    [Plugin] Stick groups to mesh ver. 1.2.
    41 Posts 23 Posters 41.5k Views 23 Watching
    • K
      kirill2008
      @chris fullmer said:
      Saved me a lot of headaches 😄
      I must say, that the most brain-damaging part was addition of edges projections of 'ruling' surface to the group
      http://kolobok.us/smiles/madhouse/wacko.gif
      . Finaly I recalled, that sketchup API has the very powerful built-in method (it actually has a plenty of) for entities collection 'entities.intersect_with'. The rest part was more or less obvious.
      So actually almost all 'housekeeping' details SU handles itself 👍 .
      • P
        pp1357pp24
        thank you,I need for my model
        • K
          kirill2008
          @escapeartist said:
          EDIT: I seem to find a way to break your plugins! Same as my comments about the "add control points" plugin, I applied the plugin, undid the action, and then tried to reapply it.
          Undo performance correct handling is my headache
          http://kolobok.us/smiles/madhouse/dash2.gif
          . I promiss to fix it.
          @escapeartist said:
          PS: I love watching these scripts work, it's like watching Jeff Bridge's character get digitized in Tron.
          A kind of retro-futurism
          http://kolobok.us/smiles/icq/biggrin.gif
          UPD: I mean real-time sticking would look much more impressive, of course. Just imagine: you see neither '>' sign moving left-to-right, nor Jeff Bridge's digitizing characters after picking a surface, just immediately sticked geometry group. It is possible for sure (and maybe already exist in some other modeling soft), but demands a bit low level coding, I guess.
          I believe, SU developing team will take in account an interest of SU community and will add similar tool in future versions of SU (at least in pro version).
          a bit off-topick: http://www.youtube.com/watch?v=jz8QWDBYn5w
            jerome
            @charly2008 said:
            Hi Kirill,
            What a great plugin. An incredible tool. But it doesn't work in Sketchup 7.
            Karlheinz
            Dear charly2008
            It's work fine in my sketchup 7.1.
              driven
              Merry Xmas, New Year, etc...
              Kirril, works on OSX10.5.8 + 7.1, however, 3D text needs to be exploded and regrouped, and it seems to prefer, grid patches made with sandbox, or I get issues.
              but that's fine because it is so neat (and I don't mean in the corny American way), it is tidy, precision engineering tidy, 3D stainless steel printing tidy, fantastic, I certainly hope Santa bought you something nice.
              Anyway heres my test, on a torrus, with a material I made using blend(dot)rb, I'll put a You tube Texture anim up tomorrow. I want to make fire in sketchup... for some reason.
              all the best
              • N
                notareal
                😮 Really cool plugin! Happy holidays!
                • charly2008C
                  charly2008
                  Hi Jerome,
                  You're right, it works. It was my fault. But I noticed the changing of the selection frame.
                  Karlheinz
                  • fredo6F
                    Kirill,
                    The plugin seems very powerful, but I can't make it work on SU7.
                    The progress bar appears but seems to block (at 12%).
                    I am just trying to stick a cube on a dome.
                      driven
                      Fredo,
                      I had to zero out smoothing on the recipient mesh first, and on some of the SU shapes, I also found using 'add-detail' from sandbox seemed to make a difference.
                      don't know why it worked, but I've been trying to apply 3D text to curved tubes for ages and kept at it till it worked.
                      Oh, I also grouped a much smaller patch, just bigger than the text footprint. as the recipient and that speeds it all up.
                      on the mac with 7.1 it was slower than the video implies and I don't seem to get as much shown on screen, but the end result is great.
                      I need this to be 'watertight' for STL export and I had very little internal clean-up to do.
                      cheers again Kirill
                      Any chance of utilising this method in a booleen tool, I can't get as clean an intersection with anything I've tried on a mac
                      • K
                        kirill2008
                        @driven said:
                        Anyway heres my test, on a torrus, with a material I made using blend(dot)rb, I'll put a You tube Texture anim up tomorrow.john
                        Actually I'm surprised a lot that it works for torus. The 1.0 version does not check if each face of ruling surface is the first one intersected by 'sticking' ray (but it has to perform such checking for the surface that is not terrain-like, I'm on my way to implement the mentioned checking).
                        So the only explanation is that torus faces near the text group were occasionally processed before other torus faces and other faces were occasionally ignored, or maybe a part of torus surface that is the most close one to the text was grouped and used as a ruling surface, as in the following video:
                        http://www.youtube.com/watch?v=8EB68JdEJSo
                        So the sticking result does not depend on smoothing, but on surface geometry.
                        explanation picture
                        Everything is more or less obvious, but demands a bit of additional work to make the result of script processing more expected one, you know principle of least surprise (POLS)
                        http://smiles.kolobok.us/standart/smile3.gif
                          driven
                          @kirill2008 said:
                          torus surface that is most close one to the text was grouped
                          Kirill
                          Exactly, on the mac I also re-surfaced the mesh and added detail with sandbox first, my model torus is 128 segments x 32 sides, so making a small patch is essential, experimenting with tube intersections now, had a couple of crashes, but I'm just playing around between domestic chores today, so maybe I'll have more luck later on.
