    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 275.2k Views 32 Watching
      rod1233
      Hi Chris Fullmer
      Thank you for the attention
      And I would like to tell you in detail the problems of
      At first you download the files as explained and you are quite successful and after two days .. got this error after you have downloaded the Camera Recorder v1.0
      And succeeded in it and when I try to download Camera Recorder v1.7 the result is an error
      I do not know what is wrong please help
      I hope you send the file to my email
      rod1233@hotmail.com
      This image is when you download the Camera Recorder v1.0
      This image is when you download the Camera Recorder v1.7
        rod1233
        Hi Chris
        I think the problem in the size of the file in the image
        clf_camera_recorder. employer
        Because I do I replace the file Shahu Camera Recorder v1.0
        The success
        Please help
        • Chris FullmerC Offline
          You should delete all camera recorder files. Then re-dnwload and re-install. See if that helps. I think that mighty do the trick. let me know how it goes,
          PS What is your native language?
            rod1233
            hi Chris
            I have deleted all the files and the files you have to re-descend again, and I encountered the same problem
            I do not know if the file size minus
            I repeat, when I put the files for the first time the result was quite successful, but know what happened to get that error
            I speak the Russian language
              Hi Rod, I still don't see what the error is. The files are where they should be, their sizes are correct. They are very small files. The size discrepency is normal and it is due to how Windows stores files tot he disk.
              Is SketchUp giving you an error? You have not posted any actual SketchUp error. If so, what does it say?
                rod1233
                hi Chris
                I can not succeed in this. I'm very sad for that 😞 😞 😞
                And thank you for the efforts made by me
                I do not know where the problem
                Perhaps there may be settings in the program led to this error
                Thank you
                  Rod, what is not working? Is it not appearing in SketchUp?
                  Maybe it just needs to be enabled. Go to Window > Preferences > Extensions and make sure that Camera Recorder is enabled.
                  See if that helps. Then let me know.
                    Rhettsmiller
                    @plot-paris said:
                    hey Chris. I am afraid, the buttons of the toolbar end up blank.
                    the zip file, you posted contains a ruby file called 'clf_center_on_origin.rb' and a folder with the Camera Recorder files.
                    within this folder there is the camera recorder ruby, several images and an empty folder called 'images'.
                    but no matter, where I placed the images (within the images folder. or the images folder directly in the plugins folder) it doesn't seem to be working 😞
                    How was this resolved?
                    Rhett
                      arg, I responded to this, and then lost connection or something and it lost my reponse....oh well. I'll try again (plus the pm's we've been sending back and forth).
                      Essentially the problem they saw here was caused by something else, I forgot a file.
                      I just asked in my PM if you have podium installed (its another plugin that apparenetly can cause problems with plugin installation locations?). Lets take the onversation out of the PM area and here, just in case others can chime in with some Mac expertise.
                      Anyhow, you might need to upload a screenshot of your plugins floder so I can see what's going on.
                        No, you don't need podium installed. I had seen in another thread that it might complicate you mac installation folders or something.
                        So I would say that the best thing to do now would be to send a upload a screenshot of your plugins folder, and maybe one of the inside of the clf_camera_recorder folder also.
                          rod1233
                          Hi Chris
                          I think I could not explain the problem. Although attaching the image.
                          When do I paste the files in the desired place, and I do open the program I get this window described the picture attached
                          Hee this problem. 😞
                          Please note that I had originally succeeded in doing so for two days. And then I got this problem without any reason
                          Tried to get rid of this problem but to no avail
                          Thank you
                            I have a new thought Rod. I bet it is a problem with "compatibility files".
                            Go to the Plugins folder and look at the top for "compatibility files" click on that. It is a secret alternate version of your plugins folder (I'm serious). If there is anything about camera recorder in there, make sure to delete it! all files and folders.
                            Then see if SketchUp works right. If not, try deleteing all camera recorder files in the regular plugins fodler, double check that the compatibility files folder also has no camera recorder files.
                            Then once you are sure there are no camera recorder files or folders, then reinstall them.
                            Then check in sketchup. I have a feeling this will solve it. Windows compaitiblity files has cause this problem more than once.
                              rod1233
                              Hi Chris
                              Thank you for the efforts
                              It tried to explained to me earlier.
                              But unfortunately the problem still exists. 😞 😞 😞
                              Please search for a solution
                              rod
                                Hi Rod, please verify that you tried the Compatibility files suggestions. Your response does not state that you tried it.
                                Next, remove all other plugins from your plugins folder. Install only the camera recorder plugin. See if that works. Then we can go from there.
                                  rod1233
                                  Hi Chris
                                  I've done it and you delete all the contents of the folder plugins
                                  And you do Install only the camera recorder plugin.
                                  But the problem is not over yet
                                  rod
                                  • charly2008C Offline
                                    charly2008
                                    Chris, your camera tool is first class.
                                    You don't need Quick time Pro. There is a freeware player who plays image sequences also. The name is IMAGEN.
                                    http://gromada.com/download.html
                                    Supported formats:
                                    AC3, Dolby Digital compatible
                                    AVI / DIVX / IVF, Windows Audio Video Interleaved
                                    BAY, Bayer Image
                                    BMP / DIB, Windows Device Independent Bitmap
                                    CINE, Vision Research CINE, (read/uncompressed only)
                                    FLC / FLI, Autodesk FLIC/FLIC-Pro
                                    GIF, Graphics Interchange Format
                                    HAV, High quality Audio Video
                                    JP2, JPEG-2000 File Format / CodeStream
                                    JPEG, Joint Photographic Expert Group
                                    MPA / MP2 / MP3, MPEG-1/2 Audio Layer II/III (MP3 read only)
                                    MPEG, Moving Pictures Expert Group, MPEG-1/2
                                    OGG, OggVorbis Audio
                                    OGV, OggVorbis Video/Audio
                                    PCX, Zsoft Paintbrush
                                    PNG, Portable Network Graphics
                                    PNM / PPM, Portable Image
                                    RAS / SUN, Sun Raster Image
                                    RGB / SGI, Silicon Graphics Image
                                    TGA, Truevision Targa
                                    TIFF, Tagged Image File Format
                                    WAV, Windows Wave Sound
                                    * WMA, Windows Media Audio
                                    * WMV, Windows Media Video
                                    XPM, X-Pixmap
                                      @rod1233 said:
                                      Hi Chris
                                      rod
                                      Great, thanks for trying that. Could you please take another screenshot of your plugins folder and inside the clf_camera_recorder folder.
                                      Also, does the file path to your sketchup program contain any non-english standard characters? I know russian language characters might cause problems with things.
                                        Great Charly, I'll post a link to that software in the first post of this thread. Thanks for finding it!
                                          rod1233
                                          I did that and the problem is still.
                                          Note: Windows in English, and also to the program in English
                                          I remembered something: when it succeeded for the first time you change the course of exporting images to another folder on the desktop.
                                          Does this lead to error
                                          rod
                                            Could you zip up your plugins folder and send me a copy please. Please remove other plugins first too. I don't need a copy of all your othe plugins you might have. Just mine. I'd like to see how its installed, and then I'll put it in my system just like you have it and see if I get the same errors.
                                            • 4 / 7
