    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 67.8k Views 42 Watching
      paulbarton
      I have an issue whereby the initial move does not seem to register. If i then do another move, and undo it (!) the mesh jumps to the previous position. And just to make matters worse, this only happens intermittently!
        kirill2008
        @mitcorb said:
        Can this script recognize and utilize construction/control points placed by another ruby script?
        This is an interesting idea. You mean you want to select a set of existing c-points + geometry group then make c-points not just c-points, but control c-points. I think it's possible, but it is not implemented yet in the current version.
          kirill2008
          Speaking of undo: the work on improving 'undo' behavior is in progress (I want to make it more 'natural', not sure if I can but I'll try). In the current version it is necessary to make undo several times to get everything to the initial state.
          Note: it is not necessary to wait until geometry transformation finishes, you may undo previous c-point movement while the group refreshes.
          For example, you moved c-point, then immidiately decided to get everything back: press 'ctrl+z' combination 3-times immediately to get the c-point back and to cancel group transformation.
          I'll try to find out why the initial move does not seem to register.
          • mitcorbM Offline
            mitcorb
            Kirill:
            On the outside c-points question, I thought I had a ruby script loaded prior to install of that placed construction points. I cannot find it now. What I did not fully realize is that cpoints could mean construction point or control point. Evidently your cpoints do more than simply highlight a target point in space.
            Sooo-- maybe my question was a bit naive.
            But thanks for the reply.
            I am putting this script through some modeling tests to learn its use.
            Thanks for the opportunity.
            mitcorb
              kirill2008
              But it gave a good idea!
              I think that it can be a kind of alternative to 'entity scanner' (it was discussed here: http://forums.sketchucation.com/viewtopic.php?f=323&t=22709&st=0&sk=t&sd=a#p191629 ). So it would be possible to link control c-points back manually to groups and/or curves after closing and opening the file. And it would be also possible to link any existing c-points to any group.
              What do you think?
              • mitcorbM Offline
                mitcorb
                Wouldn't the plain old cpoints that may have been inserted in the model prior to running this plugin have to change their status to Control cpoints? Could your plugin look for pre-existing cpoints(construction points) and change them?
                Just in case you understand- I do not have any Ruby expertise -yet.
                • CarrozzaC Offline
                  Carrozza
                  Thanks for the update Kirill! ☀
                  • EarthMoverE Offline
                    EarthMover
                    HOLY SHIT!!!! Sorry...but after watching how fast you deformed that toilet in the 3rd video, I'm completely slack jawed. FFD on super steroids! I'm boggled by the speed krill. I think if the core group of power scripters got together, you guys could cause global revolution. Amazing stuff....Blend, 2 faces and a path and this script...all tremendously powerful, super fast and have post operation editing capabilities. I wish every script performed as fast. I don't know jack about coding, but your work deserves a shot and a beer!
                    Content Creator at Skapeup
                      KXI System
                      Very nice!
                      Getting the perfect sig is hard...
                      Google it!
                        kirill2008
                        I guess, I got it now
                        http://smiles.kolobok.us/standart/ok.gif
                        http://smiles.kolobok.us/big_standart/drinks.gif
                        • Y Offline
                          Yanman
                          Wow this is amazing Plugin
                          thank you 👍 👍 👍
                          • EscapeArtistE Offline
                            EscapeArtist
                            Error; #<TypeError; reference to deleted Group>
                            L;/Modeling/Sketchup Google/Plugins/ctrlpnts.rb;214;in `entities'
                            L;/Modeling/Sketchup Google/Plugins/ctrlpnts.rb;214;in `deform_group'
                            L;/Modeling/Sketchup Google/Plugins/ctrlpnts.rb;213;in `call'
                            L;/Modeling/Sketchup Google/Plugins/bezier.rb;395
                            ...and on and on and on.
                            I noticed that after deleting a surface that I'd applied control points to I got this going on in my Ruby window ad infinitum, it's going so fast I had a hard time even copying it.
                            I got this to happen by creating a surface, applying control points, using them to deform the surface (with a couple of "undos") and then deleting the surface. Only way to get it to stop was to restart SU.
                            • X Offline
                              xrok1
                              this is getting better and better
                              now all we need is a visual representation (ideally interactive 😉 ) for the weight.
                                kirill2008
                                Thanks for the report. I'll try to fix it as soon as possible.
                                  kirill2008
                                  Well, I think, it's possible
                                  http://kolobok.us/smiles/standart/yes4.gif
                                  , why not.
                                  • X Offline
                                    xrok1
                                    , why not.
                                    😲 don't tease.
                                      EarthMover
                                      Krill, would it be possible to have an option to place a cage of control points on a mesh? Perhaps one FFD style cage box option for people used to that method and another that would place evenly distributed control points which would conform around the mesh at a given distance. You're already 80% of the way to a new type of Free Form Deformation plugin, might as well go all the way and improve on the existing.
                                      • X Offline
                                        xrok1
                                        yes that would be great since FFD thread says "Unfortunately, I am out of time to work on this script. If anyone wants to pick it up contact me. The code is simple and (for me) well commented. It needs a UI and bug fixes." and doesn't seem to be progressing. 👍
                                          kirill2008
                                          Preview of interaction capabilities of ver. 1.6. (will be ready in the coming days).
                                          Set of 4 videos:
                                          [flash=480,385:lwr4hh5j]http://www.youtube.com/p/51499EA555BCA0CC&amp;hl=ru_RU&amp;fs=1" type="application/x-shockwave-flash" width="480" height="385" allowscriptaccess="always" allowfullscreen="true"[/flash:lwr4hh5j]
                                          In case if someone wants to try prerelease version:
                                          ver. 1.6. (prerelease)
                                            dedmin
                                            Ой! Кажется какая то "волшебная" водка дает тебе творческие силы!
                                            • 3 / 6
