    [Plugin] Camera Recorder v1.7.2 UPDATED May 23, 2013
    136 Posts 32 Posters 268.9k Views 32 Watching
      rod1233
      Hi Chris Fullmer
      There is a problem I have please help
      When I download clf_camera_recorder-v1.7
      Knowing that I've downloaded in advance and did a wonderful job, but not what happened Lardy
      A copy of the problem 😞 😞
      Note
      When I download clf_camera_recorder-v-1
      The device Ballowavqp it
      Please help in this problem
      rode
      • Chris FullmerC Offline
        It looks like you do not have the files put in the correct locations. In the plugins folder, you should have a single file and a folder
        clf_camera_recorder_loader.rb
        clf_camera_recorder <---FOLDER
        And inside the folder you should have the file:
        clf_camera_recorder.rb
        along with all the icons.
        So check to see if that you have everything installed correctly and let me know if it works.
          rod1233
          Hi Chris Fullmer
          Thank you for the attention
          And I would like to tell you in detail the problems of
          At first you download the files as explained and you are quite successful and after two days .. got this error after you have downloaded the Camera Recorder v1.0
          And succeeded in it and when I try to download Camera Recorder v1.7 the result is an error
          I do not know what is wrong please help
          I hope you send the file to my email
          rod1233@hotmail.com
          This image is when you download the Camera Recorder v1.0
          This image is when you download the Camera Recorder v1.7
            rod1233
            Hi Chris
            I think the problem in the size of the file in the image
            clf_camera_recorder. employer
            Because I do I replace the file Shahu Camera Recorder v1.0
            The success
            Please help
              You should delete all camera recorder files. Then re-dnwload and re-install. See if that helps. I think that mighty do the trick. let me know how it goes,
              PS What is your native language?
                rod1233
                hi Chris
                I have deleted all the files and the files you have to re-descend again, and I encountered the same problem
                I do not know if the file size minus
                I repeat, when I put the files for the first time the result was quite successful, but know what happened to get that error
                I speak the Russian language
                  Hi Rod, I still don't see what the error is. The files are where they should be, their sizes are correct. They are very small files. The size discrepency is normal and it is due to how Windows stores files tot he disk.
                  Is SketchUp giving you an error? You have not posted any actual SketchUp error. If so, what does it say?
                    rod1233
                    hi Chris
                    I can not succeed in this. I'm very sad for that 😞 😞 😞
                    And thank you for the efforts made by me
                    I do not know where the problem
                    Perhaps there may be settings in the program led to this error
                    Thank you
                      Rod, what is not working? Is it not appearing in SketchUp?
                      Maybe it just needs to be enabled. Go to Window > Preferences > Extensions and make sure that Camera Recorder is enabled.
                      See if that helps. Then let me know.
                        Rhettsmiller
                        @plot-paris said:
                        hey Chris. I am afraid, the buttons of the toolbar end up blank.
                        the zip file, you posted contains a ruby file called 'clf_center_on_origin.rb' and a folder with the Camera Recorder files.
                        within this folder there is the camera recorder ruby, several images and an empty folder called 'images'.
                        but no matter, where I placed the images (within the images folder. or the images folder directly in the plugins folder) it doesn't seem to be working 😞
                        How was this resolved?
                        Rhett
                          arg, I responded to this, and then lost connection or something and it lost my reponse....oh well. I'll try again (plus the pm's we've been sending back and forth).
                          Essentially the problem they saw here was caused by something else, I forgot a file.
                          I just asked in my PM if you have podium installed (its another plugin that apparenetly can cause problems with plugin installation locations?). Lets take the onversation out of the PM area and here, just in case others can chime in with some Mac expertise.
                          Anyhow, you might need to upload a screenshot of your plugins floder so I can see what's going on.
                            No, you don't need podium installed. I had seen in another thread that it might complicate you mac installation folders or something.
                            So I would say that the best thing to do now would be to send a upload a screenshot of your plugins folder, and maybe one of the inside of the clf_camera_recorder folder also.
                              rod1233
                              Hi Chris
                              I think I could not explain the problem. Although attaching the image.
                              When do I paste the files in the desired place, and I do open the program I get this window described the picture attached
                              Hee this problem. 😞
                              Please note that I had originally succeeded in doing so for two days. And then I got this problem without any reason
                              Tried to get rid of this problem but to no avail
                              Thank you
                                I have a new thought Rod. I bet it is a problem with "compatibility files".
                                Go to the Plugins folder and look at the top for "compatibility files" click on that. It is a secret alternate version of your plugins folder (I'm serious). If there is anything about camera recorder in there, make sure to delete it! all files and folders.
                                Then see if SketchUp works right. If not, try deleteing all camera recorder files in the regular plugins fodler, double check that the compatibility files folder also has no camera recorder files.
                                Then once you are sure there are no camera recorder files or folders, then reinstall them.
                                Then check in sketchup. I have a feeling this will solve it. Windows compaitiblity files has cause this problem more than once.
                                  rod1233
                                  Hi Chris
                                  Thank you for the efforts
                                  It tried to explained to me earlier.
                                  But unfortunately the problem still exists. 😞 😞 😞
                                  Please search for a solution
                                  rod
                                    Hi Rod, please verify that you tried the Compatibility files suggestions. Your response does not state that you tried it.
                                    Next, remove all other plugins from your plugins folder. Install only the camera recorder plugin. See if that works. Then we can go from there.
                                      rod1233
                                      Hi Chris
                                      I've done it and you delete all the contents of the folder plugins
                                      And you do Install only the camera recorder plugin.
                                      But the problem is not over yet
                                      rod
                                      • charly2008C Offline
                                        charly2008
                                        Chris, your camera tool is first class.
                                        You don't need Quick time Pro. There is a freeware player who plays image sequences also. The name is IMAGEN.
                                        http://gromada.com/download.html
                                        Supported formats:
                                        AC3, Dolby Digital compatible
                                        AVI / DIVX / IVF, Windows Audio Video Interleaved
                                        BAY, Bayer Image
                                        BMP / DIB, Windows Device Independent Bitmap
                                        CINE, Vision Research CINE, (read/uncompressed only)
                                        FLC / FLI, Autodesk FLIC/FLIC-Pro
                                        GIF, Graphics Interchange Format
                                        HAV, High quality Audio Video
                                        JP2, JPEG-2000 File Format / CodeStream
                                        JPEG, Joint Photographic Expert Group
                                        MPA / MP2 / MP3, MPEG-1/2 Audio Layer II/III (MP3 read only)
                                        MPEG, Moving Pictures Expert Group, MPEG-1/2
                                        OGG, OggVorbis Audio
                                        OGV, OggVorbis Video/Audio
                                        PCX, Zsoft Paintbrush
                                        PNG, Portable Network Graphics
                                        PNM / PPM, Portable Image
                                        RAS / SUN, Sun Raster Image
                                        RGB / SGI, Silicon Graphics Image
                                        TGA, Truevision Targa
                                        TIFF, Tagged Image File Format
                                        WAV, Windows Wave Sound
                                        * WMA, Windows Media Audio
                                        * WMV, Windows Media Video
                                        XPM, X-Pixmap
                                          @rod1233 said:
                                          Hi Chris
                                          rod
                                          Great, thanks for trying that. Could you please take another screenshot of your plugins folder and inside the clf_camera_recorder folder.
                                          Also, does the file path to your sketchup program contain any non-english standard characters? I know russian language characters might cause problems with things.
                                            Great Charly, I'll post a link to that software in the first post of this thread. Thanks for finding it!
                                            • 4 / 7
