    Is anything impossible?
    63 Posts 20 Posters 13.8k Views 20 Watching
    • juan974J
      juan974
      @Jeff Hammond
      the fastest way if you use opposite border curves whit same number of segments is to use ExtrudeEdgebyRails, (egde is the left profil and rails are the top and bottom profil).
      Then select the horizontal lines one by one and scale each to the blue, red, green direction to ajust it to the right profil ... need a picture? (i ll post it this evening)
      juan974 (Réunion island)
      website : http://sketchucation.com/click.php?url=http://www.tarn.us
      • jeff hammondJ
        @juan974 said:
        @Jeff Hammond
        well, i'm not really concerned with the fastest method (unless there are multiple ways to do it accurately).. i'd rather just draw it correctly (which so far, none of the methods are true)..
        the fastest way to do this is with an app other than sketchup.. it's also the only way i've been able to draw it 100% correct..
        i'm still not convinced that drawing this in SU alone isn't impossible.
        fwiw, this shape i've posted is also a simplified version of the actual shapes that need to happen..
          soapskin can't handle it.. it makes horrible kinks/humps/dips and a dirty mesh...
          problem is that you can't rotate the gride (or I don't yet found how) before launch the process!
          But your special four sides case here can be resolved with a plug Coons.rb 😉
          I don't know if this one yet exist 😄 (maybe TIG is on the way 😄
          • juan974J
            juan974
            here is my 3rd try, and it's unacceptable.try3.jpgtry3.skp
            i think i will focus on ExtrudeEdgebyRails and create a topic named "can't we improve ExtrudeEdgebyRails?"
            topic : can't we improve ExtrudeEdgebyRails? here
              driven
              First off, had a look at your gallery Jeff, great work.
              Ok, so here's a 2nd attempt, using Jeff's floor plan and retaining profile's (i.e. all the matting external faces should line up with whatever)
              I wanted to find a way to use EExR and that's mostly what I did, if drawing from scratch, I think it can work on it's own, but I had to sweep the front with FollowMe and did a fillet with DB tool (i've never managed to get later versions to run on Mac). I'd use a lot more line segments from scratch to get it smoother.
              I'd be happy to skate this, although I'd do it on a bike these days.
              jb_datdere_1.skp
                I'm sure EEbyRails v2 will do this as you can pick a fourth curve as the 'melding profile'...
                I haven't yet puvlished it as I'm working on a way to optimize the sub-division of the curves that have uneven segment counts - even more important when with v2 the 2 rails AND 2 profiles egments can be mismatched... Vs might be ready for Xmas, but I'm pretty busy right now on 'real' things too...
                  driven
                  Hi All,
                  had another go (several), I need something similar and working on Jeff's model seems less like work. (go figure)
                  I think this takes Jeff's model off the SU impossible list... and with a few tweaks to the rubies I used, it can be quite fast for it's accuracy.
                  I think I've got a reliable workflow to produce accurate skateboard-ramps, although this one no longer fits Jeff's template, that could easily be remedied
                  I remembered to grab some pics so here they are.
                  Profile line +position aid [CLF_ComponentStinger along PolylineSegmented profile]
                  replaced poly-line with 2seg arc after exploding every other component, eliminates Weld, then EEbyR #comment below
                  needed some repairs after splitting out groups (TT_Select) and exploding then smooth
                  Then I couldn't resist trying Kirril's xmas present on it
                  Observations for the RubyMasters...
                  Rick- it would be really handy to have a WELD Button
                  TIG- this version EEbyR is very good, but when using it like I have, you need it to ask if you want to continue, have a last setting's box, and skip all the standard dialogs if so chosen, I know your busy on the next, but these couple of things would help allot. oh, and could it have a button, please
                  Chris- ComponentStringer was the missing link for any hope of accuracy and I figure you've already figured I like buttons, so could you do a ruby tutorial on how to add them myself to other people scripts?
                  Fredo- I'm glad someone posted about BzRoundEdge, it reminded me I had it for the lettering and it works much better on the mac then the new one.
                  cheers to all and the skp with lot's of test is there for the curious
                  almost forgot the money shot
                  Smooth_Ramp_Bit's.skp
                    I have now got EEbyRails v2 making a complex mesh without [m]any glitches - taking a profile, two rails and a final melding-profile at its end... It will be published later today...
                    Here's the 'problem/complex surface' that is now done quickly with EEbyR [v2] - the number of facets it needs to make a smooth mesh melding into all four edges is now optimized [i.e. minimized] - so even when the rails and profiles are so unevenly segmented and have no multiples - here with v2 there are 950 facets needed with the rails/profiles segments at 15/19 & 18/25 - whereas v1 would have made 285x450=128 and 25x18=250 edges >>> 128x250 x2=256,500 facets [!] and that's if it could have managed it acceptably at all [which was most unlikely!]...
                    Watch for EEbyRails v2's release later today...EEbyRv2-datdere.pngEEbyRv2-datdere.skp
                      driven
                      That looks great Tig,
                      eager to try EEbyR [v2] it on the Mac and report back, can the melding profile need equal segments to the profile or could it be a be a 2 segment point?
                        v2 is now published....
                        The v2 rails AND the profiles can have any number of segments - the rail/profile with the most segments dictate the number of mesh facets...
                        You can go down to only one segment in a curve if desired... but it will be automatically re-subdivided into the same number of pieces as its more segmented sibling...
                        Keeping a pair of rails/profiles with the same segment count or simple multiples thereof will produce the smoothest mesh but any combination will work...
                        • 4 / 4
