les 4 derniers icones de la barre qui n'étaient pas en double.
                            • X Offline
                              xrok1
                              great set of tools, thankyou.
                              is there any chance to add a project along normal to the extrude lines tool? 💚
                                LannorMov
                                @didier bur said:
                                Hi all,
                                Here is an update (major revision) of my projection toolbar.
                                What's new:
                                · More user-friendly commands: click points instead of selecting objects for plane definitions and vectors
                                · Better selection errors checkings
                                · Project faces along Z and along vector gathered in one command.
                                · ExtrudelineTool included
                                · lines2cyl and credits commands suppressed
                                · Construction line at intersection of faces enhanced: multiple selection supported
                                · New icons
                                · PDF doc included
                                Enjoy,
                                Gracias Didier, solo gracias
                                • sketcpeppe75S Offline
                                  sketcpeppe75
                                  recent release is projection v6 or v2? tanks to job
                                    Didier Bur
                                    It's V2 and can be found here: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=671
                                    DB
                                      sketcpeppe75
                                      beau travail didier....merci beaucoup 😄
                                      • jim smithJ Offline
                                        jim smith
                                        thanks for the update Didier 👍 r
                                        "Out of clutter find simplicity,
                                        from discord find harmony,
                                        In the middle of difficulty lies opportunity"
                                        Albert Einstein
                                          ahnvtk
                                          I posted, then thought I found the answer, then deleted, then thought I don't have the answer.. 😕
                                          Which version is newer: V6 at the first post here, or V2 found at the plugins index of the site linked from the last post here? -
                                          http://rhin.crai.archi.fr/rld/plugin_details.php?id=671
                                            Didier Bur
                                            @ahnvtk: the latest version is to be found at the link on RLD http://rhin.crai.archi.fr/rld/plugin_details.php?id=671
                                            DB
