    [Plugin] Selection Toys
    594 Posts 121 Posters 397.0k Views 121 Watching
      @pghstone83 said:
      However, I am not able to get the selection tools toolbar
      You must Enable it first - Tools -> Selection Toys - Enable Toolbar
      @pghstone83 said:
      select the "loop" selection on the design program.
      All commands are also available from the toolbar.
      Not sure which Loop method you refer to, but you got:
      Tools -> Selection Toys - Select Edge Loop
      and then you got the
      Right-Click on Edge -> Select - Quad-face Loop
        pghstone83
        My Tools button in the program does not have a "selection toys" button as an option to select in order to enable it.
          No Selection Toys under the Tools menu? that's very odd...
          how/where did you install the files?
          • EarthMoverE Offline
            EarthMover
            ThomThom,
            Is it possible to add an option to Select only "Outer Edges" and Deselect "Outer Edges"? Chris Fulmer wrote the code and mentioned in his post it may be better suited for your plugin.
            Do you think a "Select Connected by Orientation" for edges would be possible? Basically I'm asking for a loop select for edges. I know you were looking into it, just wondering if it would ever be possible, or if there are too many variables present to make it feasible to code.
            One other request, if doable, is a quad face loop select that would process multiple edges at once? I find this necessary if I am trying to select a quad loop on an extruded arc with multiple segments and multiple quad face loops. It would be nice to select one set of connected edges and select all their quad loops at the same time. Selection memory is a bit tedious.
            Thanks again for the plug...I love the new toolbar. Definitely owe you several dozen Cookies!!
            Content Creator at Skapeup
              Creepy! ... How did you know we where just talking about that?! 😮 😲
              It's the "Orientation" part that get's a wee bit complicated to determine what is the user's expectation of correct orientation - as well as actually determining. Things is, would a loop select be ok if it selected the edges of co-planar faces? If they are not planar - then things start to become very odd to estimate...
              I think what I need to do with this edge loop thing is make it have more contraints. So what are the most typical types of selections and geometry? (if any)
              I'll add it to the list of things to look into.
                EarthMover
                Must be the sixth sense tingling!
                Regarding orientation for loop select....in most cases that I use it, the edges are coplanar, sharing a common axis. Perhaps one way would be to add an option to select connected edges by a given axis, to better define the orientation. This would handle most of my "loop" situations...although ideally a better method would be to glean the orientation of a selected edge and select all connected edges that are running closest to that orientation. You can look at the code here from a Select edges by Z script that I believe Jim helped me put together. (which I'm sure you already know as the code is simple) Only trouble with this one is that it accounts for the whole model so I usually have to group the area first and then I can select a loop by it's Z height. It might be something to consider adding, but also giving the choice to select connected by X & Y.
                selectedgesbyZ.rb
                  pghstone83
                  I sent the file to the plugins folder on my C drive and extracted it there.I also took in the TTLib folder that I thought I needed for the plugin to work. But when I open the TTLib file up there's another selection toys folder in there. I'm thankful for your for your patience. I'm new with this program.I've been trying to download this file for 3 days and I'm ready to lose it. Isn't the process to send these plugins to the plugins folder in C drive and simply hit extract and enable them in sketchup?
                  • Chris FullmerC Offline
                    The process is to extract the files to your SketchUp plugins folder. It doesn't matter where you save the .zip file as long as you can find it to extract from it. And then extract the contects into the plugins folder. Once you get how to do it, it is very simple and all other plugins work the same.
                      pghstone83
                      Do I have to manually remove every file in the folder or can I just hit "extract"? Some other plugins had to be opened this way for me to get them to work. Also can I just import the "Selection Toys" download or do I also need to bring that TTLib file also?
                        This is easier, as you can select two edges to define the plane they are co-planar to.
                          There should be no selection toys folder in the TT_Lib folder. Something has gone wrong there.
                          There things is; "just hit extract" depends on the extraction program you use. Some apps makes an extra unwanted folder - often happens on OSX it appears.
                          For Selection Toys, the files and folders you want to move to your plugins folder is:
                          A file named "tt_selection_toys.rb"
                          A folder named "TT_Select_Toys" and it's containing sub-folders.
                          For TT_Lib:
                          A folder containing "TT_Lib" - this folder should contain other *.rb files and a webdialogs folder. If it doesn't contain that, but instead just got another folder named "TT_Lib" - then check out that next "TT_Lib" folder.
                            Panga
                            Thanks for this update, and this great plugin !!
                              Maybe an image of the arborescence folder/files needing result will be an help for new plugin users? 😉
                                Yea - I've been thinking I should include that for plugins that consists of multiple files packaged in .zip.
                                  Outer Edges added to selection filters and Quad-Face Loop now accepts multiple start-edges in my internal build. Got a couple of other things to finish before I release it though.
                                  • bagateloB Offline
                                    bagatelo
                                    MODO from Luxology have good tools that make interesting selections. I remenber one very good. Is something like select polygon by yes/no/yes/no/yes/no, or by samples. Think about this, please.
                                      yes/no/yes/no/yes?
                                      • bagateloB Offline
                                        bagatelo
                                        @thomthom said:
                                        yes/no/yes/no/yes?
                                        Please see the imagem called "selection"...
                                        This is plugins tools to make selections in 3dsMax, and more...:
                                        http://www.polyboost.com/features_selection.htm
                                        http://www.orionflame.com/
                                        • JClementsJ Offline
                                          JClements
                                          Hi Thom:
                                          Selection Tools must be a labor of love! 😄
                                          Selecting Instances on same layer (both all and active) not working? See attached.
                                          Select Instance of Same Layer Not Working.skp
                                            I will look into that.
                                            (you edited you post? you mentioned about selecting from active vs all - well, I have been planning a complete new set of selection tools, where you interactively build your selection)
                                            • 18
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 29
                                            • 30
                                            • 20 / 30
