    Adding geometry to model - speed issues
    40 Posts 7 Posters 7.9k Views 7 Watching
      But making groups isn't the problem. In my case it's faster to create a few smaller groups than one big chunk of geometry. That's even when the geometry is generated as a PolygonMesh. The geometry is then added by a single .add_faces_from_mesh. The time it takes to add the mesh isn't linear to the amount of faces generated.
      And making a PolygonMesh seem to be twice as fast as generating each face using .add_face - which comes really slow.
      • AdamBA Offline
        AdamB
        @tig said:
        @thomthom said:
        @tig said:
        I meant GC.start which collects garbage from group making etc...
        You use that after creating a group?
        In my case here, it's creating geometry in a series of groups which is faster than adding all the geometry into the same context.
        GC.start is Jim's baby - built-in - As I understand it you start if before making the groups ?
        GC.start is Mr.Ruby's baby πŸ˜‰ . It gets called automatically (every 256 instructions) by the Ruby interpreter and you generally don't need to call it yourself unless you really know what your doing.
        @adamb said:
        Adam, what is this COM interface?
        Its a hateful, clunky and ultimately pointless way of calling C++ that was introduced by MS many years ago - and since largely abandoned in favour of regular OO solutions. My point isn't about COM, more about calling the SU API directly without using Ruby. AFAIK Google only provide a COM interface to their underlying C++ API.
          Jim
          I thought I learned of it on this forum!
          I don't think it's the GC that's slowing adding geometry - more likely it is Sketchup looking to make faces and break overlapping geometry as geometry is either added or exploded. (pure conjecture.)
          • W Offline
            Whaat
            I don't think I've tested this on SU7 but on SU6, using the add_faces_from_mesh method was way faster than adding individual faces using the add_face method. I thought it was 3-4 times faster (but I don't remember for sure). Maybe they have tightened the gap between these method in SU7.1?
            For a quick test, just use SDS. Normal operation using the add_faces_from_mesh method, but if you choose the 'copy materials' option, it uses the add_face method.
              That's what I was suspecting as well. Was hoping for different result with PolygonMesh - that's it's simple be inserted as-is. But seeing that we don't actually know what it is... ...just guessing. πŸ˜•
              But I take it there's no tricks hidden up in any sleeves?
                Yes - I find add_faces_from_mesh to be faster than add_face to be faster as well. But comparing the number of polygons in the mesh with the time it takes to add the geometry - time does not increase linearly. It does seem that the time relates to the number of entities already in the context you add to.
                • AdamBA Offline
                  AdamB
                  Try this:
                  ` def addfaces(ents = Sketchup.active_model.entities)
                  vertices = [Geom::Point3d.new(0,0,0), Geom::Point3d.new(1,0,0),Geom::Point3d.new(0,1,0)]
                  start = Time.new
                  1000.times do
                  	ents.add_face vertices
                  puts "Same tris took #{(Time.new - start)}"
                  start = Time.new
                  1000.times do
                  	vertices[0].z += 0.1
                  	vertices[1].z += 0.1
                  	vertices[2].z += 0.1
                  puts "different tris took #{(Time.new - start)}"
                  start = Time.new
                  1000.times do
                  puts "more different tris took #{(Time.new - start)}"
                  addfaces`
                  Firstly adds 1000 triangles using the same coordinates, secondly adds 1000 triangles with unique vertices, lastly adds another 1000 triangles with unique vertices. Shows a 10x difference in performance, yet the geometry engine will be constructing the topology in all cases - ie doing work.
                  This would seem to indicate its an insertion bottleneck - which is consistent with thomthom findings.
                  What does it mean? It means its a brick wall and adding geometry in SU is slow and there is nothing you can do about it.
                      I ran that script four times:
                      ` addfaces
                      Same tris took 0.05
                      different tris took 0.71
                      more different tris took 1.9
                      nil
                      addfaces
                      Same tris took 1.84
                      different tris took 1.68
                      more different tris took 1.87
                      nil
                      addfaces
                      Same tris took 1.85
                      different tris took 1.659
                      more different tris took 1.89
                      nil
                      addfaces
                      Same tris took 1.85
                      different tris took 1.69
                      more different tris took 1.86
                      nil`
                      Didn't delete geometry in between.
                        Moved the geometry slightly away from original position and ran three more tests:
                        ` addfaces
                        Same tris took 1.8
                        different tris took 2.64
                        more different tris took 4.13
                        nil
                        addfaces
                        Same tris took 3.62
                        different tris took 3.26
                        more different tris took 3.65
                        nil
                        addfaces
                        Same tris took 3.62
                        more different tris took 3.68
                        nil`
                          How about entities.fill_from_mesh(...) rather than add_faces_from_mesh(..)
                          http://code.google.com/apis/sketchup/docs/ourdoc/entities.html#fill_from_mesh
                          is that quicker ?
                            I had a mad hope that Sketchup.break_edges = false might change something...
                            ` Sketchup.break_edges=false
                            false
                            addfaces
                            Same tris took 3.58
                            different tris took 5.62
                            more different tris took 7.56
                            nil
                            Sketchup.break_edges=true
                            true`
                            nope!
                            is that quicker ?
                            oooh. I've missed that method. Will give it a wirl when I get home. That even has a number of features which saves me some work when it comes to smooth vs faceted. πŸ‘
                              Jim
                              @whaat said:
                              I wasn't aware of this method! Has it really been available since SU6??
                              Me either. I thought I knew the API up and down (I act like, sometimes!) Makes me wonder what else is in there.
                              edit - maybe it was always "there", just not documented until the new automatic document system started?
                              • W Offline
                                Whaat
                                is that quicker ?
                                Someone, please do a performance test of this method now! (I would if I could.... 😞 )
                                  is that quicker ?
                                  I tried it in SU6 - it's there al'right. I will try in SU5 later today.
                                  I think I've overlooked it because I've never used PolygonMeshes before.
                                    The old documentation doesn't seem to mention it: http://download.sketchup.com/OnlineDoc/gsu6_ruby/Docs/ruby-entities.html
                                    Maybe it was added in the November update of the docs.
                                    • W Offline
                                      Whaat
                                      Sometimes I just want to slap whoever was responsible for the API docs...however, right now, I want to kick them in the junk.
                                        Come to think of it - I do remember reading somewhere about PolygonMesh'es being added without error control and being somewhat quicker. But since I previously had no interests in PolygonMeshes I didn't pay much attention. Assumed there was only one method to add a mesh.
                                          fill_from_mesh exists in SU5 as well.
                                            fill_from_mesh seems to be twice as fast as add_faces_from_mesh.
                                            But its default values doesn't match with the manual. The manual claims that the default for smooth is 0. But when I omit that value I get a soft and smooth mesh. I have to explicitly set it to 0 for no smoothing.
                                            And I can't make out what the weld vertices do. I don't see any difference in what it produces.