                            driven
                            love it , what more can I say
                            actually, I can report there's some sort of issue if I've used blend before trying to use this,
                            it's as if blend hold's on to a required file or path or something
                            if I quit and retry it works fine, only seems to be blend, but it may of been the problem the other day after I'd used CLF_SimpleLoft and 2Faces+path
                            I wasn't looking for a clash, but this is repeatable... nothing shows up in ruby or mac console, and I can't read the SU logs although I do have them.
                            cheers
                              driven
                              Hi Kirill,
                              1.1 is even better, but I guess that's the point... well done.
                              I think anyone on the mailing list may have not know about the update yet because your edit of the top frame doesn't appear to send a 'new message' notification and I got a you tube 'new movie' email and came looking for it.
                              been playing with using it to apply decals, etc to objects. You can sort of do it with photo textures, but grouped or imbedded geometry is way nicer, and easier to change materials, so I'm very happy.
                              The text is single surface, no thickness
                              On my first test, which I binned (because it had a typo) I used- Yes check for non terrain, Front and Super, when it was cooked (much faster now) I exploded both groups, smoothed, softened and textured. I then did a volume check and there were no holes at all, perfect first time, except for the typo.
                              I binned it, changed the font and size, same settings. When cooked it sat off the surface (.25), with one end further away then the other? so I went though everything I could think of until I eventually got one that was almost right, added .002 thickness and merged that.
                              Nowhere near as nice as the first so I tried scaling down the text used the original settings and ended up with a perfect profile sitting exactly in the other surface, but I couldn't the two to intersect, so this one is actually .00025 in front off the drape ( so that you can see ti from all angles) and it's still grouped separately unlike the first.
                              double sided drape, single surface text
                              if you want to have a go at merging these two here's the file
                              • K
                                kirill2008
                                Hi, Driven.
                                It is strange, but I did not provide processing of the group with zero thickness, but it is necessary to do it.
                                In the current version (1.1., 1.2.), it is possible to process zero-thickness groups, but bounding boxes of such groups has to have a non-zero thickness (it is possible if rotate a bit a flat group, then explode it, then regroup again).
                                square face was rotated 5degrees or so (XZ plane), perform non-terrain checking - yes, stick direction - down, stick type - super
                                mentioned above model
                                I promise to fix the problem to stick flat groups without any additional labor.
                                  driven
                                  hi Kirill,
                                  1.2, when did you post this? I can't keep up... looks even better, but I quickly downloaded and tried it on the curtain skp and it's not recognising the group that I was using with 1.1 so I explode, re-grouped added a second group, and still get the message to choose groups? I had this with 1.1 but can't remember the work around...
                                  I'll have a play
                                  sorted, DrivingDimensions was interfering so I disabled it and 1.2 appliqué is 'part of the fabric', literally. very, very nice...
                                  after having a play your skp I noticed I already had a slight rotation on the group from 1.1 test and I must of done it to get it to run...
                                  it seem to be what was causing the lifting at on end, so I re-aligned it and added a single square at right-angle to the text face (out of the way) and it processed fine.
                                  Tips for anyone giving '2D' text a try-
                                  leave the 'square' till last to avoid needing to use outliner to select the text group
                                  apply material to recipient mesh first, so you can you 'select face material' and ' erase co-planer', to aid clean-up of mesh
                                  I found, using cut, paste in place, explode into the mesh group gave a very clean join.
                                  leave the back of the mesh default to aid changing the face colour texture, (or hide a flat colour swatch in the group)
                                  Tips for playing around with my skp-
                                  each side is now 3 groups on separate layers, so you can toggle front, back, or thickness independently to have a look.
                                  these 6 group are inside 2 groups, so you can use 'scale' tool to open and close the curtains.
                                  if I was to use it in a model I would delete the front and thickness groups and apply 'fabric' to both remaining faces(less polly's)
                                  Now I'm off to 3D Warehouse to find a car to stick 'DECALS' all over...
                                  cheers again Kirell
                                  part of the fabricuse 'scale' to close the curtains[attachment=1]
                                  EmbroidedCurtainAnyone-1.2.skp
                                  • ken28875K
                                    ken28875
                                    Awesome, Kirill! Just what I was looking for.
                                    Thank you. 👍 👍
                                    Follow Your Dreams.
                                    • EarthMoverE
                                      EarthMover
                                      Driven,
                                      Wouldn't it be a lot faster to just use the "Drape" tool to drop 2D shapes onto a "curtain" like surface?
                                      Content Creator at Skapeup
                                        driven
                                        @ EarthMover
                                        I was doing a lot of testing on TIGs EE tools at the time and Mac de-bugging with Kirrils on another machine and thought I try some combinations.
                                        It's a bit subtle in a still but if you animate the curtains you can see the difference this methods gives..
                                        I'm actually putting 3D text onto curved pipe and kirril's is as fast as any method I've found so far....
                                        • tibetT
                                          tibet
                                          hi,
                                          because videotut aren´t working, i´ve found some for those, who aren´t familiar with the plugin like me.
                                          cheers!
                                          http://www.sublog.net/archives/41441
                                          http://i52.tinypic.com/zujcp1.jpg
                                          SU 2015 Pro on Win10 x64
                                          • K
                                            kirill2008
                                            I just live it here...
                                            [flash=530,315:fkl0g14l]http://www.youtube.com/v/gT-8NyvR3D0?version=3&hl=ru_RU[/flash:fkl0g14l]
                                            • 2 / 3
