    SketchUp Thumbnails not showing up?
    30 Posts 16 Posters 24.7k Views 16 Watching
    • G
      gistman
      Ahh... good, there is a solution- But doesn't it just seen odd, they were there, then they weren't?!? I was thinking originally that running CCleaner may have had something to do with it... It's also strange that the thumbnails show up in the folder the .skp files are in (that just might me something else though). Also- I don't think my Photoshop files have ever shown a thumbnail.
      Oh- I just remembered this- Another thing that happened at the same time as my thumbnails disappearing was the addition of {view--> filmstrip) which I have never been a fan... I think there was a windows update around the same time as well... hmmmm...
      Worked for Photoshop! Funny it's not in there to begin with?
      Hmmm... How does it work for SU? There doesn't seem to be a Google\Google SketchUp 6 in the common files
      Thank you guys...
      Aaron
      • H
        HFM
        Maybe should have added that I work with Vista. Which, by my knowledge doesn't support SKP thumbnails from the start.
        • rodrigonotorR
          rodrigonotor
          psd files works great, thanks
          • Sketchando.net • www.arqcad.net •
          • G
            gistman
            Hmmm... so there isn't a "SUicon.dll" for SketchUp? Hmmm... I tried to 'reinstall / repair' SketchUp only to have it lock up...
            About the last thing I want to do is install and have to run another application, just to fix something which shouldn't have 'broken' in the first place... grrr.
            I guess it's time to contact The Google SketchUp people. "I'm a SketchUp Pro User and Want to Contact Support (Requires License)" - One good thing about having SU 'pro'? We'll see.
            EDIT- after doing a little research on google... I found this link--> http://support.microsoft.com/?scid=243401 but it's specifically for .jpg thumbnails- But when I looked at the .jpg reg. file, I noticed that it has information under the "Data" column (OISjpegfile,image/jpeg and image) where the .skp reg. file was left blank. hmmm... Gets kind of scary when you start modifying registry files, as I know just enough about computers to break them.
            Aa
            • TaffGochT
              TaffGoch
              gistman.
              Any help here (an old forum posting)?
              SU thumbnail display
              Taff
              "Information is not knowledge." -- Albert Einstein
              • G
                gistman
                Oh man... Damn- You know, as I remember I ran CCleaner, well you know why I ran CCleaner?... Because I had just UNINSTALLED SU5! I was thinking to myself... self, you haven't used SU5 in a year or so, why don't you just go ahead and free up some of that disk space...
                Going to try the fix that was posted by the google tech guy on page two- I'll let you guys know if it works... I saw someone else had the same issue as me and posted just a bit ago.
                We've been investigating the issue and have been offered a fix that may help. Kindly refer to the following steps:
                1. Click "Start" > "Run."
                2. Type "cmd" in the Open box and click "OK."
                3. Navigate to the SketchUp directory, which is typically located at C:\Program Files\Google\Google SketchUp 6\
                4. Type "regsvr32 thumbsup.dll" without quotes and hit Enter.
                Regards,
                Tommy
                and no- This didn't work... When you go to th cmd, which opens the windows\systems32\cmd.exe dialog box... How are you supposed to "navigate" got the SketchUp directory from there? And typing in "regsvr32 thumbsup.dll" I get "LoadLibrary("thumbsup.dll") failed- The specified module could not be found."
                hmmm... I'm stumped and now I have to go measure a house- fun fun.
                • TaffGochT
                  TaffGoch
                  @gistman said:
                  How are you supposed to "navigate" [to] the SketchUp directory from there?
                  gistman,
                  Once in the 'Command Prompt' box, type...
                  cd C:\Program Files\Google\Google SketchUp 6
                  ...and hit <Enter>
                  That will switch you to the correct folder. Keep reading in that discussion I posted. The above method didn't work for some other users, either. The order of install/uninstall for SketchUp 5 and 6 is critical, and is apparently the solution.
                  Taff
                  • G
                    gistman
                    TaffGoch- THANK YOU... IT WORKED! You know I tried typing that- and copy pasting it etc etc and it still didn't work- You have to include everything between the arrows
                    -->cd C:\Program Files\Google\Google SketchUp 6<--
                    ... and you can't 'ctrl v' either you have to right click and past at the control prompt... not sure what the "cd" part had to do with it but it worked- I NOW HAVE SU THUMBNAILS!
                    Thank you again.
                    (in the screen cap- I hit enter twice, that's why in at the prompt it's there two or three times- guess I got a little impatient)
                    • TaffGochT
                      TaffGoch
                      gistman,
                      For future reference, "cd" means "change directory" and is an old DOS command.
                      Taff
                      • N
                        nacholo
                        Thank you very much! I was on same problem and solve it with your explain.
                        Thanks and regard
                          masrulpilami
                          mmmh....excuse me....hehe but it doesnt work in my sketchup 7 in my windows 7 64 bit...someone please help me...
                            It won't work on any 64bit systems. The Explorer Shell extension for .skp thumbnails is 32bit only.
                              masrulpilami
                              ou..
                              so what must i do then? it's so hard for me to choosin component from component windows on sketchup...:/
                              do u have some suggestions for me? or i must change to 32 for now...?
                                When you use the Open file dialog in SU you will be able to see thumbnails as SU is a 32bit app. Ok workaround - instead of using the Explorer to locate the files?
                                • AnssiA
                                  Anssi
                                  XNView is a free image browser software that could display previews for SU files even before SU had the feature itself. Mine is old and it wouldn't do it for recent SU files, but there seems to be a newer one. Has anyone tried it with a 64-bit OS?
                                  Anssi
                                  • B
                                    bmunsell
                                    Hey thanks, it worked for me also except I had to change to sketchup 8 folder. By the way the "cd" stands for change directory and comes from the old dos commands
                                    • brodieB
                                      brodie
                                      Anssi
                                      The latest Xnview does show thumbnails (I'm on Win7). There's also mysticthumbs http://mysticcoder.net/mysticthumbs.html small fee but it works in explorer which is really handy.
                                      -brodie
                                      • N
                                        nicolerouillard
                                        Hey,
                                        This is all very interesting. Having trouble navigating to system32. This is the screen I get:
                                        • AnssiA
                                          Anssi
                                          @nicolerouillard said:
                                          Hey,
                                          You are not giving the system any commands. Typing directory names is not enough - as the error message you get shows.
                                          So you should type, followed by Enter (not the explanations I italicized)
                                          cd\ (this navigates to the root directory of the current drive)
                                          cd "c:\Program Files\Google\Google SketchUp 8" (this navigates to the SU application folder, the quotes are compulsory here)
                                          Note that this doesn't work if you have a 64-bit operating system.
                                          Anssi
                                            SpookyChick1013
                                            Thank you SO much Anssi! I haven't used dos commands in so many years I had forgotten critical little points like those you mentioned, and was struggling with implementing that fix, until I read your post. Now, I will have my thumbnails back, thank the Force!
                                            Cathryn
                                            https://kuromatsudriveyards.com
                                            Fo-su to tomo ni aran koto o...
