    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 277.6k Views 32 Watching
      rod1233
      Hi Chris
      I think I could not explain the problem. Although attaching the image.
      When do I paste the files in the desired place, and I do open the program I get this window described the picture attached
      Hee this problem. 😞
      Please note that I had originally succeeded in doing so for two days. And then I got this problem without any reason
      Tried to get rid of this problem but to no avail
      Thank you
      • Chris FullmerC
        I have a new thought Rod. I bet it is a problem with "compatibility files".
        Go to the Plugins folder and look at the top for "compatibility files" click on that. It is a secret alternate version of your plugins folder (I'm serious). If there is anything about camera recorder in there, make sure to delete it! all files and folders.
        Then see if SketchUp works right. If not, try deleteing all camera recorder files in the regular plugins fodler, double check that the compatibility files folder also has no camera recorder files.
        Then once you are sure there are no camera recorder files or folders, then reinstall them.
        Then check in sketchup. I have a feeling this will solve it. Windows compaitiblity files has cause this problem more than once.
          rod1233
          Hi Chris
          Thank you for the efforts
          It tried to explained to me earlier.
          But unfortunately the problem still exists. 😞 😞 😞
          Please search for a solution
          rod
          • Chris FullmerC
            Hi Rod, please verify that you tried the Compatibility files suggestions. Your response does not state that you tried it.
            Next, remove all other plugins from your plugins folder. Install only the camera recorder plugin. See if that works. Then we can go from there.
              rod1233
              Hi Chris
              I've done it and you delete all the contents of the folder plugins
              And you do Install only the camera recorder plugin.
              But the problem is not over yet
              rod
              • charly2008C
                charly2008
                Chris, your camera tool is first class.
                You don't need Quick time Pro. There is a freeware player who plays image sequences also. The name is IMAGEN.
                http://gromada.com/download.html
                Supported formats:
                AC3, Dolby Digital compatible
                AVI / DIVX / IVF, Windows Audio Video Interleaved
                BAY, Bayer Image
                BMP / DIB, Windows Device Independent Bitmap
                CINE, Vision Research CINE, (read/uncompressed only)
                FLC / FLI, Autodesk FLIC/FLIC-Pro
                GIF, Graphics Interchange Format
                HAV, High quality Audio Video
                JP2, JPEG-2000 File Format / CodeStream
                JPEG, Joint Photographic Expert Group
                MPA / MP2 / MP3, MPEG-1/2 Audio Layer II/III (MP3 read only)
                MPEG, Moving Pictures Expert Group, MPEG-1/2
                OGG, OggVorbis Audio
                OGV, OggVorbis Video/Audio
                PCX, Zsoft Paintbrush
                PNG, Portable Network Graphics
                PNM / PPM, Portable Image
                RAS / SUN, Sun Raster Image
                RGB / SGI, Silicon Graphics Image
                TGA, Truevision Targa
                TIFF, Tagged Image File Format
                WAV, Windows Wave Sound
                * WMA, Windows Media Audio
                * WMV, Windows Media Video
                XPM, X-Pixmap
                • Chris FullmerC
                  @rod1233 said:
                  Hi Chris
                  rod
                  Great, thanks for trying that. Could you please take another screenshot of your plugins folder and inside the clf_camera_recorder folder.
                  Also, does the file path to your sketchup program contain any non-english standard characters? I know russian language characters might cause problems with things.
                  • Chris FullmerC
                    Great Charly, I'll post a link to that software in the first post of this thread. Thanks for finding it!
                      rod1233
                      I did that and the problem is still.
                      Note: Windows in English, and also to the program in English
                      I remembered something: when it succeeded for the first time you change the course of exporting images to another folder on the desktop.
                      Does this lead to error
                      rod
                      • Chris FullmerC
                        Could you zip up your plugins folder and send me a copy please. Please remove other plugins first too. I don't need a copy of all your othe plugins you might have. Just mine. I'd like to see how its installed, and then I'll put it in my system just like you have it and see if I get the same errors.
                          rod1233
                          Here's what you requested
                          This folder contains the files
                            rod1233
                            Where are you?
                            I hope you of what is new
                            rod
                              rod1233
                              Where are you?
                              rod
                                rod1233
                                • Chris FullmerC
                                  Sorry I missed your post yesterday. Somehiw I did not see it, sorry Rod. I have the files now and I am looking at them (I deleted the .rar file from your post alre4ady, but I downloaded it first).
                                  • Chris FullmerC
                                    OK, it is all installed right, thanks you so much for uploading that.
                                    One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
                                    PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
                                    • PixeroP
                                      Pixero
                                      Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
                                      It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
                                      Pleeeeaaase? πŸ˜„
                                        rod1233
                                        hi Chris
                                        Thank you for your patience.
                                        But unfortunately the problem did not end
                                        I barely said Volkswagen .. Strangely in the topic I have done a test it for four days and then I got this problem
                                        I do not know why and Hoahal
                                        In any case sent you the file again
                                        Please try to help
                                          rod1233
                                          Emerged within the tool ( System preferencec )
                                          But the need to activate the
                                          I tried hard to no avail
                                          • Chris FullmerC
                                            Great, we're getting closer to solving it.
                                            After you try to initilize it, make sure to also go to View > Toolbars > Camera Recoder
                                            You must make sure the toolbar is turned on too.
                                            Plus all the tools are availabe in Plugins > Chris Fullmer Tools > Camera Recorder
                                            Check those things to see if that gets it working,
                                            • 4 / 7
