    SketchUp Thumbnails not showing up?
    30 Posts 16 Posters 24.0k Views 16 Watching
    • TaffGochT
      TaffGoch
      gistman,
      For future reference, "cd" means "change directory" and is an old DOS command.
      Taff
      "Information is not knowledge." -- Albert Einstein
      • N
        nacholo
        @gistman said:
        1. Click "Start" > "Run."
        2. Type "cmd" in the Open box and click "OK."
        3. Navigate to the SketchUp directory, which is typically located at C:\Program Files\Google\Google SketchUp 6\
        4. Type "regsvr32 thumbsup.dll" without quotes and hit Enter.
        Thank you very much! I was on same problem and solve it with your explain.
        Thanks and regard
          masrulpilami
          mmmh....excuse me....hehe but it doesnt work in my sketchup 7 in my windows 7 64 bit...someone please help me...
            It won't work on any 64bit systems. The Explorer Shell extension for .skp thumbnails is 32bit only.
              masrulpilami
              ou..
              so what must i do then? it's so hard for me to choosin component from component windows on sketchup...:/
              do u have some suggestions for me? or i must change to 32 for now...?
                When you use the Open file dialog in SU you will be able to see thumbnails as SU is a 32bit app. Ok workaround - instead of using the Explorer to locate the files?
                • AnssiA
                  Anssi
                  XNView is a free image browser software that could display previews for SU files even before SU had the feature itself. Mine is old and it wouldn't do it for recent SU files, but there seems to be a newer one. Has anyone tried it with a 64-bit OS?
                  Anssi
                  • B
                    bmunsell
                    Hey thanks, it worked for me also except I had to change to sketchup 8 folder. By the way the "cd" stands for change directory and comes from the old dos commands
                    • brodieB
                      brodie
                      Anssi
                      The latest Xnview does show thumbnails (I'm on Win7). There's also mysticthumbs http://mysticcoder.net/mysticthumbs.html small fee but it works in explorer which is really handy.
                      -brodie
                      • N
                        nicolerouillard
                        Hey,
                        This is all very interesting. Having trouble navigating to system32. This is the screen I get:
                        • AnssiA
                          Anssi
                          @nicolerouillard said:
                          Hey,
                          You are not giving the system any commands. Typing directory names is not enough - as the error message you get shows.
                          So you should type, followed by Enter (not the explanations I italicized)
                          cd\ (this navigates to the root directory of the current drive)
                          cd "c:\Program Files\Google\Google SketchUp 8" (this navigates to the SU application folder, the quotes are compulsory here)
                          Note that this doesn't work if you have a 64-bit operating system.
                          Anssi
                            SpookyChick1013
                            Thank you SO much Anssi! I haven't used dos commands in so many years I had forgotten critical little points like those you mentioned, and was struggling with implementing that fix, until I read your post. Now, I will have my thumbnails back, thank the Force!
                            Cathryn
                            https://kuromatsudriveyards.com
                            Fo-su to tomo ni aran koto o...
                            • vyctortumbuanV
                              vyctortumbuan
                              Hello...people.
                              what should i do to fix this?? i was try to follow on the top solution,but im still having a problem.
                                Doesn't work on 64bit systems.
                                http://sketchucation.com/forums/viewtopic.php?f=15&t=13097&view=unread#p218683
                                You can use a third party utility such as MagicThumbs to get thumbnails for 64bit systems + huge number of other formats.
                                • vyctortumbuanV
                                  vyctortumbuan
                                  Thanks Thom.
                                  • 2 / 2
