    Entity.visible? vs entity.hidden?
    21 Posts 8 Posters 3.2k Views 8 Watching
      @al hart said:
      I believe they both refer the the hidden state, and have nothing to do with layer visibility.
      http://forums.sketchucation.com/viewtopic.php?f=180&t=23806#p202821 πŸ˜‰
      • TIGT Online
        You are right [as thomthom said] entity.hidden? is the same as !entity.visible
        You can also toggle entity.hidden=true/false and entity.visible=false/true
          MartinRinehart
          Any reason not to declare visible? a bug?
            I think the reply you would get is "By design".
            From the manual on Drawingelement.visible=:
            This method performs an opposite function to the hidden= method.
            Error 404 (Not Found)!!1
            (code.google.com)
            I think a feature request for a different method that will return to whether the entity can be seen in the model or not is what we'd need to make. Drawingelement.seen? maybe? And more importantly, a method that will let us dig down backwards in the hierarchy of the entity tree.
            • Chris FullmerC Offline
              Yeah, because maybe its actually hidden? that's a bug πŸ˜„
              Ruby likes to have duplicate methods for the same process. Seems like many methods are available in the positive and negative form.
                Jim
                Except that hidden and visible are real attributes of objects, and should not have been used as aliases. Using visible as an alias for not hidden is crap. Leave the sugar out of the API.
                • Al HartA Offline
                  Al Hart
                  At this point, if they some changed what it meant, it would break any scripts which were using it to mean "not hidden".
                  However, it would be nice if they added 1 to 3 of these new functions:
                  entity.is_visible? - not hidden, and not on a layer which is hidden (including groups and sub-components which are hidden or on layers which are hidden)
                  entity.is_in_current_view - is_visible? and also is visible in current camera view
                  entity.is_obstructed - is visible? but is behind something else which is not transparent.
                  The last two are pie-in-the-sky, but the first one would be a useful function.
                  However, as I write this I see that part of the problem is what is meant by an entity. As I drill down through the database and think I am pointed at a single, unqiue entity, I am often pointed to an entity in a component definition, which, if the component is used more than once may be in hidden instances of the same component, instances of the component which are on layers which are off, as well as in an instance which is visible.
                  What is needed here is a entity identifier which include the "path" to get to the entity, so it truly represents a single unique entity in terms of the display.
                  Al Hart
                  IRender nXt from Render Plus
                    cjthompson
                    I think I would like at least these two to be part of the view object, and pass in an entity, not on the entity itself.
                      maxim1000
                      It seems visible? and !hidden? are not the same...
                      I've attached model. visible?==!hidden? for all entities except the deepest one.
                      Here is log from my Ruby window:
                      m=Sketchup.active_model #<Sketchup::Model:0xb2ce678> m.entities[0].definition.entities[0].definition.visible? true m.entities[0].definition.entities[0].definition.hidden? true
                      and from my observation visible? is closer to the truth πŸ˜„
                      aaa.skp
                        You are testing the definition - definitions are not placed in the model and therefore can't be visible or hidden. ComponentInstances are what you need to test against.
                          maxim1000
                          Thanks for this remark, I'll adjust my code.
                          Since ComponentDefinition is inherited from Drawingelement, calling visible? and hidden? seems not to be some incorrect operation leading to undefined behaviour. Yes, they may not represent actual state of geometry, but this shows that visible? is not the same as !hidden? at least at implementation level, and thus can it be safely assumed that they are the same in all other cases?
                            (code.google.com)
                            The visible= method is used to set the visible status for an element. This method performs an opposite function to the hidden= method.
                            Might be that the definition class causes an abnormality. Testing against any other DrawingElement derived class that actually is placed in the model they behave as expects. Though it is odd it should return true on both for definition.
                            In practice - they do refer to the same thing though.
