    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 262.6k Views 32 Watching
      rod1233
      I did that and the problem is still.
      Note: Windows in English, and also to the program in English
      I remembered something: when it succeeded for the first time you change the course of exporting images to another folder on the desktop.
      Does this lead to error
      rod
      • Chris FullmerC Offline
        Could you zip up your plugins folder and send me a copy please. Please remove other plugins first too. I don't need a copy of all your othe plugins you might have. Just mine. I'd like to see how its installed, and then I'll put it in my system just like you have it and see if I get the same errors.
          rod1233
          Here's what you requested
          This folder contains the files
            rod1233
            Where are you?
            I hope you of what is new
            rod
              rod1233
              Where are you?
              rod
                rod1233
                  Sorry I missed your post yesterday. Somehiw I did not see it, sorry Rod. I have the files now and I am looking at them (I deleted the .rar file from your post alre4ady, but I downloaded it first).
                    OK, it is all installed right, thanks you so much for uploading that.
                    One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
                    PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
                    • PixeroP Offline
                      Pixero
                      Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
                      It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
                      Pleeeeaaase? πŸ˜„
                        rod1233
                        hi Chris
                        Thank you for your patience.
                        But unfortunately the problem did not end
                        I barely said Volkswagen .. Strangely in the topic I have done a test it for four days and then I got this problem
                        I do not know why and Hoahal
                        In any case sent you the file again
                        Please try to help
                          rod1233
                          Emerged within the tool ( System preferencec )
                          But the need to activate the
                          I tried hard to no avail
                            Great, we're getting closer to solving it.
                            After you try to initilize it, make sure to also go to View > Toolbars > Camera Recoder
                            You must make sure the toolbar is turned on too.
                            Plus all the tools are availabe in Plugins > Chris Fullmer Tools > Camera Recorder
                            Check those things to see if that gets it working,
                              rod1233
                              Did not show the tool in the tool bar
                              But emerged in the preferences
                                ok, so the loader file is loading, and its trying to load the script, but its failing. I have a few ideas how to fix that. Your XP is having issues with the path's for some reason. BUt I think I know how to fix it. Let me see what I can do.
                                  rod1233
                                  I do not have Windows XP
                                  I have a Windows Vista
                                    rod1233
                                    Soil you have the file on the Windows XP has been success with ease
                                    But Windows Vista is still the problem
                                      Very odd. I write these plugins on a Vista system, and use them at work on an XP system.
                                      I'll keep digging. I might have a new file for you to try in a few hours.
                                        rod1233
                                        Waiting for the new my friend
                                        All thanks to you and your efforts
                                          Sorry Rod, I've been sick and have not been doing too much.
                                          So I don't know what the problem is, but these scripts open the ruby concole while the scripts are loading, so we can see any load errors. So please overwrite the existing files with these. And copy any text that gets written to the ruby console when SketchUp is starting. Then paste that code back here.
                                            rod1233
                                            This was the result
                                            • 3 / 7
