    2D fillets and CNC
    46 Posts 7 Posters 17.7k Views 7 Watching
      If you are picking each point then only corners <180 degrees need the extra arc-hole, so place it on the smaller angle formed by the edges?
        .angle_between doesn't give a result in a 360 direction. Only 180. If you get a result of 15 degrees - it could be in either left or right direction. That's why it's a little bit more complicated. πŸ˜•
          Get a 'cross' of the normal and edge vectors and if it's '-ve' you can make 180 adjustment?
            Cross of the face's normal and the edge normal? If it's '-ve' - what does that mean?
              Sorry- I was too quickly typing that up - I had to go somewhere urgently... 😳
              If you take the vectors of the two edges 'outwards' from the vertex.position you can then get the angle_between them.
              The angle will always be returned as <=180 degrees - even if it's really >.
              If you use edge_vector.cross(face.normal) you get +/-ve values in the result.
              You can then 'cross' these together.
              Getting the cross value returns different results depending on whether the angle is <180 or not - I think it will be 0,0,0 if it's <=180degrees ?
              By noting the appropriate value of the z (?) you can add 180 to the angle if it's found to be needed when z != 0 [-ve?]...
              You'll need to check the way these values change - unfortunately I haven't go access to my 'code-snippets' right now...
              Sorry for the bad explanation - but it is possible to test for angles >180 this way - I have done it... πŸ˜•
              • O Offline
                outland86
                Hello again and thanks for all the input
                to better illustrate what the needs are for this plugin i have drawn a picture of the typical use of these fillets in a bit of sheet material say 3/8 inch MDF
                while T bones would be good they are not critical .
                however the dogbone type fillets are as you can see. t bones are just another way to get the same result.
                when i drew this i noticed that the weld and trim comands were different for the inside square and the outside trims just thought i would note that..as the mathe must be different for both?
                the options shown in the picture would be typical of the actual uses. i have uses a larger arc for this drawing but in real life the arc would be usually say 1/4 inch if cutting 3/8 thickness sheet material say plywood or MDF. i hope this better shows what i am trying to achieve..some of the projetcs i have in mind have hundreds of parts so doing it all by hand with circles etc would be a nightmare hence the need for a plugin to help automate this process. if you imagine when drawing if a guy or gal enter a radius then could point to the coner intersection of a square or inside corner then click and it would be selected then click again and presto a fillet appears one would be in CNC heaven πŸ˜„
                http://www.makecnc.com/bones2.jpg
                  That works for edges on any plane in 3D space?
                    outland86: do you need control over each corner? or would it be ok to just click a face and have the script process all the corners?
                      I used face.normal since these edges will have faces, BUT you could also use a plane defined by the picked vertex.position and the two edges' other_vertex.positions [plane=Geom.fit_plane_to_points(p1,p2,p3)] and then get the plane's normal=[plane[0],plane[1],plane[2]] ???
                      Unfortunately this is all from memory... πŸ˜’
                        think I got it working... hmm.... but I don't have much more time today to test this.
                        • O Offline
                          outland86
                          Hi all
                          to answer your question you do not need control over the parameters other than setting the tool radius before you start
                          so it would be the same every time
                          • O Offline
                            outland86
                            hey it would be perfect to have both options to process all and also indervidual corners
                            can this be done?
                            • fredo6F Offline
                              can this be done?
                              I included a DogBone extension in BezierSpline.
                              This allows to create directly dogbone when drawing a polyline, or to convert an existing contour. You can further change the radius.
                              So it is not a point and click, and more oriented to handle contours.
                              It is advised to install first the new upgrade BezierSpline 1.3, because it now converts a sequence of edges without having to weld them as a curve beforehands.
                              Here is a short video
                              [flash=425,344:2aed5ook]http://www.youtube.com/v/GN6xmiYRi7E&hl=fr_FR&fs=1[/flash:2aed5ook]
                              For BezierSpline 1.3, see http://forums.sketchucation.com/viewtopic.php?f=323&t=13563&p=100509#p100509
                              • O Offline
                                outland86
                                thanks for your help so much
                                i did notice that when you apply the dog bone or t bone to a set of poly lines it made them
                                at every single intersection of polylines which is not what is needed only on the inside corners is it needed as that is where the cutting tool raduis is a problem for getting fits
                                the cutting tool can make sharp outside corners no problem .
                                if you take a look at the picture i uploaded you can see which places need dog or t bones in them and which do not
                                is there way to make the script only apply the t or dog bones to inside corners of a drawing as shown in my picture
                                i hope this makes sense?
                                and thanks again for all your help
                                • fredo6F Offline
                                  @outland86 said:
                                  is there way to make the script only apply the t or dog bones to inside corners of a drawing as shown in my picture?
                                  Sorry, this is not really possible with the current design of BezierSpline.
                                  You can still select the two edges bordering a vertex and apply the script however.
                                  • O Offline
                                    outland86
                                    that will work fine. thanks for all your work on this
                                    and to you tig thank you for your work and input as well did you end up finishing anything?
                                    and to everyone els who took and interest thanks much
                                    merry xmas
                                      I've also been looking at this over the last week. Haven't had much time to work on it. (Nor can I do much work atm as my right eye isn't too good.)
                                      But it touches upon something I've been having problems with before, determining the orientation of edges in relationship to each other. So with a milling tool in mind, I started writing a tool that let you click in a face to create the fillets in appropriate corners.
                                      This is still just WIP. Haven't written the code that actually makes the cut.
                                        WIP alpha version available here: http://forums.sketchucation.com/viewtopic.php?f=323&t=24826
                                          http://www.makecnc.com/bones.jpg
                                          Lighting image for me about the dogs'bones & Tbones β˜€
                                            Moved this topic to the Developer section of the forum.
                                            • 2 / 3
