    [Plugin] Component Spray Tool 1.3.
    92 Posts 44 Posters 103.6k Views 44 Watching
    • Chris FullmerC
      Any thoughts on my requests Didier? Look back a few posts. Especially the first one. It's really important to my workflow. Would it be possible to include? Thanks for looking,
      • Didier BurD
        Didier Bur
        Yes, it is possible to include your requests, but you'll have to be patient πŸŽ‰
        I'm on a huge project now and I'm afraid I must leave my freebies as they are for a couple of weeks...
        DB
        • Chris FullmerC
          Oh I can be patient πŸ˜„ I just wanted to make sure you saw my thoughts and would see if they were good ideas or useless. Thanks for looking at it Didier, you're the best!
            sbthomas
            Gaieus & Didier;
            Using your suggestions I have been able to overcome the issue of spraying in the valleys of GE snapshots. The process is as follows:
            Get GE snapshot
            toggle terrain
            save-as "snapshotname"
            unlock terrain
            explode terrain
            edit>copy terrain
            file>new sketchup project
            edit>paste-in-place
            insert component
            spray component
            delete terrain
            import saved snapshot
            place model back to GE
            thanks again for your help.
            STAN
            • GaieusG
              Hi Stan,
              In order to make sure your original terrain remains intact,after the step where you copy it,you can just undo the steps in the original model (the copied version will remain on the clipboard and you can use the paste in place command in the new model to spray the components).
                This is one of my absolute favourite rubies. I just detailed a large terrain model with 4000 trees in no time. I would never have gotten such a rich detail to it manually.
                • Chris FullmerC
                  Hi Didier, I have found that this script is conflicting with progressbar.rb, and therefore crashing all scripts that are using progressbar (makefaces in particular!, but I found the problem while developing my own script). There is a pb.update() method in the progressbar that seems to not work so I'm guessing that is where the conflict is - but I could be WAAAAY off. Thanks Didier!
                  I was wondering if anyone else could confirm this?
                    Does it make use of the disable UI argument for .start_operation ?
                    • Didier BurD
                      Didier Bur
                      No.
                      Is there still a conflict with progressbar ? πŸ‘Š
                      I changed the class and methods names to get rid of any conflict in the latest version released. 😲
                      DB
                        It'd be interesting to see what speed this plugin worked at with the SU UI disabled. Any chance of an updated version?
                        • Chris FullmerC
                          Nope! It is working great now with progressbar. Thanks for fixing it so quickly too,
                            milfot
                            Wow, this plugin is fantastic!!
                            Much appreciated... i am off to build a forest.
                            ..cam
                              denna003
                              THAnk you very much!!!! πŸ˜‰
                                AcesHigh
                                Didier, is this the last version of your tool?
                                Can I make a suggestion? It seems the altitude option is too "hard". I mean, I think you could add some dialogue to add a % of chance that components will spray below and above the maximum altitude. That way, they will concentrate on the set altitude, but some of them will spread casually beyond (unless you set the chance of that happening to 0%)
                                • T
                                  tomislavm
                                  Thank You!
                                  Where in Croatia?
                                    madhav
                                    Thanks a lot
                                    • Didier BurD
                                      Didier Bur
                                      Where in Croatia?
                                      Pisak, that's 40kms South of Split and 20kms North of Makarska.
                                      DB
                                      • T
                                        tomislavm
                                        Nice place for vacation!
                                          alsenhawk
                                          Thank you,that's what i m looking~
                                            arjunmax09
                                            @rv1974 said:
                                            Didier thanks for your efforts!
                                            One can get interesting things with new vertice mode.
                                            http://img212.imageshack.us/img212/6828/screenshot060qi3.jpg
                                            [URL=http://g.imageshack.us/g.php?h=212&i=screenshot060qi3.jpg][IMG]http://img212.imag
                                            But there's bug in vertex+no to keep vertical . It's not working (see lonely cylinder over mesh, in all other cases components stay vertical)
                                            To "keep vertical" unchecked will result the component to be placed vertical to mesh, it'll work this way, right?
                                            P.S. I'm not programmer (my wife is- it's enough for one family) but you're one step from "spray along vertices of curve" ? πŸ˜‰
                                            P.P.S. Do you shine in ruby field only or there are some lisp routins of yours?
                                            hey!!! how did you create the cool DNA model man???!!!... i mean the perfect spiral thing... which plugin did you use???
                                            when you fail at something....you haven't really failed...you've found one way the thing will not work out
                                            • 3 / 5
