    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 262.5k Views 32 Watching
      rod1233
      Hi Chris
      I think the problem in the size of the file in the image
      clf_camera_recorder. employer
      Because I do I replace the file Shahu Camera Recorder v1.0
      The success
      Please help
      • Chris FullmerC Offline
        You should delete all camera recorder files. Then re-dnwload and re-install. See if that helps. I think that mighty do the trick. let me know how it goes,
        PS What is your native language?
          rod1233
          hi Chris
          I have deleted all the files and the files you have to re-descend again, and I encountered the same problem
          I do not know if the file size minus
          I repeat, when I put the files for the first time the result was quite successful, but know what happened to get that error
          I speak the Russian language
            Hi Rod, I still don't see what the error is. The files are where they should be, their sizes are correct. They are very small files. The size discrepency is normal and it is due to how Windows stores files tot he disk.
            Is SketchUp giving you an error? You have not posted any actual SketchUp error. If so, what does it say?
              rod1233
              hi Chris
              I can not succeed in this. I'm very sad for that 😞 😞 😞
              And thank you for the efforts made by me
              I do not know where the problem
              Perhaps there may be settings in the program led to this error
              Thank you
                Rod, what is not working? Is it not appearing in SketchUp?
                Maybe it just needs to be enabled. Go to Window > Preferences > Extensions and make sure that Camera Recorder is enabled.
                See if that helps. Then let me know.
                  Rhettsmiller
                  @plot-paris said:
                  hey Chris. I am afraid, the buttons of the toolbar end up blank.
                  the zip file, you posted contains a ruby file called 'clf_center_on_origin.rb' and a folder with the Camera Recorder files.
                  within this folder there is the camera recorder ruby, several images and an empty folder called 'images'.
                  but no matter, where I placed the images (within the images folder. or the images folder directly in the plugins folder) it doesn't seem to be working 😞
                  How was this resolved?
                  Rhett
                    arg, I responded to this, and then lost connection or something and it lost my reponse....oh well. I'll try again (plus the pm's we've been sending back and forth).
                    Essentially the problem they saw here was caused by something else, I forgot a file.
                    I just asked in my PM if you have podium installed (its another plugin that apparenetly can cause problems with plugin installation locations?). Lets take the onversation out of the PM area and here, just in case others can chime in with some Mac expertise.
                    Anyhow, you might need to upload a screenshot of your plugins floder so I can see what's going on.
                      No, you don't need podium installed. I had seen in another thread that it might complicate you mac installation folders or something.
                      So I would say that the best thing to do now would be to send a upload a screenshot of your plugins folder, and maybe one of the inside of the clf_camera_recorder folder also.
                        rod1233
                        Hi Chris
                        I think I could not explain the problem. Although attaching the image.
                        When do I paste the files in the desired place, and I do open the program I get this window described the picture attached
                        Hee this problem. 😞
                        Please note that I had originally succeeded in doing so for two days. And then I got this problem without any reason
                        Tried to get rid of this problem but to no avail
                        Thank you
                          I have a new thought Rod. I bet it is a problem with "compatibility files".
                          Go to the Plugins folder and look at the top for "compatibility files" click on that. It is a secret alternate version of your plugins folder (I'm serious). If there is anything about camera recorder in there, make sure to delete it! all files and folders.
                          Then see if SketchUp works right. If not, try deleteing all camera recorder files in the regular plugins fodler, double check that the compatibility files folder also has no camera recorder files.
                          Then once you are sure there are no camera recorder files or folders, then reinstall them.
                          Then check in sketchup. I have a feeling this will solve it. Windows compaitiblity files has cause this problem more than once.
                            rod1233
                            Hi Chris
                            Thank you for the efforts
                            It tried to explained to me earlier.
                            But unfortunately the problem still exists. 😞 😞 😞
                            Please search for a solution
                            rod
                              Hi Rod, please verify that you tried the Compatibility files suggestions. Your response does not state that you tried it.
                              Next, remove all other plugins from your plugins folder. Install only the camera recorder plugin. See if that works. Then we can go from there.
                                rod1233
                                Hi Chris
                                I've done it and you delete all the contents of the folder plugins
                                And you do Install only the camera recorder plugin.
                                But the problem is not over yet
                                rod
                                • charly2008C Offline
                                  charly2008
                                  Chris, your camera tool is first class.
                                  You don't need Quick time Pro. There is a freeware player who plays image sequences also. The name is IMAGEN.
                                  This Page Does Not Exist
                                  Oops, looks like the page is lost.
                                  (gromada.com)
                                  Supported formats:
                                  AC3, Dolby Digital compatible
                                  AVI / DIVX / IVF, Windows Audio Video Interleaved
                                  BAY, Bayer Image
                                  BMP / DIB, Windows Device Independent Bitmap
                                  CINE, Vision Research CINE, (read/uncompressed only)
                                  FLC / FLI, Autodesk FLIC/FLIC-Pro
                                  GIF, Graphics Interchange Format
                                  HAV, High quality Audio Video
                                  JP2, JPEG-2000 File Format / CodeStream
                                  JPEG, Joint Photographic Expert Group
                                  MPA / MP2 / MP3, MPEG-1/2 Audio Layer II/III (MP3 read only)
                                  MPEG, Moving Pictures Expert Group, MPEG-1/2
                                  OGG, OggVorbis Audio
                                  OGV, OggVorbis Video/Audio
                                  PCX, Zsoft Paintbrush
                                  PNG, Portable Network Graphics
                                  PNM / PPM, Portable Image
                                  RAS / SUN, Sun Raster Image
                                  RGB / SGI, Silicon Graphics Image
                                  TGA, Truevision Targa
                                  TIFF, Tagged Image File Format
                                  WAV, Windows Wave Sound
                                  * WMA, Windows Media Audio
                                  * WMV, Windows Media Video
                                  XPM, X-Pixmap
                                    @rod1233 said:
                                    Hi Chris
                                    rod
                                    Great, thanks for trying that. Could you please take another screenshot of your plugins folder and inside the clf_camera_recorder folder.
                                    Also, does the file path to your sketchup program contain any non-english standard characters? I know russian language characters might cause problems with things.
                                      Great Charly, I'll post a link to that software in the first post of this thread. Thanks for finding it!
                                        rod1233
                                        I did that and the problem is still.
                                        Note: Windows in English, and also to the program in English
                                        I remembered something: when it succeeded for the first time you change the course of exporting images to another folder on the desktop.
                                        Does this lead to error
                                        rod
                                          Could you zip up your plugins folder and send me a copy please. Please remove other plugins first too. I don't need a copy of all your othe plugins you might have. Just mine. I'd like to see how its installed, and then I'll put it in my system just like you have it and see if I get the same errors.
                                            rod1233
                                            Here's what you requested
                                            This folder contains the files
                                            • 2 / 7
