    New version
    22 Posts 15 Posters 3.0k Views 15 Watching
    • MarianM
      Marian
      I upgraded, from the last build to the latest, just now, seems a bit quicker, it may be just me though πŸ˜›, as i haven't used Su in a while, and not on big models, but can't say this bug fixer fixed all the bugs, i get bugs plats when running the purge plug-in or the purge option before uploading to the warehouse. It maybe purge related or maybe the fact that the shadows were on might have caused it.
      Anyway...needs more bug fixing.
      • GaieusG
        There will never be a SU version without bugs. πŸ˜‰
        • T
          tfdesign
          Andrew, It's great to have the new languages included- especially Chinese! πŸ˜„ Perhaps you could include Urdo and Punjabi next?
          However it would be a lot more democratic if those posting the original links would include links to ALL OS's, and languages, and not just one! πŸ˜‰
          Error 404 (Not Found)!!1
          (sketchup.google.com)
            dedmin
            And written in all languages πŸ’š πŸ’š
              driven
              @chris fullmer said:
              Is this your first upgrade to 7.1? 7.1 had some great speed improvements for sure.
              no, just the single step up, I gave it a short workout on a 'replaceable 3Dtext on tubular spirals' idea I'm working on using BezRndCorner/ShapeBender/CompStringer and that was faster. Also another quick test to see if it had 'fixed' an issue I have with Kirill's (StickStuff) was the same as before, so it not a miracle worker.
              However, I haven't had this console message yet- it's been there since before 7 and is always involved in crashes, so fingers crossed.
              [14/01/2010 04:10:22 [0x0-0x195195].com.google.sketchupfree7[3897] SketchUp(3897,0xa015e720) malloc: *** error for object 0xa03eb6d8: pointer being freed was not allocated]
              I'll be doing a lot of high poly bits today so I really hope it stays a least slightly better than yesterday.
              • sketch3d.deS
                sketch3d.de
                @andrews said:
                7.1.6863 German
                are you sure?
                the freshly downloaded/installed German SUP shows v7.7.6860 here too (EXE: 10.891.264 Bytes f. 12.29.09).
                Norbert
                • T
                  tim
                  Old software geek's saying -
                  The software is only finished when the last customer dies
                  • AndrewSA
                    AndrewS
                    @sketch3d.de said:
                    @andrews said:
                    7.1.6863 German
                    are you sure?
                    Yes and no. πŸ˜„
                    In my excitement to post that information, I accidentally omitted a crucial fact.
                    For all of the languages I mentioned (English, French, Italian, German, Spanish and Japanese), if you go to the "About" menu, the version will show up as 7.1.6860 on Windows or 7.1.6859 on Mac. That is a side-effect of the fact that the underlying program binaries for these installers is the same across all languages.
                    The version numbers I mentioned are how we track the installers for each language differently, which matters if you ever decide to try to install a different localized copy of SketchUp. As it happens, if you try to install English after installing German, it will fail with an error telling you a newer version is already installed, making you uninstall it first. That's because the installer thinks of itself by the version numbers I mentioned, even though the inner product sees itself as the same across the board. Therefore, if 7.1.6863 (German) is already installed and then you try to install English (7.1.6860), it'll fail.
                    But, that's pretty esoteric. In reality, you'll almost never see the installer version number.
                    πŸ‘ Just consider 7.1.6860 and 7.1.6859 as the newest across the board.
                    Sorry for the confusion. 😳
                    Andrew
                    Andrew S.
                    SketchUp Release Engineer
                    • AndrewSA
                      AndrewS
                      There was a bug-free version once. It only lasted a few days before we got bored of having nothing to do and hired some third-party developers to add a bunch of new ones.
                      Andrew
                      Andrew S.
                      • FrederikF
                        Frederik
                        Thanks for the laugh, Andrew... πŸ‘ πŸ˜†
                        Cheers
                        Kim Frederik
                          More importantly, what version will use Ruby scripters see?
                          • Tyler MillerT
                            Tyler Miller
                            Hi Thomas -
                            Ruby scripters will see the binary versions, so 7.1.6860 on Windows or 7.1.6859 on Mac.
                            • GaieusG
                              That was good, Andrew, thanks! πŸ‘
