    Entity.visible? vs entity.hidden?
    21 Posts 8 Posters 2.5k Views 8 Watching
    • Al HartA Offline
      Al Hart
      Does anyone know it there is a difference between using
      if (entity.hidden?)
      or
      if (!entity.visible?)
      That is: Do they refer to the same thing, or does visible refer to other things (such as in an invisible layer, off screen, or something else I am not thinking of)?
      Al Hart
      IRender nXt from Render Plus
        MartinRinehart
        Did a quick test: e.visible? reports true when e.hidden? reports false. Looks like a bug. If e is on an invisible layer I'd like e.visible? to report false, no?
          They are the opposite of the same thing. Think it's just so you can use whatever version reads the best in the given situation.
          And it refer to the Hidden property which you see in the Entity Info window.
          To check if a entity is truly hidden or visible you need to check
          entity.hidden? || entity.layer.hidden?
          or
          entity.visible? && entity.layer.visible?
          • Al HartA Offline
            Al Hart
            I wrote this routine to determine if an entity is truly visible.
            It gets tricky because an entity in a nested group/component is invisible of any of the layers of the parents is off, (except for Layer0 which is always on in a component or group even if it is off at the top level).
            In included both entity.hidden? and !entity.visible? - which is probably redundant.
            	def is_enitity_visible_in_sketchup(entity)
            		#printf("is_enitity_visible_in_sketchup; %s\n", entity.layer.name)
            		return false if entity.hidden?
            		return false if !entity.visible?
            		# Layer0 is only invisible at the top level
            		if (entity.parent.class == Sketchup;;Model)
            			return false if !entity.layer.visible?
            		else
            			if (entity.layer.name != "Layer0")
            			end#if
            			#make sure each parent is visible
            			parent = entity.parent
            			while (parent.class != Sketchup;;Model)
            				return false if parent.layer.name != "Layer0" && !parent.layer.visible?
            				parent = parent.parent
            			end#while loop
            		end#if
            		#printf("is_enitity_visible_in_sketchup; %s   return true\n", entity.layer.name)
            		return true
            	end#def
            Al Hart
              entity.parent will return the definition or model where the entity is contained. It will never return the component instance or group instance.
              • Al HartA Offline
                Al Hart
                You are right.
                In our routines where we actually try to determine whether an entity is visible or not, we are drilling down into components and groups, and we keep a list of layer names as we drill down.
                I have never really started with a specific entity in a nested set of groups and components and tried to drill up before.
                Is there an easy way to find out what the containing instance is when you have an entity in a component instance of group? If not, then I will have to be careful to always keep track of layers and visibility as I drill down into the model.
                Al Hart
                  I think this is one major issue with the SU structure and APIs. There's no way to backtrace. I think you would actually have to build a full tree list of the entities to be able to traverse backwards like this.
                  • Al HartA Offline
                    Al Hart
                    OK - thanks thomthom.
                    Everyone else - forget most of this thread - except the original question"
                    is entity.hidden? the same as !entity.visible (notice the ! sign)
                    And therefore should I save time and keystrokes by only using one of them?
                    I believe they both refer the the hidden state, and have nothing to do with layer visibility.
                    Al Hart
                      I understood that [probably wrongly]...
                      An object is hiddenif its set to be 'hidden' - i.e. not to be seen.
                      An object is visibleif it is on layer that's switched 'on'... 😕 ?
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=23806#p202821 😉
                          You are right [as thomthom said] entity.hidden? is the same as !entity.visible
                          You can also toggle entity.hidden=true/false and entity.visible=false/true
                            MartinRinehart
                            Any reason not to declare visible? a bug?
                              I think the reply you would get is "By design".
                              From the manual on Drawingelement.visible=:
                              This method performs an opposite function to the hidden= method.
                              http://code.google.com/apis/sketchup/docs/ourdoc/drawingelement.html#visible=
                              I think a feature request for a different method that will return to whether the entity can be seen in the model or not is what we'd need to make. Drawingelement.seen? maybe? And more importantly, a method that will let us dig down backwards in the hierarchy of the entity tree.
                              • Chris FullmerC Offline
                                Yeah, because maybe its actually hidden? that's a bug 😄
                                Ruby likes to have duplicate methods for the same process. Seems like many methods are available in the positive and negative form.
                                  Jim
                                  Except that hidden and visible are real attributes of objects, and should not have been used as aliases. Using visible as an alias for not hidden is crap. Leave the sugar out of the API.
                                  • Al HartA Offline
                                    Al Hart
                                    At this point, if they some changed what it meant, it would break any scripts which were using it to mean "not hidden".
                                    However, it would be nice if they added 1 to 3 of these new functions:
                                    entity.is_visible? - not hidden, and not on a layer which is hidden (including groups and sub-components which are hidden or on layers which are hidden)
                                    entity.is_in_current_view - is_visible? and also is visible in current camera view
                                    entity.is_obstructed - is visible? but is behind something else which is not transparent.
                                    The last two are pie-in-the-sky, but the first one would be a useful function.
                                    However, as I write this I see that part of the problem is what is meant by an entity. As I drill down through the database and think I am pointed at a single, unqiue entity, I am often pointed to an entity in a component definition, which, if the component is used more than once may be in hidden instances of the same component, instances of the component which are on layers which are off, as well as in an instance which is visible.
                                    What is needed here is a entity identifier which include the "path" to get to the entity, so it truly represents a single unique entity in terms of the display.
                                    Al Hart
                                      cjthompson
                                      I think I would like at least these two to be part of the view object, and pass in an entity, not on the entity itself.
                                        maxim1000
                                        It seems visible? and !hidden? are not the same...
                                        I've attached model. visible?==!hidden? for all entities except the deepest one.
                                        Here is log from my Ruby window:
                                        m=Sketchup.active_model #<Sketchup::Model:0xb2ce678> m.entities[0].definition.entities[0].definition.visible? true m.entities[0].definition.entities[0].definition.hidden? true
                                        and from my observation visible? is closer to the truth 😄
                                        aaa.skp
                                          You are testing the definition - definitions are not placed in the model and therefore can't be visible or hidden. ComponentInstances are what you need to test against.
                                            maxim1000
                                            Thanks for this remark, I'll adjust my code.
                                            Since ComponentDefinition is inherited from Drawingelement, calling visible? and hidden? seems not to be some incorrect operation leading to undefined behaviour. Yes, they may not represent actual state of geometry, but this shows that visible? is not the same as !hidden? at least at implementation level, and thus can it be safely assumed that they are the same in all other cases?
