    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 277.6k Views 32 Watching
    • Chris FullmerC
      No, you don't need podium installed. I had seen in another thread that it might complicate you mac installation folders or something.
      So I would say that the best thing to do now would be to send a upload a screenshot of your plugins folder, and maybe one of the inside of the clf_camera_recorder folder also.
        rod1233
        Hi Chris
        I think I could not explain the problem. Although attaching the image.
        When do I paste the files in the desired place, and I do open the program I get this window described the picture attached
        Hee this problem. 😞
        Please note that I had originally succeeded in doing so for two days. And then I got this problem without any reason
        Tried to get rid of this problem but to no avail
        Thank you
        • Chris FullmerC
          I have a new thought Rod. I bet it is a problem with "compatibility files".
          Go to the Plugins folder and look at the top for "compatibility files" click on that. It is a secret alternate version of your plugins folder (I'm serious). If there is anything about camera recorder in there, make sure to delete it! all files and folders.
          Then see if SketchUp works right. If not, try deleteing all camera recorder files in the regular plugins fodler, double check that the compatibility files folder also has no camera recorder files.
          Then once you are sure there are no camera recorder files or folders, then reinstall them.
          Then check in sketchup. I have a feeling this will solve it. Windows compaitiblity files has cause this problem more than once.
            rod1233
            Hi Chris
            Thank you for the efforts
            It tried to explained to me earlier.
            But unfortunately the problem still exists. 😞 😞 😞
            Please search for a solution
            rod
            • Chris FullmerC
              Hi Rod, please verify that you tried the Compatibility files suggestions. Your response does not state that you tried it.
              Next, remove all other plugins from your plugins folder. Install only the camera recorder plugin. See if that works. Then we can go from there.
                rod1233
                Hi Chris
                I've done it and you delete all the contents of the folder plugins
                And you do Install only the camera recorder plugin.
                But the problem is not over yet
                rod
                • charly2008C
                  charly2008
                  Chris, your camera tool is first class.
                  You don't need Quick time Pro. There is a freeware player who plays image sequences also. The name is IMAGEN.
                  http://gromada.com/download.html
                  Supported formats:
                  AC3, Dolby Digital compatible
                  AVI / DIVX / IVF, Windows Audio Video Interleaved
                  BAY, Bayer Image
                  BMP / DIB, Windows Device Independent Bitmap
                  CINE, Vision Research CINE, (read/uncompressed only)
                  FLC / FLI, Autodesk FLIC/FLIC-Pro
                  GIF, Graphics Interchange Format
                  HAV, High quality Audio Video
                  JP2, JPEG-2000 File Format / CodeStream
                  JPEG, Joint Photographic Expert Group
                  MPA / MP2 / MP3, MPEG-1/2 Audio Layer II/III (MP3 read only)
                  MPEG, Moving Pictures Expert Group, MPEG-1/2
                  OGG, OggVorbis Audio
                  OGV, OggVorbis Video/Audio
                  PCX, Zsoft Paintbrush
                  PNG, Portable Network Graphics
                  PNM / PPM, Portable Image
                  RAS / SUN, Sun Raster Image
                  RGB / SGI, Silicon Graphics Image
                  TGA, Truevision Targa
                  TIFF, Tagged Image File Format
                  WAV, Windows Wave Sound
                  * WMA, Windows Media Audio
                  * WMV, Windows Media Video
                  XPM, X-Pixmap
                  • Chris FullmerC
                    @rod1233 said:
                    Hi Chris
                    rod
                    Great, thanks for trying that. Could you please take another screenshot of your plugins folder and inside the clf_camera_recorder folder.
                    Also, does the file path to your sketchup program contain any non-english standard characters? I know russian language characters might cause problems with things.
                    • Chris FullmerC
                      Great Charly, I'll post a link to that software in the first post of this thread. Thanks for finding it!
                        rod1233
                        I did that and the problem is still.
                        Note: Windows in English, and also to the program in English
                        I remembered something: when it succeeded for the first time you change the course of exporting images to another folder on the desktop.
                        Does this lead to error
                        rod
                        • Chris FullmerC
                          Could you zip up your plugins folder and send me a copy please. Please remove other plugins first too. I don't need a copy of all your othe plugins you might have. Just mine. I'd like to see how its installed, and then I'll put it in my system just like you have it and see if I get the same errors.
                            rod1233
                            Here's what you requested
                            This folder contains the files
                              rod1233
                              Where are you?
                              I hope you of what is new
                              rod
                                rod1233
                                Where are you?
                                rod
                                  rod1233
                                  • Chris FullmerC
                                    Sorry I missed your post yesterday. Somehiw I did not see it, sorry Rod. I have the files now and I am looking at them (I deleted the .rar file from your post alre4ady, but I downloaded it first).
                                    • Chris FullmerC
                                      OK, it is all installed right, thanks you so much for uploading that.
                                      One last idea. Try this loader script. Just overwrite the existing clf_camera_recorder_loader.rb file with the attached one. Let me know if that works,
                                      PS - this file is not MAC friendly. I think it will break the script if anyone on a Mac downloads it.
                                      • PixeroP
                                        Pixero
                                        Chris, have you tried LightUp? Could you implement a flyaround mode with inertia like in LightUp?
                                        It would be so great to fly around smoothly and record scenes and then use that for both SU lines and LightUp.
                                        Pleeeeaaase? πŸ˜„
                                          rod1233
                                          hi Chris
                                          Thank you for your patience.
                                          But unfortunately the problem did not end
                                          I barely said Volkswagen .. Strangely in the topic I have done a test it for four days and then I got this problem
                                          I do not know why and Hoahal
                                          In any case sent you the file again
                                          Please try to help
                                            rod1233
                                            Emerged within the tool ( System preferencec )
                                            But the need to activate the
                                            I tried hard to no avail
                                            • 4 / 7
