    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 65.6k Views 42 Watching
      kirill2008
      Preview of interaction capabilities of ver. 1.6. (will be ready in the coming days).
      Set of 4 videos:
      [flash=480,385:lwr4hh5j]http://www.youtube.com/p/51499EA555BCA0CC&hl=ru_RU&fs=1" type="application/x-shockwave-flash" width="480" height="385" allowscriptaccess="always" allowfullscreen="true"[/flash:lwr4hh5j]
      In case if someone wants to try prerelease version:
      ver. 1.6. (prerelease)
        dedmin
        Ой! Кажется какая то "волшебная" водка дает тебе творческие силы!
        • jim smithJ Offline
          jim smith
          Google translator
          Oops It seems some sort of a "magic" vodka gives you the creative power!
          I'll drink to that 👍 👍 Thank you Kirill
          "Out of clutter find simplicity,
          from discord find harmony,
          In the middle of difficulty lies opportunity"
          Albert Einstein
            Daniel S
            Awesome plugin Kirill!!!
            Will be possible to add control points automatic to have this results?
            If you select a line:
            If you select a face:
            For more information:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=19321
            Daniel S
            PS: I suppose that ask to add automatic slicing to entities like Fredoscale does (Bend, Twist...) would be asking too much?
            • mitcorbM Offline
              mitcorb
              This is pretty much what I was asking here:
              http://forums.sketchucation.com/viewtopic.php?f=323&t=25082
              In Blender they use variable "brushes" with adjustable radius of influence, sort of like the inverse square law, or sort of like -BTM's Sculpt tools. But the deformations can be spherical, or even planar. Your gifs show a sort of spherical effect.
              This ability would be delicious
              • U Offline
                unclex
                Wonderful
                  kirill2008
                  The work on ver. 1.6. is still in progress...
                  The current stage new features:
                  • wireframe preview of geometry group deformation is a bit faster now
                  • ability to interact with curve control points is also available now
                  Demo video (first 3 minutes are about faster wireframe, last ones about curve control points):
                  [flash=320,265:2fn1qvwi]http://www.youtube.com/v/dO8Nk40IypQ&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="320" height="265"[/flash:2fn1qvwi]
                  ver. 1.6. (prerelease again)
                  @daniel s said:
                  Daniel S
                  Well, LibFredo6 is also free and open source and I think that almost everyone has it (Fredo tools are must-have ones), so, I guess, it is possible to utilize 'automatic slicing' if it is already implemented and present within the library. At least I'll try to.
                  Actually, I thought about something like adaptive tessellation around control point before, so I was going to make it anyway sooner or later.
                  Ога, "волшебная": 3,2% жирности, производится в Чебаркуле, называется ряженка (fermented baked milk). По 0,5 в день и творческих сил, хоть отбавляй
                  http://smiles.kolobok.us/personal/russian.gif
                  • EscapeArtistE Offline
                    EscapeArtist
                    I see in your 1.5 update that you've fixed the "undo" error.
                    Fantastic, and thanks again for a great plugin!!
                      kirill2008
                      First steps of interactive face deformation:
                      [flash=480,385:2m8btgdg]http://www.youtube.com/p/8AB5C9C23863405C&hl=ru_RU&fs=1" type="application/x-shockwave-flash" width="480" height="385" allowscriptaccess="always" allowfullscreen="true"[/flash:2m8btgdg]
                      The initial face dividing was actually not so difficult. Treating deformed result surface as a single entity is more tricky... I don't know yet how to do it. So ver. 1.6. release is delayed again.
                      ver. 1.6. prerelease
                        kirill2008
                        Still prerelease...
                        ver. 1.6.(prerelease)
                        • 2 modes of interactive curve control points dragging: 1) 'preview' mode: shows curve preview while dragging, 2) 'full' mode: deforms the curve (it affects instances 'glued' to curve immediately, but sometimes causes SU crashes...), <Home> key to switch to 'preview' mode, <End> key to switch to 'full' mode.
                        Video shows 2 modes difference, when curves which are under control are also in use within 'blended object' (sublend.rb)
                        [flash=480,385:1q5ubzq1]http://www.youtube.com/v/Wt_Isl5tzP8&hl=ru_RU&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"[/flash:1q5ubzq1]
                          SHAHEEN
                          thanks a million !!
                          Great Plugin
                          " An eye for an eye only ends up making the whole world blind "
                          Gandhi
                            Merlan
                            Amazing !!!
                            Thank you so much !!!
                              kirill2008
                              New version:
                              ver. 1.6.( prerelease)
                              New features:
                              • the current version shows geometry deformation preview while moving control points (both geometry group control c-points and curve control c-points)
                              • it is possible to choose preview mode by hitting <Ins> key (3 modes available: 1. flat-faced surface, 2. surface + edges, 3. wire)
                                [flash=480,385:33h537rh]http://www.youtube.com/p/5077FD48856CD56D&amp;hl=ru_RU&amp;fs=1" type="application/x-shockwave-flash" width="480" height="385" allowscriptaccess="always" allowfullscreen="true"[/flash:33h537rh]
                              • mitcorbM Offline
                                mitcorb
                                Kirill:
                                This looks excellent. I presume it will deform any volumetric mesh?
                                Are you by chance creating a bezier control mesh to do the deformations?
                                  kirill2008
                                  Not exactly. Ctrlpnts.rb utilizes 2 different methods:
                                  • for curve shape changing: linear and cosine smoothed methods
                                  • for geometry group deformation: the same method as pnts2mesh.rb uses for creating terrain surface (when 'according to distance' z-calculation method is chosen)
                                    The second method calculates offset vectors lengths of each vertex according to distances from it to all control points. The degree of influence of each control c-point depends on <1/(distance^power)>. Power is an adjustable value.
                                  Currently I'm thinking about making a kind of substitute for nurbs surface (I don't know what will come of this). It is necessary to add possibility to adjust the slope of the surface area, which is under control of each c-point.
                                  slope adjusting will look something like that
                                  I guess it is possible after adding some linear terms to <1/(distance^power)>.
                                  • mitcorbM Offline
                                    mitcorb
                                    Ok. Just curious. And thanks for your reply.
                                    Does the plugin operate on ungrouped geometry, or groups, or components? Or, how does it deal with these. Even though I watched the video, I am missing something.
                                    I presume this is better for smaller models, because I was trying to deform a rather dense mesh ungrouped. I made a selection of a portion of the mesh and the control point was lost in the blue highlights. It took me a while to find it. And I know I did something wrong because I saw the prompt at the bottom of the screen but I got no results--no action.
                                    Also, I noted that in the plugins menu are some interact commands. But because there is no identifier in the command, I wasn't sure if this was related to Control Points. Perhaps you could do something there to identify with the script.
                                    I was just the other day wishing for an operation like this that would do "smooth mesh deformations" such as in your video. I am using currently Sketchup 6 free version in Windows XP.
                                    Thanks again,
                                    mitcorb
                                      Sculpting in movement! ☀
                                      • EarthMoverE Offline
                                        EarthMover
                                        Kirill,
                                        1.6 looks amazing!
                                        I was wondering if it would be possible to add an option to lock the initial outer edges? To lock the edges from moving, but still deform the face would be a great solution for mounding surfaces.
                                        Content Creator at Skapeup
                                          d12dozr
                                          👍 That would also be nice for making cushions.
                                          http://goo.gl/f7ooYh
                                            EarthMover
                                            I agree Marcus...for me it would be great for terrains and mounding flower beds. I would love to be able to replace Soap Skin Bubble and get rid of that annoying time limit BS.
                                            • 4 / 6
