    The best GPU of the 15th century!
    15 Posts 9 Posters 736 Views 9 Watching
      matteo
      Ladies and gentlemen,
      mr. Paolo Uccello: he was an Italian painter and a mathematician who was notable for his pioneering work on visual perspective in art.
      I've always loved his work, and recently I've stumbled upon this figure again- it's simply astonishing! every time.
      hire me: http://www.nonsolo3d.it/ !
        Indeed nice wireframe (although a little bit low poly for rendering I guess). What app did he use?
          What is GPU?
          • IdahoJI Offline
            IdahoJ
            What is GPU?
            Graphics Processing Unit = Video card
            "For a moment, nothing happened. Then, after a second or so, nothing continued to happen."
            • david_hD Offline
              david_h
              Looks like he used an Early Version of Lathe.rb.
              • charly2008C Offline
                charly2008
                I think he used the tool Quill Version 1397-1475
                • mitcorbM Offline
                  mitcorb
                  Notice, he kept his mesh clean. Almost all quads.
                  • MarianM Offline
                    Marian
                    So.....uhm is anyone gonna attempt to make this one in SU? 😄
                      matteo
                      The mazzocchio: a torus primitive.
                        matteo
                        ... and the dirty ruby script to draw a mazzocchio 😉
                          matteo
                          Finally textured and rendered 🤓
                          • TIGT Online
                            LathedVase.pngLathedVase.skp
                            A quick study using my Lathe.rb... you had to ask... 😉
                              matteo
                              The software was officially sold with the name of SuperDelineo or SupraDelineo, but most of its users called it simply SD (read 'eseh-dee). I dont know which version was used here.
                                matteo
                                Wow Tig! Quite perfect.
                                I may be wrong, but I suspect that the triangular faces are part of an array of pyramids surrounding the upper part of the cup.
                                Time for a lathe&array ruby plugin? 😉
                                • TIGT Online
                                  CF's Component Stringer does the job already - easily added with a small pyramid component [make path in two parts as it can't handle loops] - then explode instances back into main geometry...LathedVasePyramids.pngLathedVasePyramids.skp
