    HelpMeDraw: A curved twisted rope
    12 Posts 4 Posters 2.3k Views 4 Watching
      Make your straight one and use ShapeBender or Fredoscale πŸ˜‰
      or better component Stringer πŸ˜‰
        Quickest way is to find the helix.rb script - that will quickly make a helix shape,
        The select the edges and use another tool like TubeAlongPath.rb to extrude a circualr profile [keep the number of segments sensible as this'll all multiply up and kill your processor...]
        You now have one spiral 'thread' of the rope.
        Select it and use Rotate.Ctrl to make apolar array 360 degrees, immediately type /xxx where xxx is the number of threads in the rope - perhaps 12 - you can keep trying different ones until it looks right.
        The threads are repeated twisted around the vertical axis...
        If you want a non-straight rope bend it with Fredo's tools ShapeBender or Scale or use something like Chris Fullmer's ComponentStringer.rb could do it - where you make a small piece if helix threads and copy it along a 3D path...
          toke
          Thanks for the answers, but I have it difficult to follow your guides. Where do i get Chris Fullmer's ComponentStringer and helix.rb scrip.
          If you could draw it or maybee more precise
          thanks
            Hi toke,
            One of the best tutorials on ropes I have ever seen is that Of Taff Goch here:
            http://sketchup.google.com/3dwarehouse/details?mid=a1d0f59bb2a6325d1672893bc20b4763
              A plug named on the title subject is always on the first post of the thread πŸ˜‰
              So Component Stringer is here πŸ˜‰
              Some helix plugs are here; (you have right to use the search engine of the forum πŸ˜‰
              (up top right page)
                toke
                Hehe i get it now
                should i just copy the component stringer file into the folder plugin or should i do somthing else ?
                  should i just copy the component stringer file into the folder Plugins
                  Yes, just πŸ˜‰
                  Easy isn't πŸ’š
                    toke
                    Sry for being a bit of a retard.
                    I found the reason. You need to group the component
                      toke
                      Okay... I have tryed, but i really cant get what i want.
                      Its driving me mad.. Plzz if some1 thinks it is easy or would help me, upload a some pic how to do it.
                      Thnaks
                        Without any graphic infos posted or skp file what can we do for help? πŸ˜’
                        and seems that with this tut you can make anything!
                          Hi Take,
                          If you really want to modelthe rope, you will easily find yourself with an extremely large model that is (almost) impossible to work with. Would a solution to do it with only the rope texturebe okay?
