    HelpMeDraw: A curved twisted rope
    12 Posts 4 Posters 2.4k Views 4 Watching
      Quickest way is to find the helix.rb script - that will quickly make a helix shape,
      The select the edges and use another tool like TubeAlongPath.rb to extrude a circualr profile [keep the number of segments sensible as this'll all multiply up and kill your processor...]
      You now have one spiral 'thread' of the rope.
      Select it and use Rotate.Ctrl to make apolar array 360 degrees, immediately type /xxx where xxx is the number of threads in the rope - perhaps 12 - you can keep trying different ones until it looks right.
      The threads are repeated twisted around the vertical axis...
      If you want a non-straight rope bend it with Fredo's tools ShapeBender or Scale or use something like Chris Fullmer's ComponentStringer.rb could do it - where you make a small piece if helix threads and copy it along a 3D path...
      • T
        toke
        Thanks for the answers, but I have it difficult to follow your guides. Where do i get Chris Fullmer's ComponentStringer and helix.rb scrip.
        If you could draw it or maybee more precise
        thanks
        • GaieusG
          Hi toke,
          One of the best tutorials on ropes I have ever seen is that Of Taff Goch here:
          http://sketchup.google.com/3dwarehouse/details?mid=a1d0f59bb2a6325d1672893bc20b4763
            A plug named on the title subject is always on the first post of the thread πŸ˜‰
            So Component Stringer is here πŸ˜‰
            Some helix plugs are here; (you have right to use the search engine of the forum πŸ˜‰
            (up top right page)
            • T
              toke
              Hehe i get it now
              should i just copy the component stringer file into the folder plugin or should i do somthing else ?
                should i just copy the component stringer file into the folder Plugins
                Yes, just πŸ˜‰
                Easy isn't πŸ’š
                • T
                  toke
                  Sry for being a bit of a retard.
                  I found the reason. You need to group the component
                  • T
                    toke
                    Okay... I have tryed, but i really cant get what i want.
                    Its driving me mad.. Plzz if some1 thinks it is easy or would help me, upload a some pic how to do it.
                    Thnaks
                      Without any graphic infos posted or skp file what can we do for help? πŸ˜’
                      and seems that with this tut you can make anything!
                      • GaieusG
                        Hi Take,
                        If you really want to modelthe rope, you will easily find yourself with an extremely large model that is (almost) impossible to work with. Would a solution to do it with only the rope texturebe okay?
