    The best GPU of the 15th century!
    15 Posts 9 Posters 1.1k Views 9 Watching
    • GaieusG
      Indeed nice wireframe (although a little bit low poly for rendering I guess). What app did he use?
        What is GPU?
        • IdahoJI
          IdahoJ
          What is GPU?
          Graphics Processing Unit = Video card
          "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
          • david_hD
            david_h
            Looks like he used an Early Version of Lathe.rb.
            • charly2008C
              charly2008
              I think he used the tool Quill Version 1397-1475
              • mitcorbM
                mitcorb
                Notice, he kept his mesh clean. Almost all quads.
                • MarianM
                  Marian
                  So.....uhm is anyone gonna attempt to make this one in SU? 😄
                    matteo
                    The mazzocchio: a torus primitive.
                    hire me: http://www.nonsolo3d.it/ !
                      matteo
                      ... and the dirty ruby script to draw a mazzocchio 😉
                        matteo
                        Finally textured and rendered 🤓
                          LathedVase.pngLathedVase.skp
                          A quick study using my Lathe.rb... you had to ask... 😉
                            matteo
                            The software was officially sold with the name of SuperDelineo or SupraDelineo, but most of its users called it simply SD (read 'eseh-dee). I dont know which version was used here.
                              matteo
                              Wow Tig! Quite perfect.
                              I may be wrong, but I suspect that the triangular faces are part of an array of pyramids surrounding the upper part of the cup.
                              Time for a lathe&array ruby plugin? 😉
                                CF's Component Stringer does the job already - easily added with a small pyramid component [make path in two parts as it can't handle loops] - then explode instances back into main geometry...LathedVasePyramids.pngLathedVasePyramids.skp
