    SU 7.1 - Free version - IMPORT DFX/DWG ???
    20 Posts 12 Posters 7.4k Views 12 Watching
      Thanks, Chris, I knew I'd seen it somewhere - it's just so new I couldn't remember.
      Also, I will make this topic sticky for a while.
        dolphus
        Thanks chaps i am up and running again ....just don't upgrade EVER AGAIN?
          No, Dolphus,
          When SU 8 comes out and you install it, it will install in a different folder and you can run the two programs separately without any problems (like currently some run even much older versions, too).
          This "courtesy" by Google was only made that if people update SU 7 from 0 to 1, they don't get (too) fvrustrated because of the lack of cad import (although - despite this is not usual from Google, they announced this step way ahead).
          So don't worry.
          πŸ˜‰
            remus
            But then you dont get the speed increase πŸ˜‰ Horses and courses and such.
              Or just stick to v7.0 and do not bother with v7.1 et-al?
              Mike, for the time being, you (and every) free user could upgrade to v.7.1 (it is worth it, believe me) and use the plugin instead of the native importer.
              As for the future, you will see - and that's a different subject.
                The performance improvements in SU7.1 is worth the extra clicks to install the DWG importer plugin.
                  And the plugin is exactly the same importer there is in the Pro version (as I was told when asked if I should install for testing reasons when it was not released yet) so you don't even have to be afraid of any extra bugs it could involve.
                  • AndrewSA Offline
                    AndrewS
                    For the sake of eliminating confusion, I can confirm this.
                    When you use the DWG/DXF importer installer that we're distributing, it enables the use of exactly the same importer as is available in 7.1 Pro. Also, aside from any improvements and modifications that were made in the 7.1 development process, that plugin is the same as what was provided in 7.0; it's not like it's a completely new/redesigned plugin or anything.
                    Andrew
                    Andrew S.
                    SketchUp Release Engineer
                    • O Offline
                      outland86
                      hello is thee any reason why the dxf exporter makes the size of the file that has been imported and worked on scale up by a couple hundred thousanths of an inch ?
                      is this a fault in the exporter ?
                      • FrederikF Offline
                        Frederik
                        Have you remembered to set the scale in the Import options...?? πŸ˜•
                        Cheers
                        Kim Frederik
                        • O Offline
                          outland86
                          yes it works fine for the import but when you export the DXF and bring it in to another cad application it is always larger by about 200 thou
                          very annoying.
                          this seems to happen no matter what the export options are set to and is the same over several external cad applications
                            very annoying.
                            200/1000 - 1/5" ! which might not be much in a big building but is a lot in a piece of furniture...
                            Can we have a zipped/small problem skp and dxf to see it first hand... πŸ˜•
                              arjunmax09
                              Since the discussion is about cad import into SketchUp.. i'd like to ask a question about cad export from SketchUp Pro... on exportin' a model from SketchUp [export 2D graphic option] that has different layers... the layers lose their properties in AutoCAD... i.e. to say... the whole model is in one or two layers... For example if i've made layers in SketchUp for furniture, walls, windows, fixtures, etc... the same doesn't happen in AutoCAD on the model export... the whole cad ... I have to redo the layer thing in AutoCAD 😞 .. is there a way to solve this problem??
                              when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                joppermann
                                I know this may seem like a silly question but what file do I put this in? Plugins?
                                I can't seem to figure out where it should go or how to import a dwg file. I assumed it would be in the import selection. Help!
                                Thank you
                                • Chris FullmerC Offline
                                  Its actually an installer. So double click on it to begin installing it (.msi stands for MicroSoftInstaller). So run it and it wil install itself where it belongs.
                                    joppermann
                                    Aha! Thank you Chris. I appreciate it.
