    [Plugin] Control points ver. 1.6.
    115 Posts 42 Posters 74.8k Views 42 Watching
      REGIS
      @xrok1 said:
      i would love to be able to select more than 1 point at a time though(wouldn't need FFD anymore)
      Not sure I wouldn't need FFD anymore, I was thinking in a combination with control points and FFD
      @ Kirill
      Any idea if this plugin could work in SU7 on mac ?
      Cheers
      • X
        xrok1
        @aceshigh said:
        @xrok1 said:
        can't beleive i missed this one! f'n incredible.
        as far as I know, you can select more than 1 point at a time.
        well i tried making a cylinder; putting a point on each side, then scaling so they got further apart? it allways tends to pull more to one than the other.
        • EarthMoverE
          EarthMover
          TIG, got a DIY quick fix for one step undo?
          Content Creator at Skapeup
          • P
            paulbarton
            I have an issue whereby the initial move does not seem to register. If i then do another move, and undo it (!) the mesh jumps to the previous position. And just to make matters worse, this only happens intermittently!
            • K
              kirill2008
              @mitcorb said:
              Can this script recognize and utilize construction/control points placed by another ruby script?
              This is an interesting idea. You mean you want to select a set of existing c-points + geometry group then make c-points not just c-points, but control c-points. I think it's possible, but it is not implemented yet in the current version.
              • K
                kirill2008
                Speaking of undo: the work on improving 'undo' behavior is in progress (I want to make it more 'natural', not sure if I can but I'll try). In the current version it is necessary to make undo several times to get everything to the initial state.
                Note: it is not necessary to wait until geometry transformation finishes, you may undo previous c-point movement while the group refreshes.
                For example, you moved c-point, then immidiately decided to get everything back: press 'ctrl+z' combination 3-times immediately to get the c-point back and to cancel group transformation.
                I'll try to find out why the initial move does not seem to register.
                • mitcorbM
                  mitcorb
                  Kirill:
                  On the outside c-points question, I thought I had a ruby script loaded prior to install of that placed construction points. I cannot find it now. What I did not fully realize is that cpoints could mean construction point or control point. Evidently your cpoints do more than simply highlight a target point in space.
                  Sooo-- maybe my question was a bit naive.
                  But thanks for the reply.
                  I am putting this script through some modeling tests to learn its use.
                  Thanks for the opportunity.
                  mitcorb
                  • K
                    kirill2008
                    But it gave a good idea!
                    I think that it can be a kind of alternative to 'entity scanner' (it was discussed here: http://forums.sketchucation.com/viewtopic.php?f=323&t=22709&st=0&sk=t&sd=a#p191629 ). So it would be possible to link control c-points back manually to groups and/or curves after closing and opening the file. And it would be also possible to link any existing c-points to any group.
                    What do you think?
                    • mitcorbM
                      mitcorb
                      Wouldn't the plain old cpoints that may have been inserted in the model prior to running this plugin have to change their status to Control cpoints? Could your plugin look for pre-existing cpoints(construction points) and change them?
                      Just in case you understand- I do not have any Ruby expertise -yet.
                      • CarrozzaC
                        Carrozza
                        Thanks for the update Kirill! ☀
                        • EarthMoverE
                          EarthMover
                          HOLY SHIT!!!! Sorry...but after watching how fast you deformed that toilet in the 3rd video, I'm completely slack jawed. FFD on super steroids! I'm boggled by the speed krill. I think if the core group of power scripters got together, you guys could cause global revolution. Amazing stuff....Blend, 2 faces and a path and this script...all tremendously powerful, super fast and have post operation editing capabilities. I wish every script performed as fast. I don't know jack about coding, but your work deserves a shot and a beer!
                          • K
                            KXI System
                            Very nice!
                            Getting the perfect sig is hard...
                            Google it!
                            • K
                              kirill2008
                              I guess, I got it now
                              http://smiles.kolobok.us/standart/ok.gif
                              http://smiles.kolobok.us/big_standart/drinks.gif
                              • Y
                                Yanman
                                Wow this is amazing Plugin
                                thank you 👍 👍 👍
                                • EscapeArtistE
                                  EscapeArtist
                                  Error; #<TypeError; reference to deleted Group>
                                  L;/Modeling/Sketchup Google/Plugins/ctrlpnts.rb;214;in `entities'
                                  L;/Modeling/Sketchup Google/Plugins/ctrlpnts.rb;214;in `deform_group'
                                  L;/Modeling/Sketchup Google/Plugins/ctrlpnts.rb;213;in `call'
                                  L;/Modeling/Sketchup Google/Plugins/bezier.rb;395
                                  ...and on and on and on.
                                  I noticed that after deleting a surface that I'd applied control points to I got this going on in my Ruby window ad infinitum, it's going so fast I had a hard time even copying it.
                                  I got this to happen by creating a surface, applying control points, using them to deform the surface (with a couple of "undos") and then deleting the surface. Only way to get it to stop was to restart SU.
                                  • X
                                    xrok1
                                    this is getting better and better
                                    now all we need is a visual representation (ideally interactive 😉 ) for the weight.
                                    • K
                                      kirill2008
                                      Thanks for the report. I'll try to fix it as soon as possible.
                                      • K
                                        kirill2008
                                        Well, I think, it's possible
                                        http://kolobok.us/smiles/standart/yes4.gif
                                        , why not.
                                        • X
                                          xrok1
                                          , why not.
                                          😲 don't tease.
                                          • EarthMoverE
                                            EarthMover
                                            Krill, would it be possible to have an option to place a cage of control points on a mesh? Perhaps one FFD style cage box option for people used to that method and another that would place evenly distributed control points which would conform around the mesh at a given distance. You're already 80% of the way to a new type of Free Form Deformation plugin, might as well go all the way and improve on the existing.
                                            • 3 / 6
